Sanyo plus q 60 speed problems spining to fast
The plater spining to fast sims that the quartz control not working
Once the needle touches 33 lp it speeds buy the songs
Yes the platter speeds up until the moment comes. 0'5 sec later and then the electronics take over , want you to try quartz activated and after that quartz put out and then you have a pll. try moving the pitch a bit, cause the 1210mk2 aint tables which you want for the good maintainence. if it helps or doesn't , mail as fast as you can
Mar 18, 2014 | Technics Audio Players & Recorders
Maytag modle #rsw24eo.refrigarator side will only get down to 60 deg.the freezer side working as designed.cleaned condensor and checked condensor blower motor.I think it is spining way,way to...
Your problem sounds like a defrost or control board. The condser fan sould run full speed when running. It will cost about 90-100 dollars. I hope this helps.
Aug 27, 2011 | Maytag MSD2656G Side by Side Refrigerator
Not spining properly on daily load cycle
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Please reply with additional details for further assistance.
Shane
Mar 26, 2011 | Whirlpool Washing Machines
Can boost mobile sim work in a pro 700
PRO 700 DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
Mar 14, 2010 | Sanyo PRO-700 Cellular Phone
When the tread mill is running at a set speed, it for no appearant reason speeds up super fast with no one touching any button?
The motor controller controls the speed of the motor. This part usually work or dont work but I have seen a few instances where it was just going bad.
Jun 05, 2009 | Weslo Cadence 60 SE Treadmill
Technics SL-Q200 Quartz Direct Drive
Your best bet is to get a good quality switch contact cleaner to clean all the contacts on the speed control switches.
I guess the contacts inside the switches will have corroded slightly with your turntable having been stored in the garage.
May 13, 2009 | Technics SL-1210MK3 Turntable
SPRINT SANYO PRO 700
Hey! I just got the PRO 700. IT DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
Apr 09, 2009 | Sanyo PRO-700 Cellular Phone
Time speeds up on alarm clock
Usually clocks use the frequency of the AC supply to keep time, a synchronous motor was used in the old motorized clocks. If all the outlets eventually go back to one incoming supply, they all share the same mains frequency.
If it is a quartz reference type, then temperature may be a factor - extremes of temperature will cause deviation in the main oscillator. Otherwise, time appears to be passing at a different rate in that room!
old LED clocks did not have a crystal, they had a counter that counted the 60 cycles power, an intermittent connection will create extra pulses that will be counted. That will make it run fast.
it possible the outlet makes an intermittent connection (loose plug, maybe) so that the clock intermittently switches to battery backup on a lousy quartz crystal timebase that runs too fast during these periods? Remove the battery & see if the clock resets to 12:00 periodically.
Mar 30, 2009 | Audio Players & Recorders
Problem when i click to make sims do something...
Hi...
i think you have to change your mouse settings in control panel...
Go to Start->Settings-->Control Panel--> Mouse..
then try bringing the Double click speed bar in the middle.....
Jan 19, 2009 | EA - Electronic Arts The Sims 2: Free...
 Grubhead
Grubhead
