Question about Refrigerators
Bosch classixx KGU30604 fridge freezer alarm indicator light on
The fan is working in the freezer but temp is running too high & not freezing - do I need a new thermostst & are these easy to install?
4 Suggested Answers
namzyanzy
  • 435 Answers
SOURCE: Bosch Classixx Fridge freezer KGU30604 I
Hi Kloynes,
It could be a problem of LEAKAGE.....Followings steps may help you tackle the problem:
Steps
  1. Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
  2. Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Tips
  • Clogs are usually caused when dust, moisture and micro-organisms get together in the drain tube. Keep the dust vacuumed from the back and bottom of the fridge. Make sure the drain tube is firmly connected at all points. The drain tube can be flushed with chlorine bleach, rubbing alcohol or other anti-bacterial product. Product selection should be consistent with the tubing material.
Warnings
  • Use caution with anti-bacterial products. Make sure that any such products cannot flow back into the food compartment.
Things You'll Need
  • Wire hanger
  • Anti-microbial agent such as chlorine bleach, rubbing alcohol or anti-bacterial soap.
Thanks
Posted on Sep 03, 2008
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
heatman101
  • 43501 Answers
SOURCE: Bosch Classixx Fridge/Freezer. Freezer has stopped
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 28, 2010
I have a Bosch Classixx KGV28V01GB fridge freezer. I defrosted it as there was a bog built up of ice in the freezer. I switched the fridge freezer back on today and have noticed that the fridge is not...
it will take at least 48 hours for a large fridge freezer to settle down after a complete defrost,so leave it alone with the door shut,set at you favourite temp....
Jul 27, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Why the red light blinking with audible alarm?
Your temperature alarm is going off as it has exceeded your set high temp.
Usually means you have had a power failure or you have a thermostat, starter relay, compressor or freon problem.
To find out what is happening get a therometer and put in fridge. A fridge / freezer thermometer is best but any will help
May 18, 2009 | Bosch Refrigerators
Fridge too warm
first, verify that the fan is running in the freezer compartment. second check that there is no airflow blockage between freezer compartment and refrigerator compartment. if that does'nt solve the issue verify the defrost system is working.
Mar 28, 2008 | Refrigerators
Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Dec 22, 2007 | Refrigerators
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
