Question about Apple iMac 24inch 2.8-3.06GHz Early 2008 Audio Board Part 922-8466
IMac 2008 wont turn on - Apple iMac 24inch 2.8-3.06GHz Early 2008 Audio Board Part 922-8466
IMac 24 core2duo 2.8 (A1225) early 2008. Got one without HDD. I put in a new 2.5 HDD and tried to fresh install OSX 10.8. Everytime after about 8 minutes in installation process the screen goes black and...
Now what did the Thermal Paste have to do with the swapping in a new Hdd. You've now added another variable to the equation before solving the first problem, getting it up and running. Grab another Mac and put the iMac in Target Disc mode, firewire the two, use the USB drive with 10.8 and install it on the iMac and see how that goes.
Nov 03, 2013 | Computers & Internet
Tip
If your problem is due to a hardware fault, the following site was very useful...
Check here - http://docs.info.apple.com/article.html?artnum=306857
EB
on Jul 25, 2009 | Apple eMac G4 Desktop
My imacs screen wont show up what do i do?
get an external monitor and the correct dvi adapter and plug it in to te back and turn it m Make sure that in the >System Preferences>Displays you have mirroring turned on then you should be able to a least use your mac. My sister had the same problem this solved it somewhat She hides the iMAC behind the new screen. Only other solution would be to take the iMAc in and probably have the display board replaced which would cost you more than the new screen. You will still have the new screen to put on a new computer and use it as a second display.
I have two 24 inch displays on my computer
Oct 21, 2012 | Apple iMac G5 Desktop
My imac g5 wont turn on at all! what can i do?
First, you should make sure you you have power to the iMac. Next if you checked you don't have power the iMac and you do, you could bring it to an Apple Store near you so they can diagnose it. Note, " I pretty sure they could diagnose it." Then if they know what the problem is, you could buy the parts needed from sites that have them and replace the faulty parts. You might be able to find how to replace the parts on www.iFixit.com. If this isn't what you are looking for you should probably clarify your qustion because the question has tons of possibilities. Hopefully this can help!!!!
Note: The Apple Store people might be able to fix the iMac for a price.
Mr Fixya533
Feb 07, 2011 | Apple iMac G5 Desktop
Why wont the screen turn on on Apple iMac m5521 Desktop?
Usually a problem with what is called the video up board, there was a firmware snag going to OSX from 9 but that was long ago.
Jan 04, 2011 | Apple iMac G3 15" M5521 Desktop
IMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
If it only boots to a blue screen, try booting up in Safe Boot mode:
http://support.apple.com/kb/ht1455
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
http://support.apple.com/kb/ht2956
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
http://support.apple.com/kb/ht1710
May 18, 2010 | Apple iMac G4 Desktop
My imac wont turn on!
It sounds like something is either corrupted on your system or one of the files in your imac may be suspect. What I would suggest is get your system disc boot the imac down holding down the c key on your keyboard. Once it is booted up go to the file menu and find the disk utility. Open up the disk utility and first of all repair your disk permissions and then run disk verify and if an error comes up choose to repair it.
If this does not work. I would suggest installing a clean system. Again with the system disk in your computer restart your machine with the c key held down on your keyboard. Choose to do an install but remember to select preserve users. This will give you a clean instal with your files and preferences intact.
Once your machine has restarted it is well worth setting a second account under system preferences under accounts as if one account becomes corrupt in the future you have a second account to fall back on.
For prevention of any problems in the future I would download Onyx from this website http://www.switchingtomac.com/tutorials/keep-your-mac-running-smoothly-with-onyx/ which also talks you through the method of using it. I use it every month just to keep my mac in tip top condition.
Hope this helps.
Apr 03, 2010 | Apple 24" iMac Desktop
I am attempting to transfer Quicken 2008 qif files to the new IMAC, I just purchased. I made an export file...the IMAC only has Quicken 2007 installed. I have been unable to locate a 2008 or 2009 program...
go to this site for some gray tips on how to perform this:
http://www.google.com/search?q=how+to+transfer+Quicken+2008+qif+files+to+the+new+IMAC&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Aug 28, 2009 | Computers & Internet
Imac question
Try turning it on with the shift key down. This gives a safe boot. If it's going to turn on at all, it will turn on then. Also, boot it with Disc Warrior or Tech Tools and run some tests to see what is going on. I hope you find all is well, and that the repairs are just minor. Good luck.
Sep 19, 2008 | Apple iMac G4 Desktop
IMac G5
you need to contact apple support for the same
Jun 23, 2008 | Apple iMac G5 Desktop
Apple iMac 24inch 2.8-3.06GHz Early 2008 Audio Board Part 922-8466 Logo
23 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
