Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Replacement of ic mcz 3001d with equivalent ic
2 Suggested Answers
  • 139 Answers
SOURCE: I have a Sony KV-32S20 32
you first must verify you have horizontal deflection. do the crt fillaments light up? if they dont you probably have a shorted horiz. output transistor short or a bad solder joint in the drive circuit. i would solder this anyway it is a common issue. it can blow up the power supply if it fails. if they do light up turn up the screen control, the bottom control on the flyback transformer, do you have a flat vertical line? if so you lost vertical deflection. that could also be a bad connection on the ic or it failed.
Posted on Dec 28, 2009
Acer aspire 5315-2153 has a power problem caused by wrong adapter, the 3 ics on intel celeron board have got burn't. Can you send me the equivalence of the 8 legs Dip ic that i can buy in the market to...
The numbers on the IC's are what you need to use to order replacements. Generally, there are no equivalents available without knowing the numbers on the faulty IC's.
Dec 30, 2013 | Computers & Internet
I have Sony KP-46WT510 46 ,when i turn it on,it blinks 10times,sound is there but no video,engineer told sjort of ic no.3001d,where to find it in india,plz help
they have the repair kit for the 10 blink error at the following link it comes with instructions shipping to india may be a little higher than US orders.
http://tvrepairworld.com/sony_repair_kits
Mar 01, 2013 | Televison & Video
Standby light is blinking 9 times. what does that mean and what should i do about it?
You have a bad MCZ. Try taking a blow dryer to the right side of the TV to see if this fixes the problem.
http://cgi.ebay.com/LOT-2-MCZ3001DB-IC-SOCKET-MCZ3001D-670581001-/220499156868?pt=LH_DefaultDomain_0&hash=item3356c61f84#ht_1871wt_1020
You will have to find these and replace them both on the board to the most left of the T.V. There are two of them. The one closest to the back of the T.V. is probably the problem.
Jun 20, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
7 blinks
There's a bad MCZ ic. It's got 10-12 legs. There are 2 of them. It's the one located closest to the back of the T.V. You can heat your T.V. up to get it working again using a blow drier until you can get it repaired.
May 06, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
My Sony KP 51W520 won't come on. The standby light flashes 10 times. I read through the other people's problems listed here and everyone else has had either 3 blinks or 9. Any thoughts?
Hi.
it seems that your power supply or high voltage section is failing. Look for PWM IC genarator. MCZ 3001D on Power supply and near high voltage section. Try to replace these IC's.
Jan 05, 2011 | Sony KP-51WS520 51" Rear Projection...
I have a Sony KV-32S20 32" TV and the red standby led flashes constantly. From what Ive read does that mean an an I.C. tv chip # mcz 3001d is bad? I also read that replacing the R-536 with 1 ohm resistor...
Dec 28, 2009 | Sony KV-32S20 32" TV
My Sony Wega KV36XBR800 has no picture or sound, Stand by light blinks 6 times, then paus, then again 6 times. Please help. Thanks Sometimes it blinks 7 times.
ur tv chassis is DA-4 and IC 8002 is no good that is MCZ 3001D.
carefully de-solder and take IC out.
recommend use 18 pin ic socket, so u can push new IC in instead of soldering- fast and easy. do it ur self save $300. happy?
Aug 12, 2009 | Sony Televison & Video
Need equivalent IC
i made programmer for 89c51. in this use ic ds275. i want know what is the equivalent ic of ds275.
Aug 10, 2008 | LG F-185 CD Shelf System
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
173 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
