Question about Toshiba Satellite L850D-BT2N22 Customizable : Laptop Notebook
Broken shift key on Satellite L850D
I had just gotten this Notebook less than a week ago and everything was working perfectly. Today I noticed a physical difficulty my shift has been having where I can tell the rubber underneath has broken and will not pop the key back up. I wonder if this is common and I had replaced computer keys before on a different Notebook. To note, this Notebook is also refurbished by either Toshiba and/or Future Shop. My question is how I can remove the key without damaging anything
  • Eric Hallett Jan 06, 2013
    Reminder: This is a PHYSICAL PROBLEM. THE HARDWARE.
trintek
  • 111 Answers
SOURCE: STICKEY KEYS!
heres the quick version:
hold down both shift keys, it should either disable it or pop up a message to disable it, hit escape, not cancel...
control panel, accessibility options, keyboard, click settings near filterkeys, uncheck use shortcut, click ok.. check the boxes for use filter toggle and stickey keys, hit applyuncheck them all and hit apply again... if this doesnt fix it, read on..
create a blank text file on your desktop named disable.reg or something similar, and paste the portion between the --------'s into it:
[HKEY_CURRENT_USER\Control Panel\Accessibility]
[HKEY_CURRENT_USER\Control Panel\Accessibility\Blind Access]
"On"="0"
[HKEY_CURRENT_USER\Control Panel\Accessibility\HighContrast]
"Flags"="122"
"High Contrast Scheme"="High Contrast Black (large)"
"Volital HC Scheme"="High Contrast Black (large)"
[HKEY_CURRENT_USER\Control Panel\Accessibility\Keyboard Preference]
"On"="0"
[HKEY_CURRENT_USER\Control Panel\Accessibility\Keyboard Response]
"AutoRepeatDelay"="1000"
"AutoRepeatRate"="500"
"BounceTime"="0"
"DelayBeforeAcceptance"="1000"
"Flags"="122"
"Last BounceKey Setting"=dword:000001f4
"Last Valid Delay"=dword:000003e8
"Last Valid Repeat"=dword:000001f4
"Last Valid Wait"=dword:000003e8
[HKEY_CURRENT_USER\Control Panel\Accessibility\MouseKeys]
"Flags"="58"
"MaximumSpeed"="80"
"TimeToMaximumSpeed"="3000"
[HKEY_CURRENT_USER\Control Panel\Accessibility\SerialKeys]
[HKEY_CURRENT_USER\Control Panel\Accessibility\ShowSounds]
"On"="0"
[HKEY_CURRENT_USER\Control Panel\Accessibility\SoundSentry]
"Flags"="2"
"FSTextEffect"="0"
"WindowsEffect"="0"
"TextEffect"="0"
[HKEY_CURRENT_USER\Control Panel\Accessibility\StickyKeys]
"Flags"="506"
[HKEY_CURRENT_USER\Control Panel\Accessibility\TimeOut]
"Flags"="2"
"TimeToWait"="300000"
[HKEY_CURRENT_USER\Control Panel\Accessibility\ToggleKeys]
"Flags"="58"
make sure not to paste the ------'s.. anytime it enables itself, just doubleclick the file, it should disable it for you.
hope this helps
trin
Posted on Nov 16, 2007
  • 152 Answers
SOURCE: @ key not working in toshiba laptop
has it ever worked?
it could be that your are pressing the wrong combination buttons or that if its a laptop with a spanish keyboard, the keyboard settings is kind of wrong..
to check if its the keyboard settings, go to control panel and look for something that has to do with lenguaje.. there you can set up the lenguaje you want..
hope that helped..
Posted on Dec 13, 2007
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite wireless switch doesn't turn on
Ok, if your using Vista, what i want you to do is right click "computer" select "manage" and then "device manager", then click on the + sign next to "network adapters" and right click on the wireless network and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again
keep me informed please and thanks for using Fixya
Posted on Feb 13, 2009
sp4m771
  • 116 Answers
SOURCE: toshiba satellite fn key display problem
Just download this :) It will fix your problem. If it doesn't work, just search for Toshiba Value Added Package Vista/XP (that depends on what Operative System you've got) and download for your Operative System.
Posted on Jul 23, 2009
  • 6 Answers
SOURCE: How to remove and replace the keyboard on a Toshiba notebook
Manual at Here (http://uk.computers.toshiba-europe.com/innovation/download_manuals.jsp?service=UK)
it should tell you in there, you may need a positive screw driver as well
Posted on Feb 12, 2010
2006 Kawasaki ZZR 1400 won't shift
Hi, Edward and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
won shift up to 2nd
Shift Lever is stuck Cant get past 2nd Kawasaki Forums
Kawasaki 2007 ZZR1400 Service Manual
OEM Parts for Kawasaki
Kawasaki ZZR1400 Owner Manual
Jun 10, 2017 | 2006 kawasaki ZZR 1400
Toshiba L850D bios password
If removing CMOS battery did not help, you need to do the BIOS reset from jumper on motherboard.
Apr 22, 2014 | Computers & Internet
Not cooling
either your heating element for auto defrost is broken or your thermostat is is broken
Dec 09, 2013 | Frigidaire Refrigerators
Have a Toshiba Satellite and it has been having problems over the last week It would sometimes take me up to 10 tries to get it to turn on. After it did turn on it would be fine. But when I was on...
Seems like a clear case of overheating. Have you owned it a long time? May need to clean out the dust in it. The Fan may of also stoppped working. Hopefully you can get it checked out before permanent damage is done.
Jun 16, 2011 | Toshiba Satellite M35X-S163 Notebook
My truck wont start
ignition switch,,or,,battery dead,,or ,,broken wire at starter
Jan 31, 2010 | 1988 Chevrolet S-10
Gear Shift also "floppy"
sounds like a selecter fork broke or dislodge
Aug 27, 2009 | 1997 Saturn SL
Media Keys don't work after XP reinstall
They should be included with the chipset drivers, you might try looking for a F Lock on your keyboard. Maybe you need to turn it on?
Jan 22, 2009 | Toshiba Satellite A55-S326 Notebook
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite L850D-BT2N22 Customizable : Laptop Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
