Question about De'Longhi Dem10 Dehumidifier
Why is the orange light on? - De'Longhi Dem10 Dehumidifier
Our dehumidifier seems to be working fine but the orange light is flashing above the star mark
When an error occurs, the Alarm lamp flashes orange. Check the status of the lamps, then take the appropriate action in Alarm Lamp Flashes or ON Lamp and Alarm Lamp Flash Alternately.
Jan 10, 2017 | Dehumidifiers
Dehumidifier will not start
You emptied the tank, right?
Sep 02, 2014 | Maytag Dehumidifiers
The orange full light is flashing, but the tank is empty, but no other light is on and it does nothing, i keep pressing buttons and nothing
This problem is usually caused by an improperly installed water collection bucket or the float valve inside the top of the bucket is broken or stuck in the DOWN position.
To troubleshoot this, turn the unit OFF & unplug it. Remove he bucket, check the float valve's position. If it stuck in the UP position, jiggle the handle to make it return to the DOWN position. This will also allow you to determine if the float is broken. If all this checks out, reinstall the bucket "squarely" from top to bottom into the bucket holder. It must make contact with the bucket safety removal switch on the back wall of the holder. When installed properly, the bottom of the bucket will not tilt down at all. Plug the unit in and turn it ON. If everything was done correctly, the unit should start within a few seconds.
Hope this helps you to troubleshoot and solve the problem. Thnanks for choosing FixYa.
Aug 16, 2011 | Maytag M7DH65B2A Dehumidifier
My dehumifier has an orange light by the picture of the fan. What do I need to do?
Empty the water collection bucket. But, before you do, turn the unit OFF & unplug it.
Jul 12, 2011 | Danby Dehumidifiers
The dehumidifier drain hose does not drain when a hose is connected properly and is set at ``Continous Run``.The light on Continous setting is orange,is this normal? Raymond Benoit
http://www.searspartsdirect.com/partsdirect/part-number/Whirlpool-Parts/Dehumidifier-Parts/1172075/0042/106/Model-AD25BBK0/1198/0907000?keySuffixId=NA&productTypeId=x&searchModelNumber=AD25BBK0&subCompDesc=Cabinet&brandDesc=WHIRLPOOL&modelDesc=DEHUMIDIFIER&blt=11
I would suspect the float first, IF the unit is level. But it could also be blocked with gunk and you will need to check the drain holes. I have always found a guitar string is an affective clean out of drain lines and holes.
The orange light indicates that your bucket is full, so if it isn't then it is most likely the float above.
Jun 19, 2011 | Whirlpool AD25BBK Dehumidifier
What is the blue light for and what is the orange light for
You need to rewrite your problem and include the model and brand of your dehumidifier so we can be specific
Jan 19, 2011 | Dehumidifiers
Unit is on fan not running
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Mar 31, 2010 | LG LHD45EL Dehumidifier
We have LG65 model dh5018 that froze up and now doesnot want to work
if you carefully examin the compressor/motor, there should be a small red or orange button on the side of it. Or it may be inside the the terminal box.TURN OFF POWER BEFORE YOU START!!!
press the button in firmly and you shoul feel or hear a click.
That is the motor protection 'overload".
once pressed. close it all up and turn on power.
Feb 02, 2010 | LG Dehumidifiers
Bad fan motor on DH504ELY5?
problem fixed with the fan motor not running.
heres how i did it for anyone who experiences the same problem
1.) open back of unit(6 screws and pop tabs)
2.) with back cover open youll have access to compressor and fan-locate the blower assembly and remove the nut on it i used a 3/8 wrench from dollartree and rotated the blower fan while turning-its plastic be careful and remember righty tighty lefty loosey)
3.) with fan assembly off youll see the motor with 2 phillips head screws-taking these screws out with a power screwdriver allows the bearing assembly closest to the fan assembly,shaft,armeture and motor assembly to come out leaving rear bearing assembly attached to chassis
4.) once the motor assembly is completely out gently rest it against the fan hole and cut the silver tape being careful to ONLY cut the silver tape and the first white tape strip.
5.) youll see 3 wires and some insulator sleeves covering them leave everything alone except the ORANGE wire this wire attaches to the thermal fuse than to the windings
CAREFULLY heat up your soldering iron and remove the orange to thermal fuse connection than carefully thermal fuse to windings its a bit of a pain but can be done with patience
6.) remove original thermal fuse noting EXACTLY where original is placed on windings-it will have a small tape strip on it. replace it with one of EXACT OR NEAR THERMAL RATINGS a good choice is radioshack 270-1322. this thermal fuse is ratyed 10 amps max. but remember thermal fuses go by degree of heat and not by amp rating unless the amperage is in excess to melt the thermal material inside-my original fuse was 2 amps and 130 degrees celcius new fuse was 129degrees but plus minus 2 degrees so its a good choice and costs under 2 dollars
7.) place a heatsink clip or needlenose pliers between thermal fuse and solder connections BEFORE YOU SOLDER IT IN PLACE this prevents your 700 degree f iron from melting the fuse(remember its thermal not amperage were talking about here)
solder orange to thermal fuse with plastic extension than flat end to winding wire exactly opposite of how removed
8.) tape fuse in ORIGINAL LOCATION AS OLD FUSE i used scotch tape,place the thermal white protector piece on orange to fuse wire and push everything back down in original places-there should be no contact with any other wires etc. it will cause a fire
9.) once fuse is in place push tape you cut earlier back on and put 2 or 3 small scotch tape pieces of good length to secure the innards, lube the rear bearing of motor using vasoline- a few dollups will do it do the same for front slide motor winding assembly holding it in place than replace armeture with front bearing attaches as they came out secure the 2 screws back in place, put fan blade assembly back on(its keyed) secure nut and reassemble back
if you did everything correctly it will work like new just remember this time CLEAN YOUR FILTER SCREEN REGULARILY lol its critical for proper fan cooling
that should do it:)
Aug 20, 2008 | Goldstar DH504EL Dehumidifier
Fan not working
THE FAN MAY OR MAY NOT HAVE OILING PORTS ON THE MOTOR. IF NOT, THE MOTOR NEEDS REPLACED. IF THERE ARE OILING PORTS ON THE FAN MOTOR, TRY SPRAYING SOME WD-40 IN THEM AND THEN ADDING SOME LIGHT MACHINE OIL TO THE MOTOR. THE OILING PORTS ARE SMALL HOLES AT EACH END OF THE MOTOR WHERE THE MOTOR SHAFT EXITS THE MOTOR HOUSING.
Mar 22, 2008 | Kenmore 54501 Dehumidifier
De'Longhi Dem10 Dehumidifier Logo
74 people viewed this question
Top De'Longhi Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a De'Longhi Dehumidifier Expert? Answer questions, earn points and help others
