Question about Indesit Washing Machines
My indesit iwe7145 has stopped draining and it has given f05 fault what does this mean
  • 45 Answers
SOURCE: error code on washing machie
The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too.
Posted on Jan 03, 2008
SOURCE: indesit we14
Hi l have a indesir WIE147 that keeps on flashing F 01 repair man came changed module and next day same thing happened again HELP PLEASE
Posted on Jan 17, 2008
SOURCE: Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Posted on Nov 16, 2008
SOURCE: My indesit wixe 127, wont
i think there is a problem with low water level sensor
My 127 fill up with water and i have f-08 error code which is a high level water sensor faulty
Posted on May 17, 2009
barkencoa
  • 3463 Answers
SOURCE: fault code F05 on an indesit washing machine WIXE
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove large black fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hop[e this helps you.
Posted on Dec 28, 2009
Why does our Indesit IWE7145 fill with water but then stop?
sounds like the timer has failed call a repairman
Apr 11, 2015 | Indesit Washing Machines
Indesit pwe 8148 w with error code FO5 Is the problem usually either a blockage or the pressure switch? I am going to try to fix it myself but how do i get to the pressure switch to see if it is stuck on...
Hi.
F05 means that the pressure switch shows full all the time:
F05 - Pressure switch jammed on full
The fault is usually fixed repairing or replacing the pressure switch. Before replacing the switch check for draining issues that can trigger F05 and clean the hose connected to the PS. The PS is located inside the appliance in the control panel or at the right side of the cabinet. The part is reached removing the screws holding the top and lifting the top. Power must be disconnected before starting.
Here how the switch looks like:
Sep 14, 2011 | Indesit W 123 Front Load Washer
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
F05
F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Indesit W 123 Front Load Washer
Dear Sir my washing machine which is one year old started for the last couple of weeks todo unnecessarily noises and also it doesn not drain the water, showing code F05. WHAT TO DO? thank you!
F05 on an Indesit washing machine means "Pressure switch jammed on trip"
As is often the case, knowing the error code is one thing, but findng the cause is another because error codes often have several possible causes. The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too. Finally, the Indesit washing machines PCB's can give erroneous errors where the fault turns out to be with the pcb itself. This makes things very difficult if you don't have access to replacement PCB's to try.
Basically, I would keep an eye on the washing machine and try it again. If it reoccurrs then clearly it needs sorting, but if it doesn't it might have just been one of those things.
Sep 28, 2009 | Washing Machines
My indesit 1300 stops mid cycle and flashes f-05 help
pump blocked take plastic trim off bottom and unsrew filter is main cause or poss pressure switch jammed on full
Jun 07, 2009 | Indesit W 123 Front Load Washer
Fault f05
F05 means pressure switch jammed on full, firstly check that pump is working and that there is no blockage anywhere,
if it still does not work, then you are going to have to call an engineer.
Hope this helps.
Please leave feedback.
Nov 24, 2008 | Indesit W 123 Front Load Washer
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
146 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
