Question about Apple iPhone Smartphone
Cannot detect device
I just bought a i9 phone and neither of my 2 computers can detect it in the USB port. It says unknown device.. Ive been lookin on the internet for driver updates but i cant find any.
  • johnforward Jan 21, 2009
    Yes it happened to me and it was because in hacking the phone's innerds, it triggered a mechanism in the phone that cut off all communication (and charging) to the phone. If you hacked it, and it has been switched, you are basically DOA. You now have a fancy paperweight.
  • 8 Answers
Connect the phone while the computer is off. Power on teh computer and it should detect a new USB hardware device. You should then see two new drive designations. 1 for the phone's memory and teh 2nd for the onboard memory card if you have one installed. Remember for the first connection the computer must be off when you connect the phone.
Posted on Jun 15, 2009
Usb port not recognized
1. try using usb1 port ( instead of usb2)
2. check the Device-manager for USB controllers normality. (or try to upgrade versions)
Nov 15, 2010 | SanDisk Sansa Clip MP3 Player
Cannot print from computer. printer will print test pages, though
How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
If Printer is connected USB than try different USB Cable and try different USB Port on the computer
If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
Oct 16, 2009 | HP Color LaserJet 3500 Printer
Cannot connect to computer
FIRST OF ALL, NEVER EVER PLUG IT INTO THE COMPUTER WHILE ITS ON. ALWAYS TURN THE PHONE OFF BEFORE HAND. AS FAR AS YOUR COMPUTER NOT RECOGNIZING THE USB CABLE, IT MAY ACTUALLY BE YOUR COMPUTER. AFTER ALL IF IT WAS THE CABLE, YOUR PHONE WOULDN'T CHARGE SINCE IT IS THE SAME CABLE FOR CHARGING AND USB CONNECTIONS. MY COMPUTER HAS HAD TROUBLE SEVERAL TIMES WHEN PLUGGING IN NEW OR DIFFERENT DEVICES INTO THE PORT. TO CHECK THE USB PORT ON YOUR COMPUTER.... GO TO CONTROL PANEL, THEN DEVICE MANAGER. DOUBLE CLICK UNIVERSAL SERIAL BUS CONTROLLERS. IF ANY OF THEM ARENT WORKING PROPERLY THERE WILL BE A YELLOW TRIANGLE WITH AN EXCLAMTION POINT BESIDE THE UNFUNCTIONING USB. IF IT IS NOT FUNCTIONING YOU WILL HAVE TO UPDATE THE DRIVER. IF YOUR PORTS, DRIVERS ETC DONT SHOW THE YELLOW TRIANGLE, THEY ARE WORKING. TRY PLUGGING THE PHONE INTO A DIFFERENT PORT UNTIL YOU FIND ONE THAT WILL ACCEPT IT. I HAVE A LAPTOP AND MY PHONE ISNT RECOGNIZED IN THE SAME USB PORT (ON THE RIGHT SIDE OF THE COMPUTER) THAT I USE FOR MY PRINTER. I USE A DIFFERENT PORT FOR MY CELL PHONE. IF YOUR COMPUTER IS OLDER , THE USB PORT MAY NOT BE HIGH SPEED. OLDER COMPUTERS HAVE USB PORTS WITH A SPEED OF 1x OR A MIX OF PORTS WITH 1x AND 2.O (2.0 IS HIGHSPEED 1x IS NOT). I HOPE THIS HELPS!!!
Jun 23, 2009 | Dual Electronics CECT P168 Cellular Phone
Settings for MTKTB DEVICE i9 phone internet settings
There is a i9 manual with GPRS settings here. They also have Internet settings for many providers. Just ask them for it.
May 31, 2009 | Dual Electronics CECT P168 Cellular Phone
My nokia 6500 slide is not detected on my p3 processor computer
hi ,
on your p3 laptop/desktop go to the device manager and update usb drives (DO NOT CONNECT your phone). Before that uninstall pc suite. Then reinstall again.And follow the on screen guide how to connect the phone.
Apr 11, 2009 | Nokia 6500 Slide Cellular Phone
I've bought a USB 3RCA data cable to project video from my Laptop to me TV/projector. However it doesn't work, and no signal appears to be received by either TV or Projectors... USB 3RCA Cable from PC...
i hope that is a USB driver issue when u plug your device does your computer detect any usb device and then its says unknown/unrecoginzed device. You have to check the cables first then you download USB2.0 driver install it inyour computer andl aslo try to connect the device in another port also put the the driver cd for the TV/projector
Jul 02, 2008 | Computers & Internet
USB ports not working
Looks like it is a problem with those ports since you bought the computer.
Pls take it to a local tech to diagnose the problem or contact Acer Tech Support
Feb 13, 2008 | Acer Aspire 9503EWSMi Notebook
Sync Manager Problme with Vista with LG CU500
The problem is a driver issue. It is strictly a LG/Verizon problem, and not Windows. What you should is hook up your phone your computer LG USB cable and using the Music Essentials CD-ROM.
Install the latest version of BitPim where  you can find at http://www.bitpim.org/ .
"I hooked up my phone to my computer via the USB cable, and opened BitPim. Much to my dismay, bitpim did not find the COM for the LG Modem".
However, Vista popped up the window in the taskbar telling me that new hardware was detected but could not be installed. I went to Start > Search > Device Manager
Once the Device Manager is opened up, you should see an unknown hardware profile for the USB cable/phone. In my case, Vista seemed to recognize the fact that it was a LG USB Modem, but didn't have the driver. Anyway, right click on the unknown driver and select "update driver software." Surprisingly, Vista will tell you it found a driver. Unfortunately, when when you go to install the driver 2 new unknown drivers will appear.
To fix the 2 unknown drivers, all you have to do is insert the VCAST Music Essentials disk into your disk drive, and point Windows in the direction of the files for the drivers on the VCast Music Essentials CD (in my case, the D: drive).
Windows finished the install, and from their BitPim recognized the cable on COM5.
That should work.
Jan 22, 2008 | Cell Phones
Motorola V3i won't connect to the computer, even with a USB cable.
is the phone on ??
if the phone is off the pc no detect this
pres on butto with the * and # buttons.. then tyhe phone is in the flash mode...
the pc may detect this..
excuse my bad english
victores from cuba
Jan 12, 2008 | Motorola Mobility RAZR V3i Cellular Phone
All sansas
Update your USB drivers?
You could try putting the Sansa's in MSC mode.
Depending on your Firmware there will be a USB option under settings (Under USB it might be on Auto just select MSC)
OR you will need to
1)have the player on (but not plugged in)
2)push the HOLD switch tot he right (towards the REC button [see orange in the hold slot]
3)HOLD DOWN the |<< rewind button (keep this held down)
4)plug the cable into the Sansa (assuming the other end is in the USB port)
Wait till you hear it detect it..
If it still does not..
CHECK the Device Manager to SEE if their are any unknown devices under USB unplug the Sansa
Delete the unknown and try steps 1 thru 4 again.
If you do not know how to get to Device Manager then you will need the help of someone who knows these types of things to show you or look this up on the internet.
Dec 09, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Apple iPhone Smartphone Logo
137 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
