Question about Kodak Cameras
Easy share M451 will only work when plugged in, have fitted a new battery
Camera will not start up, works when plugged in to charger, have fitted a new battery,
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello Susan, I thought I just answered this question ? Well I guess I will answer it again. Sounds like contact problems inside the camera. Look inside for anything obvious, normally corrosion or contact damage. Hope this helps.
Best Regards, Russell
Posted on Jan 24, 2013
SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Posted on Sep 26, 2008
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
BillB-SA
  • 2761 Answers
SOURCE: Kodak Easy Share V1003 camera is frozen. Turned
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
BillB-SA
  • 2761 Answers
SOURCE: Kodak Easy Share M763 Won't turn on!!
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
Posted on Aug 15, 2009
  • 11967 Answers
SOURCE: zoom lens stuck in out position, kodak C875 camera
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 28, 2010
Replaced battery since it wasn't holding a charge. Has been plugged in for 24 hrs, still won't power on when unplugged from wall charger. What course of action should I attempt?
Possibly the charger itself is bad and only operating as a electrical connection/power cord for your camera. Try borrowing or buying another charger or take the camera to a local camera repair center or Best Buy, etc or contact customer service for your camera's manufacturer.
Hope this helps. Mike
May 24, 2015 | Kodak Easyshare M580 Digital Camera
Can you charge camera from USB?
You don't say what make or model the camera is, so I can only answer generally. Most cameras, as opposed to most cellphones, do not charge the battery in the camera at all. They are supplied with a separate mains charger- you take the battery out of the camera and put it in the charger. I have a number of cameras with USB connectors, and none of them charge while connected to the computer.
If you bought the camera new, and it came with a charger, then the camera almost certainly needs the charger to charge the battery. If you purchased it used or it was a hand-me-down, and you didn't get a charger, then the seller or giver has probably been remiss. It won't hurt to leave the camera connected to the computer's USB port to see if it will charge, but when that doesn't work, you can find a replacement charger for your camera by searching Amazon with the camera model number and the word "charger". Better, you can get a "universal" charger on Amazon for as little as $4 that will charge any of the small lithium batteries used in cameras and phones (assuming this isn't a huge battery of the kind fitted to older video cameras). I have a universal charger and it is easy to use and has saved me a lot of money as I no longer need to buy a replacement for every type of battery I come across.
Jan 02, 2011 | Vivitar Cameras
My kodack easy share c183 camera will not charge
The C182 isn't a battery charger. It uses standard AA batteries, disposable or rechargeable. If you use rechargeable batteries, you must charge them outside the camera using a standard battery charger.
Dec 26, 2010 | Kodak Easyshare C182 12MP Digital Camera
Z740 easy share will not power up,tried new batteries ,nothing at
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format.
Jun 08, 2010 | Kodak EasyShare Z740 Digital Camera
Battery won't charge on my ryobi 14.4v cordless drill yellow and green lights stay on
I had the same problem and found a solution on another forum...
Plug the battery into the charger. The yellow and green lights come on. Leave the battery plugged into the charger. Plug and unplug the charger power cord from it's power source a few times until the the red charger light comes on..... problem solved!
I think the "smart" circuit in the charger that is supposed to trickle charge before the regular charge cycle needs at least some battery power to test and start the cycle. If the battery is totally discharged, the test can't deternine the battery status and will not charge.... Plugging and unplugging the charger seems to bypass this teat and charge the battery normally. The charging process should work normally after this method.
Oct 22, 2009 | Drills
I CHARGED THE CAMARA OVER NIGHT AND THE CAMARA IS
First off, There is nothing inside the camera that is user, by you, fixable. As simple as it sounds, be sure you are pressing the actual ON/OFF button of the camera. Assured of that and if still NOT working, make sure that the BATTERY is installed correctly, in most cameras and other devices the BATTERY will fit in the device in a designed way to make it idiot proof. Assured of that, make sure that you actually have POWER going to the CHARGER. To make sure that you have power at the outlet you have chosen, plug a lamp into it to determine that the outlet is hot. Assured of that, Now plug your charger in. There should be a light of some color on the charger to indicate that it is doing its job. Either correctly put your BATTERY in the charger or connect your camera to the charger. If your charger has an installed indicator light, it should NOW be illuminated. If it IS so, then your charger most likely works. If NOT illuminated, when it should be, most likely it does not work in which case seek another charger. IF the charger appears to BE working but the BATTERY still does NOT charge, then try another BATTERY (a NEW one). If after eliminating all possible problems that can be addressed by you the user and after TRYING all of the above suggestions, the camera STILL does not work, return it and whine and try for a refund or exchange for one that works or remember that; "All things man made are subject to fail and as if by magic, you have found one that proves it".
Apr 20, 2009 | Optimus DS-5080 Digital Camera
I have a Kodak Easy Share Camera ANd I have a charger, had this for 2 years and now the charger shows green when charged but will not open the lense
Mine did the same thing and I found out that the battery door was not completely closing. I put a rubber band around it to put pressure on the little battery door and it worked. My son's camera did the same thing.
Sep 15, 2008 | Cameras
Jazz DV169 issue
umm i have jazz camera and i didnt have a charger **** i bout a motorola house cahrger and it charged my camera.
Aug 01, 2008 | Jazz DV169 Camcorder
Charger light flashing, battery not charging
What you can do is call their tech support department and they should be able to replace the battery for you. Tech support will take your information and request you to send in your battery before they replace it.
Jul 23, 2007 | Casio Exilim Card EX-S600 Digital Camera
Cameras Logo
44 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
