I have an older onkyo receiver that when the on button is pressed it will come on then immeadiately shut off with an audible clicking sound
  • 119 Answers
It's letting you know it's over time for a new reciever
Posted on Feb 25, 2009
ONKYO TX-SR307. Problem with volume/sound getting lower. "Setup" does not alter / resolve the issue. Please help
Hi, if this has not been resolved please try the following reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings, Thanks, JT
Mar 02, 2015 | Onkyo Audio Players & Recorders
My onkyo tx-ds575x lost power in a storm and now I get no audio from it. The sony bravia tv has sound but the onkyo won't send it to the speakers.
Please reset Onkyo receiver that will solve noisy sound problem, to reset the receiver, press and hold Video-1 button on unit and press Speaker-A button. Display will show *Clear* that means receiver has been restore on default settings, turn it On and check sound.
Hope this will help.
Thanks.
Apr 06, 2011 | Onkyo Audio Players & Recorders
When power button turned on, receiver powers up
I have had the same problem with my new Onkyo HT-S 5305B (A/V Receiver + 5.1 speakers). To solve this, try to follow "Troubleshooting" guide that came with your system. I followed it 2-3 times. In my final attempt, when system was not shutting down but stayed-n with no sound, I played with the setup and tried changing audio adjustment, input, dimension etc. and slowly I was able to get speakers up one after the other. It's working fine now.
However, I am little concerned that why such a high-class Onkyo system failed in less than two days, forcing me to troubleshoot. - Apurva
May 10, 2010 | Onkyo TX-SR500 Receiver
I have an onkyo tx-sr506 and the system shuts off as I turn up the volume. It doesn't get very loud (barely audible) before shutting off.
Check speakers for distorted or dead drivers . Disconnect and repair. receiver will blown if not disconnected.
Mar 15, 2010 | Onkyo TX-SR506 Receiver
My Onkyo Tx-Sr700 sound is not working. I have speakers connected for surr. sound but I can't figure out what buttons to press to turn them on for tv. Tv is video 1
make sure you have audio cables connected from your cable providers audio out to your receivers audio in on video 1 press the video 1 button you should hear the sound.
Oct 16, 2009 | Onkyo TX-SR700 Receiver
Power on but no tuning or sound from other sources
Check for "Tape Monitor On" button. According to Onkyo's web page "Press and hold the tape button for two seconds allows the tape and MD sources to be switched - Also try the speaker A/B switch. - Check back for further assistance - The web page for your operations manual can be found at...
http://www.us.onkyo.com/download/own_manuals.cfm?cat=Receiver
Then select your model.
Hope this helps
Len
Mar 02, 2009 | Onkyo HTR500 Receiver
Code for Verizon FIOS remote Control
I have a solution which has worked well for me. It uses the DVD button at the top of the remote. It was a trade-off as none of the codes in the RC144 Philips remote will work any Blu-ray players, so the DVD button was unassigned. The 922, 955 and 977 codes are explained in the directions for the FIOS remote. http://onlinehelp.verizon.net/consumer/bin/pdf/philips%20rc1445302%20user%20guide.pdf
1. Set up your TV button to work your TV.
2. Set up your Onkyo code, pick one to turn on the receiver. I used 3719
3. Use the 9-2-2 code to cycle through all available codes. At about a count of 300 I found one which will turn the Onkyo receiver off. Make sure you start this process with the ONKYO receiver already on. Once you find it press the OK button.
4. Use the 9-7-7 code to power all devices TV, AUX and DVD from the power button.
In this way, each time the power button is pressed it will send both the power on and power off signal to the ONKYO receiver.
This technique works well when you point the remote at the ONKYO receiver and press power button. Apparently the TV has better reception for the signal then the ONKYO does.
Oct 24, 2007 | Onkyo TX-SR605 Receiver
No Sound
Called Onkyo and here is the solution they gave me.
1. Turn on unit.
2. Press and hold VIDEO 1 button.
3. While pressing VIDEO 1, press Speaker A button.
4. You should see "CLEAR" on the display for a second and it will go on stand-by mode.
5. Turn on the unit and check if sound is back.
Hope this helps
Mar 30, 2007 | Onkyo TX-DS575 Receiver
Onkyo receiver
It sure dosent sound good!! The clicking sound you here are the protection relays to assist in protecting your speakers from blowing out. Your output devices are shorted it sounds like. Do not ever ever attemp to jump out those relays as it will burn out your speakers and possibly burn down your house!. Theres alot of current inthese amps for high power so if your not a tech and you think its worth it take the unit in to be looked at as there are no serviceable user parts inside these units . Sorry to have to tell ya this.. Good Luck
Jun 05, 2006 | Onkyo TX-DS575 Receiver
 Grubhead
Grubhead
