Question about Magellan RoadMate 700 GPS Receiver
Intermittent Hey Gus, I posted this in april and only got a rant againsy Thales and the French. Can anyone help me with this?? Unit is suddenly intermittent. Sometimes OK, sometimes can't get beyond final blue screen. Did read many posts and have accessed secret menus: have reset data. Have also run test on hard drive whichreads ok. Do hear a slight rattle when shaking unit (haven't dropped it) Suggestions
  • John Bulcroft Jun 30, 2007
    Took it apart as directed. Chip was OK. Found nothing else loose. Put it back together. Still heard slight rattle -- RF cable on case???
    Tried out unit and so far is working fine. Gremlins, natural perversity of inanimate objects, who knows??
    Thanks for hel --- I think.
    Novelist:
    Scholar:
  • 86 Answers
Rutabaga, The most common reason for intermittent power is a small IC chip on the backside of the I/O board which is attached to the rear housing of your unit. If your unit's warranty has already expired I would recommend the following. This is at your own risk. Grounding yourself is recommended. 1. Take off the antenna by rotating it as far counter-clockwise as possible (all the way up) and pull it off. 2. Take out 4 screws 3. Hold both front housing and rear housing with and gently pull the two housings apart. Once it's barely opened unplug the RF cable attached to the corner of the main board. It will either be gray or black depending on when it was made. 4. The other end of the RF cable is connected to the I/O board attached to the rear housing. This is the board that has the small IC chip that rubs against the rear housing which causes it to come off. 5. There are 6 or 8 small screws holding the I/O board to the rear housing. Remove them. 6. Once you got it off, look at the back. On the bottom backside of the I/O board next to the metal heat shield there should be 3 small IC chips. The lowest one is the one that rubs off. If the IC chip is present try looking at it through a magnifying glass and even push it a little bit to make sure it's not loose. If the IC chip isn't there, then look around for that rattling piece. (Either way I suppose look for the cause of the rattle) Soldering: If you find that the IC chip is loose, then you will need to solder it back on. This is not a lead-free unit therefore you can use lead. If you do not feel comfortable doing this, then atleast you have found the problem and can take it to an electronics shop for them to solder it back on. If you feel comfortable doing it, then by all means knock yourself out. If you have any further questions then please ask before proceeding. -Daniel
Posted on Jun 29, 2007
Jet stops and water comes out of main unit
water usually only comes out of there if its hot or damaged. if water is hot its ok, check for temperature anomolies, if water is not hot replace temperature relief valve
Feb 27, 2014 | Garden
Vehicle Stall - Ford Focus X Reg
I will suggest some cheap areas to try first.
1.Wiring connections to your computer under the dash.
2.Check wiring to fuel pump.
3.Check black boxes under hood. They have relays and terminals may corrode.
4.Ignition switch, sometimes with heavy keychains the contacts can loosen.
Take it to Autozone or Oreillys for a free scan. When you say car cuts out, does anything work like lights, horn, radio? Please post symptoms and if anything has helped you.
Sep 21, 2009 | 2000 Ford Focus
Gas range igniters won't shut off
The problem that you're describing is commonly associated with the spark modulator. It usually occurs after a spill or when the ignitor electrodes have remained wet after a cleaning. If after a day or two it continues to spark intermittently on its own, then the only recourse would be to replace the module. Hope this helps,,,, Bill
May 28, 2009 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Hey there, lp820 user
No I was never able to come to a resolution for this projector.  My next step was to buy a new bulb but I haven't gotten around to that since I already have another projector that works.  If you do buy a new bulb, let me know if that fixes the problem.  The only other thing I've heard it mind be was a memory problem or the temperature sensor...  good luck
Nov 15, 2008 | Office Equipment & Supplies
Moblie Mapper CE Cannot Link to desktop
On your Thales, go to Start> Settings> Control Panel, then find "PC connection". Open that and make sure "Enable direct connections to the desktop computer" is checked. Click "Change Connection" and make sure it says USB then hit OK. Hit OK again close Control Panel. Disconect the GPS from your computer and reconect. It should allow access now.
Mar 31, 2008 | Thales MobileMapper CE GPS Receiver
Intermittant
Chuck that piece of S_it in the garbage and pack the whole can off the France. Hopefully you bought a replacement plan or equivalent when you purchased it. Brought mine back after 2 days of blue screen issues, Best Buy replaced with a 1G Garmin Nuvi. Bye Bye Magellan, you bunch of French pinkie raised ****.
May 09, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
48 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
