Question about Fujitsu Siemens Computers & Internet
I have a fujitsu laptop, when i plug in ac power the baterry charges but nothing else responds not even the fan, what could be the problem?spur
  • Fujitsu Siemens Master
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Jan 06, 2013
benwabnick
  • 2404 Answers
SOURCE: Acer 5100 laptop doesn't work on ac or charger battery
Motherboard is bad and will have to be replaced unless of course the AC Jack on the back of the laptop is loose. That would cause the ac adapter not to charge and then you would have to take the motherboard out and put solder on each leg on the bottom of the ac jack to make sure it stays in place then the ac adapter can charge the battery properly.
Even going thru the solder method the motherboard could still be bad and have nothing to do with the ac jack.
Posted on Mar 08, 2009
  • 8 Answers
SOURCE: hp compaq nx9110 runs only on battery when it is plugged to AC
It sounds like you have a faulty power jack, and possibly a dead battery as well. You should take it to a person you may know that can order and solder a new one in or take it to your local electronics repair shop. I do repairs like this on a daily basis for my computer business.
Posted on Apr 28, 2009
  • 16 Answers
SOURCE: Dell Inspiron 5150 Will not turn on......
First off start with cheap, Replace the external powersupply, (the ac power cables and company)
Second, Replace the battery. However if it dosn't show the lights atall when it's plugged in it must not be the battery. Because even without the battery a light should come on saying the laptop is plugged in.
Finnaly what I think the problem probably consists of:
You most-likely need to get your computer repaired by someone, There's mostlikely a fault in the internal power supply. that charges the battery. I'm guessing maybe a little fuse or something popped and you need it replaced. But best get a professional to do it instead of someone who knows nothing.
Posted on Apr 29, 2009
parrotheadpc
  • 2600 Answers
SOURCE: acer aspire 5920 wont start. light in AC chrger
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Posted on Oct 12, 2009
RescueTechLA
  • 2653 Answers
SOURCE: Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Posted on Apr 04, 2010
Testimonial: "First step in a series to diagnose. On the journey. Useful thanks."
Baterry isnt charging it only works on AC power DELL PP22L
Press the function and F3 button. This will enable/disable charging. If that does not work, then you either have a power adapter that is not creating enough voltage to charge the battery or the battery has gone bad.
Oct 21, 2012 | Dell PP22L-XT279 Core 2 Duo 1.6g 1gb Ram...
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
Hello my fujitsu e2010 jusr stop working it will
Hi. Try to remove the battery, unplug the ac adapter and press/hold the power button for 10 seconds then plug the ac adapter in. do not put thebattery back in yet. turn the computer on and see what will happen.
If nothing happens, your motherboard needs to be replaced.
Good Luck!
Jun 06, 2010 | Fujitsu Siemens LifeBook E2010 Notebook
Fujitsu esprimo mobile only charges when it is on
No that not normal.
Turn the laptop off and remove the AC power and then the battery. Plug in AC power only and start the laptop, let it boot into the operating system and then turn it back off.
Remove AC power and reinsert the battery, then plug in AC power again and look for the charge indicator LED light on the front of the laptop.
If the light comes on then it's charging.
If it doesn't then there is a problem with the laptop.
I would recommend giving Fujitsu a call as their customer service is excellent.
Good luck.
Sep 16, 2009 | Fujitsu Siemens Computers & Internet
LAPTOP KEYBOARD IS NOT RESPONDING TO TOUCH. dELL
try this:
1. shut down your laptop
2. remove battery and unplug ac power
3. keep it that way for 2-3 minutes and then put the battery back in, plug the power cord and turn it on.
if you have no luck try doing a windows system restore and see if that helps. if not you should contact dell support or return for warranty.
Aug 19, 2009 | Fujitsu Computers & Internet
Fujitsu laptop powered up then went dead now not even powering up
take out the battery and only hook up the ac adapter and turn on the laptop and see if that gets video to come back up.
If that doesn't work then try another known working ac adapter to see if that works.
After that, then open up the memory door and reseat each memory one stick at a time into each slot one at a time turning on the laptop after each stick reinsertion. If this doesn't work, try a known working stick of memory into each slot of the laptop, just to make sure that its not a problem with either of the other two sticks.
If that doesn't do the trick then with the laptop off, take out the hard drive and take out the dvd drive.
If you still can't get any video on the screen, then the motherboard is shot and would need to be replaced and hopefully the laptop is under warranty for you.
Jul 05, 2009 | Fujitsu Siemens Computers & Internet
Fujitsu siemens amilo m1405 won't switch on
hi i have fujitsu sieman amilo 3710 it will no switch on there nothing no noise no light but when put it on charge the little charging light comes on to say its charging can u help
Jun 11, 2009 | Fujitsu Siemens AMILO Xi 1546 Notebook
No response
First follow procedure to try to reset the power.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 23, 2009 | Acer Computers & Internet
No power
Hi there
Take the battery out and try to power the machine up on AC only,
Post back with the results please
Feb 01, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Dell gx520 power light flickers green and cant powerup
Rmove the baterry and start without baterry, and put back the bateryy after restart .
Jan 22, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
163 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
