Question about Refrigerators
LG Refrigerator model LFX 25980st repair manual--need one
Would like to purchase a repair manual for above refrigerator
22yooper
  • 828 Answers
SOURCE: LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
Posted on May 19, 2008
SOURCE: LFX 25950TT problem
Just had this same problem. We were away at Disney for four days - turned the icemaker off before we left. We have the LG french door double drawer freezer model. Came home, the ER IF code was displayed. Wouldn't dispense water or ice. Took the icebox out, and it was all frozen in the augers. Then I read on the door something to this effect - "if you turn off the icemaker, it will not continue to cool the ice. This will cause the ice to melt and leak out of the unit, and when it refreezes, the dispenser will not produce ice or water."
So, I took the ice box out, emptied it, reinstalled it, and the unit os making ice and dispensing water as I write.
Again, if you turn off the icemake, empty the ice box, or you will get the error message when you start the ice maker again.
Posted on Dec 25, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Need owners manual for LG Refrigerator
Your manual can be found and downloaded in PDF format. Hope this helps, Thanks, Sea Breeze
Click link below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Feb 26, 2009
  • 363 Answers
SOURCE: replacement instructions for ice maker in
I have found service manuels at appliancesfactoryparts.com
Posted on Jul 17, 2009
SOURCE: Error message on LG Refrigerator
The message is ERROR ICE FAN. You can order a new one from LG for around $65 and if you know someone handy they can probably put it in by just eyeballing the old one. WARNING>>>>this must be someone with common sense and some degree of problem solving skills as it does not come with the fan blades and that must be switched. This is a common problem with this model and usually the ice fan goes out in about 12-20 months. Use your owners manual to figure out how to get the door off and access the fan. Also, Lg employees are confused and may try to tell you there is just one fan......they did tell me that!
The ER IF is part # 46811B1029E---The ER FF (freezer fan) is part # 4681JK1004E and only a skilled repairman can modify them to be interchanged.
Posted on Aug 31, 2009
LG Ref/Frzr LFX 31925st ERROR CODE ER 1F NEED MEANING AND FIX
A F1 or 1F error code on the refrigerator's display indicates a problem with ice blower fan or ice maker motor.
search LG error 1f and u will find lots of info
Dec 09, 2016 | LG Refrigerators
Whst temperature do I set LG LFX 31945ST
Hey Rosalie,
The lower the temperature the better but do not operate to the extreme.
  • I would set the freezer between 0 and 7 degree F
  • The fridge between 34 & 37 degree F
  • Adjust Temp if necessary.
Here is a link to the fridge manual.
Good Luck!
JP
LG LFX31945ST Owner Manual
Jul 19, 2015 | LG Refrigerators
LFX 28978 LG French door refrigirator too warm, frost in the back of freezer
call for service, could be a computer board, fan motor, or defrost system. cheaper in the long run to call for service
Apr 30, 2012 | LG LFD25860TT Titanium French Door...
LG LFX25960ST refrigerator food freezing above the pantry draw. Made all the tempature adjustments and still happening.
I have the same problem and I know the solution.
For LG to get their "in the door icemaker" to work, they have to blow cold air into the door's icemaker compartment. This air travels through two vents located just inside the refrigerator on the left side. The problem LG has is that the seals between the door and the refrigerator for these vents leak. This means that cold air is vented into the refrigerator compartment. Any sensitive food placed on the bottom two shelf on the left side will freeze. I can place two bowls of water in my refrigerator and make ice in 6 hours, even though the refrigerator is set to 38 degrees. The good thing is that LG knows there is a design problem and they know they can not fix it. After calling LG repairmen out for my freezing problem and not getting the seals fixed, LG gave up. Of course LG will try replacing the seals, and then replacing the door; but the real problem is a bad seal design. Just keep putting bowls in your refrigerator and as long as they continue to freeze up, keep calling LG back and demand that they fix the problem. LG can not fix the problem because it is a bad design, so now I am getting a new refrigerator Model LFX 29927, which is better and has dual icemakers. If you an LG refrigerator with their in the door icemaker, place two bowls of water inside the refrigerator, and if your seals are bad and they freeze; complain to LG until they give you a new refrigerator.
Nov 10, 2009 | LG LFX25960ST Stainless Steel French Door...
Water is slowly trickling out of water dispenser
This is usually because the water filter on the supply line needs replacing.
If it has not been replaced within 6 months, then this will probably cure it.
Thank you for using Fixya,com
Aug 05, 2009 | LG LFX25960ST Stainless Steel French Door...
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
LG LFX 25950SB, the Ice Maker is not working, just hear a click
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
klh
Feb 22, 2009 | LG LFX25960 Bottom Freezer French Door...
Dec 07, 2008 | LG LFX25960 Bottom Freezer French Door...
Long scratches on my LG Titanium refrigerator door. Is there a way to fill or buff out?
Unfortunately there is no way to fix this problem. The doors can't be "buffed" out to repair scratches. The only way you can fix scratches on the refrigerator is to buy "touch up paint" from LG and it is only for the sides of the refrigerator. To fix this problem you will have to purchase a new door. You can call LG Parts Dept. 888-393-6484 to purchase this door.
Apr 28, 2008 | Refrigerators
LFX 25950TT problem
Apr 08, 2008 | LG Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
