Question about Jetway 512MB 945GCM3 667MHz UDIMM
Power on/off switch is not working
5v is coming on on/off switch
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jetway Master
  • 2,226 Answers
Is it on the right pin for power pins on board
Posted on May 25, 2014
I get problem with my loewe television concept L26 that remains stand by even you switch it on using remote. at the power supply circuit only 5V can be seen at connectorW652 and connector W651 no vol
Just understand, that the 5V supply you measure comes from the power supply is used for standby and power On switching purpose. As far as this supply voltage is OK, the fault must be to its main board, because, from the main board comes the power up start voltage back to power board to initialize its whole working.
Check the main board. The power supply regulator board is now Ok; otherwise, you can't get this 5V supply line active. Contact any service technician.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jun 25, 2014 | Loewe Concept L26 26 in. LCD TV
TV will not come on even though the light turns blue
check for leak or bad capacitors in the power supply board, then if you can make a voltage checking just to ensure if output voltage in the power supply board are present. the 5v standby 5v switch 12v and 24vdc at the power supply doesn't drop.
Sep 03, 2012 | Televison & Video
Where does the power switch connect on a Gateway GT5056?
the power switch is in the front pannel of the motherboard if you have multitester the power wsitch will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 27, 2011 | Gateway GT5056 PC Desktop
No power
Do you get any indicator lights at all? If you do, the at least the 5v standby circuit is still working. Check the power supply fuse first, then look for 5v standby voltage, if you do have the 5V, then the problem can be in the controller board not sending the ON command to the main power supply when the power switch is activated, OR the main power supply is bad. Look for bad capacitors or bad/burnt parts.
http://en.wikipedia.org/wiki/Capacitor_plague.
Nov 06, 2009 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Olevia 42 inch Flat Panel has power supply issue... Blue light does not come on and tv does not turn on... I have tried all different things to get tv to work with no positive results
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Nov 04, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
I have a smartlink ESK-108 with no power supply can you tell me what voltage is required thanks?
AC/DC power adapter transformer
AD-051A 120v 13W input AC, 5v 1A output
or
JOD-41U-27 120v 100mA input AC, 5v 1A output
I have the latter and it works.
Apr 12, 2009 | Archtek America ESK-108 8x10/100 Mbps...
Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
ASUS P5GL-MX performance
Install new power system!
Thanks,]
Melcom Smit
Oct 04, 2008 | Computers & Internet
Will Not Turn On
hi,
iandojay
check PW suppy is ok check all voltages in the micro controller IC
Dec 05, 2007 | Televison & Video
Jetway 512MB 945GCM3 667MHz UDIMM Logo
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
