Question about Jenn-Air JXT8136ADS Kitchen Hood
Halogen bulb melted the socket
One of the halogen bulbs got so hot the sprockets on the end of the bulb actually melted off, the bulb fell out of the socket with the sprocket on fire and the inside of the socket is melted. Bad wiring? defective socket?
  • jewart72 Jan 20, 2009
    even the socket casing gets extremely hot on all of them...is this normal?? seems like a fire hazard.
    Sergeant:
    Champion:
  • 338 Answers
Most likely a bad socket. if it were bad wiring the problem may have occured somewhere else in the range..
Posted on Jan 20, 2009
My Sirius Range Hood has two lights that take G4 Halogen bulbs. Is there a 115V bulb made for this application or is there something that converts the voltage to 12V?
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb is just as bright but runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Nov 29, 2016 | Sirius Kitchen Ranges
Headlight Bulb Keeps Burning Out
The bulbs that you are using might be too hot. IF you are using halogen bulbs, that could be the issue. Stop at an autoparts store and see if they have the socket/plug assembly, that is the easiest way. If you must use halogen bulbs and there is a cover that is on the back of the bulb, leave it off for better ventilation. Also some high intensity bulbs burn out FAST and you CANNOT install them with bare hands because the oil in your skin ruins them.
Feb 17, 2014 | Pontiac G6 Cars & Trucks
Need replacement halogen lights for SU3
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Mar 07, 2013 | Sirius Hoods SU3
Headlight bulb burnt out. Upon replacing bulb, found the plug had been hot and burnt the plastic mold around plug. The prong hole was also black. New replacement bulb also burnt out immediately.
Welcome to Fixya
This is a common problem with headlight bulb higher than the 60W bulb. You can actually replace the plug with a ceramic type so that it wont melt. This happens to my car. I am using halogen bulb and burned the plastic mold together with the bulb. Replacing the plastic mold with ceramic type mold fixed the problem.
Thank you for using Fixya!
Jun 14, 2011 | 2006 Pontiac Grand Prix
How to change a front turn light in a 1996 taurus.
Lamps, Parking Front Lamp-Lamp Assembly, Taurus
Removal and Installation
  1. Remove Headlamp (13008) as outlined.
Headlamp Assembly
  1. ani_caut.gif WARNING: THE REPLACEABLE HALOGEN HEADLAMP BULB CONTAINS GAS UNDER PRESSURE. THE HALOGEN HEADLAMP BULB MAY SHATTER IF THE GLASS ENVELOPE IS SCRATCHED OR THE HALOGEN HEADLAMP BULB IS DROPPED. HANDLE HALOGEN HEADLAMP BULB CAREFULLY. GRASP HALOGEN HEADLAMP BULB ONLY BY ITS PLASTIC BASE. AVOID TOUCHING GLASS ENVELOPE. KEEP HALOGEN HEADLAMP BULB OUT OF REACH OF CHILDREN.
    Position headlamp switch (11654) and headlamp time delay switch (13736) in the OFF position.
  1. Remove two bolts retaining headlamp (13008) to upper support assembly and loosen pinch bolt. Remove headlamp assembly from vehicle.
  1. Remove park lamp bulb and socket (Sable only) and headlamp bulb and socket from Headlamp Assembly as outlined.
    Headlamp Assembly (Taurus Shown, Sable Similar)
  1. Turn lamp socket and wiring (13410) assembly 1/2 turn counterclockwise and remove from parking lamp (13200) housing.
  1. Remove screw from park/turn signal housing.
  1. Using 1/4 inch drive socket extension and swivel, insert tool through two access holes in upper radiator support. Remove screws from park/turn signal housing.
  1. Remove parking lamp from vehicle.
  1. To install, reverse Removal procedure.
Nov 19, 2010 | Ford Taurus Cars & Trucks
Need help changing out the low beam on drivers side of 2006 buick rainier
Removal & Installation
Bulb Replacement
To Remove:
CAUTION
Halogen bulbs contain pressurized gas.
Mishandling a bulb may result in the bulb shattering into flying glass
fragments.
CAUTION
Make sure to wear eye protection when
handling a halogen bulb.
CAUTION
Do not touch the glass of a halogen bulb,
only handle the bulb by the base.
CAUTION
Do not allow a halogen bulb to come into
contact with dirt or moisture.
CAUTION
Make sure to dispose of a used halogen bulb
properly.
CAUTION
Do not allow children to handle halogen
bulbs.
  1. Turn the lamp switch to the off position.
  2. Make sure the bulb is cool before changing.
  3. Remove the headlamp assembly from the headlamp panel.
  4. Remove the rear access cover from the headlamp assembly.
  5. Disconnect the headlamp connector.
  6. Remove the bulb from the headlamp assembly by rotating the bulb and socket
    counterclockwise.
To Install:
  1. Connect the headlamp connector.
  2. Install the bulb into the headlamp assembly by rotating the bulb and socket
    clockwise.
  3. Install the rear access cover onto the headlamp assembly.
  4. Install the headlamp assembly into the headlamp panel.
Headlamp Assembly
Chevrolet
To Remove:
Headlamp Assembly (Chevrolet)
  1. Remove the grille from the front of the vehicle.
  2. Release the headlamp assembly retaining tabs.
  3. If equipped, disconnect the headlamp leveling motor connector.
  4. Disconnect the headlamp connector.
  5. Remove the park/turn and side marker bulb sockets from the headlamp
    assembly.
  6. Remove the headlamp assembly from the headlamp panel.
To Install:
  1. Place the headlamp assembly into the headlamp panel.
  2. Install the park/turn and side marker bulb sockets into the headlamp
    assembly.
  3. Connect the headlamp connector.
  4. If equipped, connect the headlamp leveling motor connector.
  5. Lock the headlamp assembly retaining tabs.
  6. Install the grille onto the front of the vehicle.
GMC, Oldsmobile, Buick, Isuzu, and Saab
To Remove:
Headlamp Assembly (GMC, Saab, Oldsmobile, and Buick)
  1. Release the headlamp assembly retaining tabs.
  2. Disconnect the headlamp connector.
  3. Remove the park/turn bulb socket from the headlamp assembly.
  4. For GMC, Saab, Oldsmobile, and Isuzu vehicles, remove the side marker bulb
  5. Remove the headlamp assembly from the headlamp panel.
To Install:
  2. For GMC, Saab, Oldsmobile, and Isuzu vehicles, install the side marker bulb
    socket into the headlamp assembly.
  3. Install the park/turn bulb socket into the headlamp assembly.
  4. Connect the headlamp connector.
Oct 28, 2010 | 2006 Buick Rainier
How to replace headlight bulb on 2002 chevy trailblazer
Headlamp Removal & Installation Bulb Replacement To Remove:
CAUTION
Halogen bulbs contain pressurized gas. Mishandling a bulb may result in the bulb shattering into flying glass fragments.
CAUTION
Make sure to wear eye protection when handling a halogen bulb.
CAUTION
Do not touch the glass of a halogen bulb, only handle the bulb by the base.
CAUTION
Do not allow a halogen bulb to come into contact with dirt or moisture.
CAUTION
Make sure to dispose of a used halogen bulb properly.
CAUTION
Do not allow children to handle halogen bulbs.
  6. Remove the bulb from the headlamp assembly by rotating the bulb and socket counterclockwise.
To Install:
  2. Install the bulb into the headlamp assembly by rotating the bulb and socket clockwise.
Headlamp Assembly Chevrolet To Remove:
  5. Remove the park/turn and side marker bulb sockets from the headlamp assembly.
To Install:
  2. Install the park/turn and side marker bulb sockets into the headlamp assembly.
Jul 20, 2010 | 2002 Chevrolet TrailBlazer
Change low beam
CAUTION
CAUTION
CAUTION
CAUTION
CAUTION
CAUTION
To Install:
Jul 16, 2009 | 2004 Chevrolet TrailBlazer
How do you replace the fog light bulbs on a 2004 buick regal?
Notes FOG LAMP BULB REPLACEMENT - FRONT
REMOVAL PROCEDURE
  1. Remove the front bumper fascia deflector.
  2. Disconnect the electrical connector from the front fog lamp bulb/socket. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Rotate the front fog lamp bulb/socket counterclockwise to release.
  2. Remove the fog lamp bulb/socket from the front fog lamp assembly.
  1. Install the fog lamp bulb/socket to the fog lamp rotating clockwise until fully seated. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Connect the electrical connector to the front fog lamp bulb/socket.
  2. Install the front bumper fascia deflector.
Jun 16, 2009 | Buick Regal Cars & Trucks
Halogen light heater
I have same problem Took whole unit apart found upper bulb is connected with wire that goes through out. You hve to physically take bulb out through side without electronic panel wire is connected on panel sid with actual plug. but ended up cutting wire other side. Bulb is not like regular bulb you will have to hard wire one side of it. bulb is unseperable from wire. Still looking for replacement bulb. I sure miss my toaster I believe it will probably be chaper for me to buy new toaster vs replace bulb. The bulb is nothing like I have seen before.
Nov 03, 2007 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
Jenn-Air JXT8136ADS Kitchen Hood Logo
603 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
