Question about Amcor Dehumidifiers
Amcor Dehumidifer TC120 - Circuit Board Required
Help Does anyone know where I can get a replacement control PCB for my Amcor TC-120 Dehumidifier. I am told they have gone out of business so cannot contact the supplier. Thanks
  • Andrew Jan 23, 2013
    I have now found a supplier of replacements, but not fitted it yet.
    www.bluecooling.co.uk/
  • TheWord Mar 09, 2013
    I have the same clicking problem. Replacement relay alone didn't fix it. Did the replacement board work for you?
It is not your relay. Mine did the same and the problem is the resistor that drive it goes short so the relay clatters as the circuit is trying to control it. The actual fault is the 78p153sp driver. You can change the transistor, a pnp will do the trick but the driver is dead. I'm currently looking for this IC and they're hard to find, cheap Chinese tat. So instead I'll likely fit a temp sensor that detects when the cooling coils reach about 4deg and switch the fridge off because shorting the relay will just cause the cooling to stay on and you'll get ice, it needs to cool, collect moisture, switch off, warm up and dump the moisture...crude but it works. This unit is worth saving.
Posted on Jan 29, 2013
My unit is clicking due to fault with motherboard. friend local agent said replacements not available but said he thought the relay had failed. friend is going to replace the relay for me. there are threads on line that suggest that this will fix the problem. we will see!?
Posted on Jan 23, 2013
Fan not operating, believe the mother board needs replacement, where could I purchase one for Amcor Dehumidifier Model # AHD-65E
Unfortunately, you will be hard pressed to find parts for your Amcor Dehumidifier. This British Manufacturing Company of electrical household goods went out of business 03/11/2009. Although, there are some of their appliances are still on the market, you can rest assured their warranty is useless.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Sep 19, 2011 | Amcor Dehumidifiers
How do i know if dehumidifer is is low on freon not taking much water out of air
Hi, Usually if it is low it will start to freeze up but if you have a freeze control unit then the compressor just won't run much...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 19, 2011 | Soleus CFM-40 Dehumidifier
My amcor dehumidifier tc120 has started clicking recently and now its out put is poor the unit is used in a cellar just to keep control of humidity it works 24/7 then has few days off when full untill i...
heatman101
Jan 17, 2011 | Amcor DC930 Dehumidifier
My Amcor TC120 has started to make a clicking sound when its on which it never use to, does anyone know what could be wrong with it and how I fix it?
mine has also started doing this as well now its working poorly and having taken back of the unit is iced up and iam defrosting it to see if it makes adifference it might be the auto defrost is not working hows yours doing since you posted in oct
Oct 16, 2010 | Dehumidifiers
Tubing to drain the water into the container for the Amcor TC 120
take a sample piece of tubing to a home improvement,hardware,or appliance parts store to match it up.
Sep 29, 2009 | Dehumidifiers
I have no instruction for my gold star dehumidifier. please help me
My dehumidifer is 6 years old. I lost my instructions. Do not know how to set for normal control.
Thank you.
Bonnie
Jul 31, 2009 | Goldstar DH304 Dehumidifier
Dehumidifer runs for about 45sec to 1minute and then shuts off. wqhat would be making this happen
If it does that consistently, then it's likely that the compressor is overheating and shutting down. (It has a thermal overload circuit to prevent a potential fire). Another cause could be a malfunction of the control circuit board which runs all functions of the unit. To check for possible compressor problem, unplug the unit, remove the housing to expose the compressor, plug it back in and power it up. When it shuts down, feel the compressor. It should be warm to the touch, but definitely not so hot that it singes your fingers.
If you find that the compressor is just normal warm, then the control circuit board is shot and needs to be replaced. Check with the merchant or manufacturer for availability & cost. If prohibitive, you're better off simply replacing that unit with a new one.
Jun 10, 2009 | Goldstar DH304 Dehumidifier
Where, in the UK, can I obtain Amcor replacement parts?
the thermal break is there for a reason, the motor has overheated, if this was due to a towel or other item covering the unit great remove the the obstruction and replace the thermal break. however the major cause is that the bearings have dried up on the motor and it has started to seize, which means replacement.
Mar 31, 2009 | Amcor MD250 Dehumidifier
Dehumidifier Error?
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
May 29, 2007 | LG DH504E GoldStar Dehumidifier
Dehumidifiers Logo
369 people viewed this question
Top Amcor Dehumidifiers Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you an Amcor Dehumidifier Expert? Answer questions, earn points and help others
