Question about HGST 1 TB Touro Mobile MX3 USB 3.0 External Hard Disk Drive
Installing a touro usb drive
Unable to install on windows 7 desktop
ANY DRIVER FOR TOURO MOBILE MX3 USB 3.0?
go on line for your model and down load the driver or if in windows add the machine and let windows search and down load the driver for you.
Jul 06, 2014 | HGST 1 TB Touro Mobile MX3 USB 3.0...
Tip
Windows 7,Linux and other OS install from USB Pen drive, Flash Drive
To Install Windows 7 via USB Flash Drive (Pen Drive)
You need:
USB Flash Drive (Pen Drive) minimum 4 gb for windows 7
Windows 7 ISO image file.
UNetbootin software download from here UNetbootin
Download the Unetbootin software, and open the file and click "RUN".
below window will pop
You can aslo install other OS's like linux etc etc. for Windows 7, click "Diskimage" radio button, locate or browse the ISO file of your OS by clicking "..." button.
select Drive: (in my PC usb drive is "I:" and press OK.
Next window looks like below picture
Wait till Installation Compleate.
after compleation. Click "reboot" to install to the same PC, or remove the Flash drive(Pen drive) and plug it to another PC or Laptop USB
and boot that System by USB Flash drive.
To do this Select the USB boot option from the BIOS. Or to boot from USB go through your Motherboard User Manual.
This method works on most of Machines with USB booting option.
I personally installed 100's of PC's via this method
thank you. Keep smiling. aaarwind
for other OS setup's via USB drive refer to below Website:
UNetbootin - Homepage
on Jan 20, 2011 | Computers & Internet
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
I can now see my hard drive but unable to access to install Windows 7, what must I do ? My new HP PC p2-1394 desktop came with Windows 8,I don't like it and wish to re install Windows 7, but can not a
Go to the forgotten password and enter ur mail or phone number then u reset ur pasword from e-mail or phone number with given a security code which sending from +3266 and chnge ur paswrd nd enjoy facebook...
Feb 07, 2014 | HP/Compaq P4 System - WinXP Pro/Office...
Hello I have a Dell Optiplex 170L it has 1GB Ram 80 GB hard disk Installing Win 7 does not finish error is cant instal Windows then refers me to change settings in bios I am unable to identify the exact...
You can possible download windows 7 via microsoft's website(https://www.microsoft.com/en-us/download/windows-usb-dvd-download-tool) onto a USB drive. just make sure in bios to set the boot priority to USB devices.
Sep 12, 2017 | Computers & Internet
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
Tip
Install Windows From Usb Drive
Windows 7 can run on machines with lower specs than required for Windows Vista, and many users are actually finding it runs better than Windows XP on lower spec machines. It’s also ideal to run on newer netbook machines, but unfortunately many of these do not include a DVD drive so how do you install windows 7 on a machine without a DVD drive?
I spent yesterday researching this exact problem and I managed to install Windows 7 on my LG X110 netbook in around 20 minutes using a 4GB USB Drive. Setting up the USB drive to install Windows 7 was fairly easy in the end, and the installation was quicker than a DVD drive, so this method is perfect if you want to install Windows 7 quickly on several machines.
How To Install Windows 7 From A USB Drive
  1. Find a standard 4GB USB Drive and plug it into your machine
  2. Click Start in your enter ‘cmd’ in the run field. Once cmd is open type in ‘diskpart’ and a new window will open
  3. In the new diskpart window type:
  • ‘list disk’ : This lists all the disk drives attached to your machine
  • Look for your USB drive and note the number and then type: ’select disk #’, where ‘#’ is your USB disk number
  • then type ‘clean’
  • then type ‘create partition primary’
  • then ’select partition 1′
  • then ‘active’
  • then ‘format fs=fat32 quick’
Once you’ve finished these steps you then need to copy your Windows 7 files to the USB. To do this you have to mount your Windows 7 ISO as a virtual DVD. Doing this is easy:
  1. Install MagicDisk (free)
  2. once installed, right-click on MagicDisk in your system tray click on ‘Virtual CD/DVD-Rom’, select your DVD drive
  3. then ‘Mount’ and in the dialog window that opens up, select your Windows 7 ISO
  4. Now in windows Explorer, click on your DVD drive and you should see all the Windows 7 Files. All you have to do now is copy and paste all the files to your USB key and you have a Windows 7 USB Installation Stick!
  5. Install the stick in the PC you want to install Windows 7 on and boot up. Remember to change your bios to allow booting from USB
If you follow the steps above then you should have no problems installing Windows 7 from a USB key
on Dec 23, 2009 | Computers & Internet
My hitachi touro desk dx3 2tb hard drive use to work fine on my mac then i plugged it in to a windows 8 pc, since then the hard drive will only work on the windows8 and not my macbook, how can i fix t
Thanks for asking your question on Fixya. ;-)
What error messages are you seeing, if any? Does Apple OS recognize it at all? Also, did you format the drive on a windows computer? How about deleting the partition and plug it back into the macbook so the macbook can set it up for you. If you plug it into the windows machine, what messages did you get from that?
Jul 21, 2013 | Hitachi 2TB Touro Desk DX3 USB 3.0...
Hitachi touro usb 3 hardrive will not work in windows 8
I contacted Hitachi support, no solution. They say we should return and exchange the disk with a new model that supports Windows 8.
Very very fustrating.
Jan 23, 2013 | Hitachi Gst Hitachi - Touro Desk Pro USB...
HGST 1 TB Touro Mobile MX3 USB 3.0 External Hard Disk Drive Logo
48 people viewed this question
Top HGST Computers & Internet Experts
David Payne
David Payne
Are you a HGST Computer and Internet Expert? Answer questions, earn points and help others
