I have a galaxy comet convector gas fire when i lite it it burns for about 3/4 mins then cuts out it allso cuts out the pilot light
Galaxy mostyn ch89dt
5 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: rinnai convector 404
You have a dirty pilot assembly and maybe even a bad ECO switch (safety switch). I would suggest replacing the ECO and removing the pilot assembly and clean it out.
Posted on Jun 03, 2008
  • 108 Answers
SOURCE: I have a weil-mclain CGA-4-SPDN
You need to replace the Thermocouple. (pilot safety device) It would be best to call a Technician about this.
Posted on Oct 22, 2008
SOURCE: gas firelog pilot light will not stay lite
try to replace the thermo couple
Posted on Nov 25, 2008
  • 7 Answers
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
Posted on Jan 30, 2009
Slant fin boiler galaxy natural gas, pump starts and runs. Igniter comes on . Pilot lights. Burner lights. Runs for seconds. Burn shuts down. Igniter starts pilot light, pilot goes out and on and on
The flame sensor, which is located in front of one of the burner flames is probably oxidized and needs cleaning or replacement. If the unit can't "sense" the flame, it will continue to cycle.
Jan 22, 2017 | Slant Fin Heating & Cooling
Require millivoltage for gas valve on raypack pool heater
clean burn tube to pilot generator replace generator and make sure all wires tight
Apr 12, 2017 | RTO Pressure Switch 3902 Swimming Pool...
Heater fires 3 times then quits, light on control board quits blinking then minutes later it tries again.
It sounds like a weak pilot generator. They wear out after a number of years. It is trying to fire which means the safety loop is all good. Sometimes the pilot generator is strong enough to keep the pilot valve open, but upon call for heat the main gas valve isn't getting enough voltage to open (and a good voltage output from the generator drops to nothing). It's not too hard of a diy
Sep 12, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Not light
check to make sure that the poilet lite flame is touching the tip or top of the thermocouple.
the pilot lite needs to heat up the thermocouple so that the thermocouple opens the gas to the main gas log. a cold thermocouple shuts off the gas to the main gas log or gas burner and a hot thermocouple opens the gas to the main burner.
the pilot lite flame must be touching the thermocouple to heat it up.
pilot lite orface needs to be clear to let the pilot flame gas through with enough pressure so that the little flame can reach & touch the thermocouple. Pilot lite gas feed tube must be clear to let gas through. Use compressed air or a fine sewing needle, or even carb cleaner to clear out orface hole and gas feed line to pilot lite.
important!! WARNING:
if you use carb cleaner,make sure all the carb cleaner is dry,soaked up with paper towell or kleanex tissue and blowed out with compressed air , because carb cleaner can burn just like gasoline; so any carb cleaner must be compleatly gone before you attempt to lite the pilot lite.
May 20, 2013 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
How do I know if the pilot is lit on my heater? Can I light it myself?
Hello
You should be able to see it.There is a small flame in the bottom of the fire box at the end of the gas line tube inside the heater.
Also the gas valve will be turned to on.There are 3 positons on the gas valve, off pilot and on.
If the pilot lite is not lit the valve will be in the pilot or off positon.Plus if it were on and not lit you will smell gas.
Yes you can lite it.Follow instructions on side of heater on how to lite pilot.
May 10, 2011 | Heating & Cooling
Make = Trident exel natural flame gas fire - model fan powered rear flue - 549 RMN FEF +3 The fire ignites and runs normally for about 10 minutes and then the gas side completely cuts out (both the...
Hi this is a oxy pilot problem as you say, would be best to replace. There are two types that were used on Trident /FEF fires,Ican help with either but need to know which one ,get back to me for further help .Will.
Nov 11, 2010 | Heating & Cooling
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Rinnai convector 404
Jun 03, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
