Question about Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver
How do I change the view on the projecting time, so it is facing the right way when I look at it on the ceiling?
How do i set the two faces of a rotary relelation watch
What happens when you pull out the button when viewing the white face?
May 26, 2014 | Rotary Revelation Reversible Black/White...
How do i reverse the upside down screen
You turn the unit upside down.
http://support.dell.com/support/edocs/acc/2300MP/en/usage.htm
Go to the menu.
Go to management.
Go to Projection Mode.
Front Projection-Desktop: If you want it to project right side up off a table.
Front Projection-Ceiling Mount: If you're hanging it off a ceiling.
Jun 24, 2011 | Dell 2300MP Multimedia Projector
I want to hang it on the ceiling face down, but the it projects upside down!
almost all projectors have a menu setting to allow the image to be flipped when ceiling mounted. Be careful not to confuse this with the rear projection setting which it is also likely to have...this makes a mirror image.
Just go in to the menu using the remote or the buttons on the projector and you will find a setting in there
Apr 05, 2011 | Optoma TS400 Multimedia Projector
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
How can i flip the screen up side down on the projecter
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Or you can hold down the [A/V Mute] button for about 5 seconds to change the projection setup from Front to Front/ceiling or Rear to Rear/Ceiling.
Mar 31, 2010 | Epson EMP-S4 LCD Projector
Upside down picture how do you invert the images projected
Go to menu and select images and click arrow left or right to invert image position.
Mar 21, 2010 | Eiki LC-XB20 Projector Multimedia...
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Skyscan 34202 Projection
I doubt there is a way to change that, but it's also not clear which way it's supposed to go anyway.  Mine projects "right side up" if you are facing the same direction as the clock is facing - that is imagine you are looking away from the face of the clock.  It is upside down if you are looking at the clock's readout.  One way to solve the problem would be for you to turn the wheel of the projector to make it face the opposite wall.  It will then be right side up.
Oct 11, 2008 | SkyScan 34202 Clock Radio
Optoma EP721 - reverse image
Go to menu, select Projection and choose your desired projection scheme (Desktop, ceiling mounted, behind the screen, etc.)
Jun 03, 2008 | Toshiba TDP S3 Multimedia Projector
This tv has been a nightmare, its been down 3 times in 4 years.
The convergence board, AA95-01799G is available from http://www.samsungparts.com for about 122 bucks + shipping. You also may need to get the service manual so you can do the convergence alighnments with this set when you replace the board. You will also need the manual to perform the perfect focus alighnment on this set if you have that feature. Good Luck
Mar 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver Logo
15 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
