Question about Kenmore 84152 Electric Dryer
Kenmore 84152 How do I remove the heater element? Do I remove the drum and work from the front. Do free manuals exist?
  • Kenmore Master
  • 8,220 Answers
On a kenmore conventional dryer they had for a million years the heating element is on the rear of the machine on the right. Some newer models "princess type" have a lower front panel and a heater that just yanks out for easier servicing.
Posted on Jan 20, 2009
How to remove back of kenmore 417.90812991 dryer
If you have the stacked "laundry center"like shown here:
http://www.searspartsdirect.com/model-number/41790812991/0582/0152000.html?searchType=modelSearch&q=417.90812991&searchTerm=417.90812991
You need to access the heater from the front of the machine. After you open the front and remove the drum, you will find the heater behind the drum.
Mar 04, 2017 | Kenmore Dryers
I need to replace belt on a Kenmore 417.94802301 How do I get to it?
Unplug it. Get the topthemobilian_2841.jpg off then remove the splashplate. themobilian_2842.jpgRemove the controls. Then the front. themobilian_2843.jpgRemove the 3 screws holding the drum to the rear (or if you are Hercules you can just lift it out). themobilian_2844.jpg
Check the glides to see if they are what cause the belt to break. themobilian_2845.jpg
Note: this is the old style yours might be different and not have this type setup.
See the small klixon? If that dude trips the dryer won't run. That is the thermal fuse.
Check the bearing in back for wear. When they go out the drum falls into the heater element and has a meltdown
themobilian_2850.jpgthemobilian_2851.jpgthemobilian_2852.jpgthemobilian_2853.jpgthemobilian_2854.jpg
Service manual and more photos are HERE
Aug 18, 2011 | Kenmore 98702 Stacked Washer/Dryer
How do i replace the heater element
Remove the rear panel and on the right side looking fro rear you will see a "can" into which the heater is mounted. That is if the lint filter is in the top of the dryer(whirlpool) made . If it is GE made then you must remove the front and the drum and the heater is behind the drum.
Nov 01, 2010 | Kenmore 63942 Dryer
Kenmore dryer rotates but does not get hot is this a costly repair problem?
What you need to do is check the heating element. It is mounted on the back wall. 0706c6a.jpg Remove the top first then you can remove the front. Get the belt loose from the idler and lift out the drum. Then you can check the heater element. More here
Oct 24, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Procedure to replace heating element on 84152 electric dryer
This is a simple repair. Just follow these steps:
1. UNPLUG dryer. Dangerous voltage is still present even with the dryer turned off.
2. Remove the dryer vent exhaust hose and remove the back of the dryer.
3. The heating circuits are located on the right hand side (as viewed from the rear). The heating element is located inside the heater box. Simply remove the mounting screws on the heater box and remove the two wires on the heating element terminals. NOTE: You can leave the two remaining components (Thermal Cut-Out and Hi limit Thermostat) connected on some models. If you need to remove them in order to remove the heating element make sure you label the wires.
4. Locate the mounting screw(s) on the outside of the heater box that hold the heating element in place.
5. With the mounting screw(s) removed the heating element will slide out of the heater box.
6. Insert new heating element, making sure you avoid touching the coil and align the screw holes so you can reinsert the mounting screws.
7. Re-install the heater box and any remaining components.
Now...are you sure you have a bad heating element? Just because a dryer does not heat, does not necessarily mean the heating element is bad. The following link explains:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The most common fail item that causes a dryer heating circuit failure is a blown TCO caused by poor dryer ventilation. Just something you may consider.
If you have any questions, please let me know. I hope you find this information helpful.
Aug 22, 2009 | Kenmore 84152 Electric Dryer
Kenmore electric dryer 8662100 drum turns, no heat
you have probably lost one leg of your power supply feed 120volts+120volts=240volts,your motor will operate on 120volts, but the element won't,also if you have 240volts the neutral wire to the element can burn off w/heat and age
Aug 18, 2009 | Kenmore 84152 Electric Dryer
My Kenmore dryer is not heating. Need to check heating element.
Hi, You need to remove the front lower panel. There you will find the element on the right side under the drum. If the element checks out ok, then you need to test al the thermostats and the safety fuse. With he dryer unplugged, check all these parts for continuity. If any of them show no continuity,replace it. If I can assist you further, please let me know.
Thanks
Vic
May 16, 2009 | Dryers
MAYTAG DRYER DE-306 REPLACING HEATER ELEMENT
the elament is in center of drum take off back of drum
Feb 18, 2009 | Zanussi TD4212W Electric Dryer
Kenmore 84152 /94152
probably the heater
Jan 15, 2009 | Kenmore 63942 Dryer
Hello My Kenmore 84152 dryer stopped making heat. I have varified the 2 thermo units each read 0 ohms the lower thermister on the blower houseing read 89.4k ohms and I can't for the life of me get to the...
AS LONG AS YOU GET READING THE IS GOOD ,NO READING AND THE PART IS BAD,TRY TO GET ONE OF THE TERMINAL OFF THE HEATER COIL AND YOU STILL CAN TEST IT THAT WAY,MORE THEN LIKEY IT IS THE HEAT ELEMENT BECAUSE EVERTHING TEST GOOD RIGHT?HOPR THIS HELPS,THANKS-MIKE
May 30, 2008 | Kenmore Dryers
Kenmore 84152 Electric Dryer Logo
126 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
