Question about Toyota Hilux
Toyota hilux starter cranks but not run the engine. Check the fuse box O.K. Previously had to jump start the Hilux but still doesn't start. Is there anywhere else I should check. Thanks a lot
Hello.
Posted on Feb 19, 2013
4 Suggested Answers
  • 14036 Answers
SOURCE: how can i fix my toyota hilux 1995 from jerking?
could have stopped up fuel filter,weak faulty fuel pump.
Posted on Nov 25, 2011
rickyrt441
  • 4399 Answers
SOURCE: where is fuel tempature sensor on toyota hilux 06
Are you talking about the coolant temperature sensor or the fuel pressure sensor?
Posted on Feb 18, 2011
Zim1308
  • 543 Answers
SOURCE: 1990 Toyota Hilux 2.2litre petrol 4 x 4. I need
First of all its called the "gap" and the points "setting" is often called the "wind gap". Next the plug gap is 0.0028in and the wind gap is 0.0032in. thank you for your patients in our chat session!
Posted on Jun 27, 2011
How to change fuse of Toyota hilux 2015
  • locate fuse box
  • locate broken fuse
  • pull out broken fuse
  • push in new fuse
May 24, 2016 | Toyota Cars & Trucks
Power loss and smoking
Toyota Hilux engine power loss Questions & Answers - Fixya
www.fixya.com > ... > Tags > engine power loss > Cars & Trucks > Toyota
Toyota Hilux cars & trucks engine power loss questions and answers. Ask your Toyota engine power loss related question. ... Question about 2006 Hilux 3.0.
Sep 27, 2015 | 2006 Toyota Hilux 3.0
Check engine light is not displayed on Toyota Check engine light is not displayed on Toyota Hilux 2010 and engine does not start.
Not all failures will make check engine light come on, so run basic troubleshooting--is there spark? Correct fuel pressure? Timing belt broken? Compression?
Jun 24, 2015 | Toyota Cars & Trucks
Dashboard and side lights not working on my 2010 Toyota hilux, can you advice
Dashboard and side lights both run through a fuse, usually the same fuse, so this is your first point of checking. Go through all the fuses, make sure you check the fuse box in the engine compartment as well as the one inside the car.
Mar 02, 2015 | 2010 Toyota Hilux 2.5
Toyota hilux surf problems
have injectors or glow plugs removed and crank engine if water cones out. your engine might have experienced overheating and you have a blown gasket or a cracked cylinder and allows water into one or more cylinders.
May 14, 2014 | 1986 Toyota Hilux 2200
Toyota hilux 2006 fuse
I think she needs some re-wiring done. Sounds like not just the fuse, but "a lot of copper strips" sounds like several terminals in the fuse box were also destroyed, the ones that accept the fuses spade ends.. I may be wrong, but a new fuse box would just have empty slots for the wiring connectors, wouldn't it? In that case, she needs an experienced electrical wiring person. Blowing a 50 amp fuse sounds pretty awesome-lol.
Jan 23, 2014 | Toyota Cars & Trucks
Hilux starting
runs perfect all the time hot engine, even up hills?
ever do a tuneup
do the 60,000 mile service points? or the 90?
bad running engines, do not want to start.
did you try the 2 tricks in the operators guide
1: crank with 10% throttle (helps finding stuck closed ISC valve)
2: crank it W.O.T? clears the flooding.
got idle problems , hot engine? too low, too high>? key symptoms.
got misfire up hills,
is the CEL glowing running > Check engine lamp
ever scan it? see if DTCs are stored??????????????????????????
Dec 30, 2013 | 2006 Toyota Hilux 3.0
Toyota hillux vigo
Click the help link below,in related to toyota Hilux.
Toyota Hilux Surf Fuse Box Diagram? http://technoanswers.blogspot.in/2012/06/toyota-hilux-surf-fuse-box-diagram.html
How to lower fuel pressure on Toyota Hilux? http://schematicsdiagram.blogspot.in/2012/02/how-to-lower-fuel-pressure-on-toyota.html
2012 Toyota Hilux SR5: Immobilizer override and bypass? http://whatisbyme.blogspot.in/2012/05/2012-toyota-hilux-sr5-immobilizer.html
2006 Toyota Hilux: Programming New Key? http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
These details should help.
for more help.
keep updated with more details.
Thanks.
Oct 15, 2012 | Toyota Hilux Cars & Trucks
Where is cig lighter fuse on toyota hilux surf ssr-x
Cig lighter fuse located in fuse box under driver side foot-well.Click the link below for fuse box diagram:-----http://technoanswers.blogspot.in/2012/06/toyota-hilux-surf-fuse-box-diagram.html
--------This will help.Thanks.
Jun 27, 2012 | Toyota Hilux Cars & Trucks
Owners manual for a 1986 toyota hilux dual cab. the cigerate lighter doesn't work and would like to know the fuse diagram to help me locate the right fuse
Open the fuse box, check each fuse if the tiny wire that connects to each side is not cut, if cut, then replace the fuse.
Aug 12, 2011 | Toyota Pickup Cars & Trucks
Toyota Hilux Logo
352 people viewed this question
Top Toyota Toys Experts
Thomas Perkins
Thomas Perkins
Rabbit Brains
Rabbit Brains
Stan Ford
Are you a Toyota Toy Expert? Answer questions, earn points and help others
