Question about iflo Home
When i switch on my iflo enigma shower the power indicator goes out and the shower runs cold
Power light is on when start buttun is pressed the light goes out and the shower runs cold
    Problem Solver:
  • 14 Answers
You should not be taking an enema shower, especially with cold water.
Posted on Mar 25, 2013
I need to know why i have no power light on my triton shower unit ?
check the circuit breaker is on & reset the thermal cutout on the unit
Nov 26, 2014 | Home
Triton martinique shower runs cold .Selector light goes from hot to cold
forums.moneysavingexpert.com/showthread.p...
Jun 30, 2014 | Home
Shower not draining iflo waste
The domed drain plug has to be removed periodically, disassembled, cleaned, and reassembled. Be sure to disassemble it in order so you can reassemble it correctly.
While the drain plug is removed, apply drain cleaner in accordance with the directions
Nov 10, 2013 | iflo Home
I have an iflo thermostatic bar shower mixer which no longer delivers hot water for the shower. Do i need a new Bar Mixer?
To get rid of this problem, you should consult with a professional. Apart from this, you can buy attractive and best quality shower mixer by visiting this site: showerenclosures
Jan 02, 2013 | iflo Home
How do I wire up my IFLO TIMESWITCH 24hr 7 day
put the wire to the connector of iflo time switch . then install a on-off .that's ok ..
bathroom light
May 15, 2012 | iflo Home
Water was turned off because of fault now shower is running cold water what do i do
Most showers have a low flow protection on them so it is either the mains pressure has dropped after the fault was repaired or it could be a blocked filter, the shower should have a low flow indication on it by means of a light on the front of the shower unit.
Mar 29, 2011 | Home
My Bristan Meridian Show start ok with hot water then after a few minutes the water runs cold. Even if you try and increase the temp it still remains cold. You can switch of the shower and start again...
It sounds like 1 of 2 things to me. I will start wit hot water heater. The first test for the water heater is to have someone run the hot water while you hold the hot and cold pipes and see if the water is coming out of the water heater cold when the shower goes cold. Of the water heater is cold coming out then the problem is in the heater. ether a lower element is bad or the dip tube is broken at the top of the tank. if the hot water heater continues to put out hot water when the shower goes cold then it has to be the mixing valve for the hot and cold mix at the shower and that valve will have to be repaired or replaced. hope this gives you a good start. let me know if I can help further.
Dec 24, 2010 | Home
Cold shower
You posted to the category:
Tritton Technology | T-NAS 120GB (trinas120) 120 GB Network Storage
Take the defective unit to a qualified repair-site, for trouble-shooting.
Nov 14, 2009 | Tritton Technology T-NAS 120GB (trinas120)...
Home Logo
217 people viewed this question
Top iflo Home Experts
Donni Steen
Tom Chichester
Are you an iflo Home Expert? Answer questions, earn points and help others
