Question about Maytag Refrigerators
Maytag GC2225GEKS repair manual
Leaking water from water filter unit
3 Suggested Answers
SOURCE: Water filter compartment leaking
If you have already replaced the filter and you can see the housing is still leaking, You have to replace the housing and water tank as an assembly (12956202). Make sure you verify it's the filter housing leaking, and not a fitting at the water valve which is right behind the plastic cover around and below the filter housing.
Posted on Apr 28, 2009
BMT60
  • 126 Answers
SOURCE: new unit never used found the water filter cracked
THE FILTER HOUSING MAY HAVE FROZE AND BROKE. MAY HAVE FROZE ON TIME IN SHIPPING. CALL ELECTROLUX THEY WILL SEND YOU THE PART AND A TECHNICIAN TO FIX IT. SO IT COULD BE REPAIRED IN ONE TRIP.
Posted on Apr 24, 2010
Testimonial: "good answer, water filter replaced. water is still collecting at the bottom of the ice box, the new water fiter is not leaking, ???"
My Maytag gc2225geks water dispenser not working. At first the water dispense from it at a very slow flow rate. My brother removed the filter and give it a clean and now it failed to dispense any water or...
Try this... unplug frig and take everything out, leave the doors open as well. let everything thaw out for at least 2 days. then plug in and see if water comes out. what we are trying to do is make sure that the water hasn't frozen inside the door. i seen this happen and it drove me crazy. try this because i want to save you money from guessing whats wrong and buying parts. if the water comes back on then let me know and i will find the kit you need to stop this problem
ok if the water still doen't come out then make sure you have enough water pressure going to the frig.
another problem could be a plugged water filter, you can try to put a new one (every 6 months recommend) to see if this corrects the problem
take off the connector at the water valve and see if there is any debris
if all fails the only thing left is the water valve itself
replace
hope this was helpful
Mar 15, 2010 | Freezers
The switch face panel on my Maytag gc2225geks has started to break up infront of the switches due to ware an d tare can you get new switch panel covers.
most of the time u can call maytag or go online to maytags website and find a number to call to get the part u need and u r going to have to order it but the price may be ridiculious
Mar 01, 2010 | Refrigerators
Leaking Maytag Model MZD2766CE
Your drain line is clogged. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
Feb 02, 2010 | Refrigerators
Apr 28, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
When washer finishes there is a dripping of water inside unit
What has happened is you have sand in your water valve from your water. This pluggs the water valve and also sticks it open so when the water valve shuts of there is still a small trickle of water coming through the washer. Replace the water and it will fix the problem (no way of cleaning the inside of the valve.) Replace water valve.
Nov 24, 2008 | Maytag Washing Machines
Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Leaking dishwasher
when you state "there is water leaking out of the drain hose", then that leak must be fixed either by a new hose or to repair the hose. as far as the timer issue, i need more info.
May 25, 2007 | Maytag 24 in. PDC3600A Built-in Dishwasher
Refrigerators Logo
59 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
