Question about Toshiba 57H81 57" Rear Projection Television
Dont know what a hyper board looks like
From all the helpfull info i knoe its my hyperboard that is causing my problems. I am confadent i cak fix it myself. MY problem is i dont know what a hyperboard looks like, and where it is located in my tv
can some one help me
    Sergeant:
    Champion:
  • 267 Answers
DO YOU OWN SOLDERING STATION, SOLDERWICK, SOLDER. TAKE IT TO A SERVICER YOUR IN OVER YOUR HEAD
Posted on Jan 23, 2009
Toshiba 57hx81, has a slight squikgly line near the top of screen, colors seemed faded, not bright. i did the convergence adjustment and adjust the colors/focus with front lower right screws..Is there a...
jhinsincity: you dont need to be here, do you? the problem are the caps on the hyperboard, 10 -16v@ 10uf, rear access right hand green board, model 57hx81, the hyperboard must desoldered from main board. read the post on wavy lines,,
Dec 30, 2009 | Toshiba 57HX81 57" Rear Projection...
65H82
Have you tried to contact ptscorp.com yet. Go to their web site and get their telephone number. They should be able to help you with a good hyper board. this might be your problem with what the set is doing now. Did you have this problem before you worked on the scan converter board?
Sep 08, 2007 | Toshiba 36HF72 36" TV
Tosh 57h82 flashing led and bad hyper board.
For a service manual, contact Toshiba directly.
Jun 17, 2017 | Toshiba 57H82 57" Rear Projection...
Toshiba 50H82 hyperboard caps
Service manual won't help much in the hyper board and that's likely the problem.. Simply remove the hyper board and open the can. Inside you'll see a number of smd caps. There are 11 10mf/16v that need to be replaced...
Bill
Jul 26, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 50hd82 Hyperboard
By your question alone the best place to start would be a good repair shop. The hyper module needs to be removed from the main chassis. After removing the two outer covers locate Cx261, Cx230, Cx270, Cz52, Cx178, Cx221, C514, Cx250, Cx670, Cx241 and Cx541. These are all 16v/10uf caps SMT but most techs simply replace them with the sub mini radial caps.
Bill
Mar 13, 2008 | Toshiba 50H72 50" Rear Projection...
50h821
There are about 6 or 7 surface mount capacitors 10mf/16v that cause the symptom you are having. They are located under the shield of the hyper module. The hyper module is located behind the input jack panel in the back. The module is vertically mounted and can be removed from its socket. However you must first unsolder the 4 anchor tabs of the shield first. Thats the easy part. Removal and replacement of the capacitors requires precise and excellent soldering skills. This job should be left to someone who has done this a few times. Hope this info helps.
Nov 26, 2007 | Toshiba 50H82 50" Rear Projection...
Wavvy lines, wiggy
Dougers, I am next door, in Alberta. I have fixed my hyperboard by replacing the surface mount caps myself in my workshop for a fraction of the cost of a replacement board.
See my other thread for more information.
Oct 23, 2007 | Toshiba 57H82 57" Rear Projection...
65H82
what you did forget you just tell what is your problem now clearly so i can help you in a systematic way.
57h82
Heres your link for the capacitors http://www.mcminone.com/search.asp?keyword=surface+mount+capacitors&btnSubmit.x=8&btnSubmit.y=7&btnSubmit=GO Loads of info here about the board http://www.techlore.com/forum/thread/15237/Toshiba--Model4283--picture-is-zig-zag./ Good Luck
Jul 16, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
148 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
