Question about Janome Harmony 2041
The machine doesn't go in reverse when I press the tab
    New Friend:
Can you help me
Posted on Feb 20, 2013
Loud clunking noise when sewing. . . then it starts to stutter then it stops & gives me an error. It doesn't occur when reverse sewing though
try these suggestions
change the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not damaged or warped
make sure the bobbin is not over full
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin case fits securely into the machine unless it's
a drop in bobbin
if these suggestions don't help then the machine may need to be
checked at a repair shop
Sep 11, 2012 | Brother CS6000i Computerized Sewing...
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
Just purchased a Singer 4423 machine, need more detailed instructions for buttonholes
when you press the button hole option & then pull the button hole lever
down it will rest against the button hole foot, having the button in the
button hole foot help the machine gage the size the button hole needs
to be, if the machine keeps on sewing & doesn't stop automaticily then
there is something wrong with the button hole option.
Jul 18, 2012 | Singer 4423 Sewing Machine
My New Home sewing machine has been in storage for 2 years. When I press the pressure foot, the motor just hums. Can you help me?
try oiling the machine, since you took the machine apart oil it, use only sewing machine oil, usually you can get it at a fabric store or I think wal mart sells some too.
oil the machine,, let it set for a couple of hours,, put paper towel or old towels under neath the machine because of the oil dripping
then try to turn the handwheel back & forth,, putting slight pressure but not heavy,, DO NOT FORCE IT
if it doesn't break loose oil it again & let it set another couple of hours
then try to turn the handwheel again like before
if that doesn't work then get a can of penetrating oil, & use that,, then wait a couple of minutes & try the hand wheel again & after it breaks loose then be sure to oil it again.
let me know if it helps you
Mar 30, 2012 | Sewing Machines
The motor runs on my Singer Merrit 8734 but the needle doesn't move.
if you have to undo the clutch to wind the bobbin, then try undoing the clutch again & then retightening the clutch & see if that helps & if it doesn't help the machine needs to be checked
Mar 26, 2012 | Singer Merritt 8734
Comunication error
At first turn the machine off, and then press the start button, reverse button and auto lock button at the same time.
-Turn the machine back on while still pushing the three buttons. After the machine has powered on, release the buttons.
-Press the + sign at the bottom of the screen, continue pressing each + sign as it appears. The machine will display a "Test Complete" message, turn off your machine.
-Wait 5 to 10 seconds before powering your machine back on, your machine will run through a diagnostic test and repair any issues it finds.
If this doesn't work;
Have you set up communication is to the "COM Port" designation within Customizer/Digitizer.
Go to >ScanCard >Communication Settings > choose the COM Port you want to use (find out what COM port the cable's using by going to your Start/task Bar in Windows>Control Panel >System >Hardware >Device Manager >Ports (COM & LPT).
There, you should be able to see what port your cable's using.
Hope this helps
Nov 03, 2011 | Janome Memory Craft 9000 Computerized...
I have a Necchi 3205 Royal series machine. I was sewing denim and it jambed and bent the needle. I replaced the needle and now it won't pull the bobbin thread up. I have tried several different needles...
Hi, I've got a necchi sewing machine too, not the same model as yours.
you said you were sewing denim & the machine jamed & bent the needle, it's sounds like the machine is out of time, sometime it doesn't take much to get them out of time & would have to be serviced by a repair shop with the tools needed to fix the timing.
Aug 29, 2011 | Necchi Sewing Machines
Janome Harmony 2041 Logo
109 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
