Question about Bosch Washing Machines
I purchased a Bosch wash machine a couple of years ago from a local dealer. I had trouble right away when the washer spins it vibrates and makes a lot of noise. I contacted the dealer right away and then sent a service man out to look at it and balance it. They have been contacted several times regarding this issue and they have told me that front load washers just do this. I have visited with several others that have front load washers and there's are quiet and don't move all over the place when they are spinning. I now have water that just sits right inside the door. There is a bedroom directly below this wash machine and the light fixture doesn't work correctly anymore because the ceiling shakes so bad everytime it spins. I am VERY VERY frustrated with this and would like to know what I can do. I don't even want this wash machine anymore. I feel I have a lemon and feel that it should be taken care of. The dealer makes up a different excuse everytime I talk to him regarding why this moves all over while it spins, it vibrates and is noisy. He has used the excuse that it's the floor, sometimes he tells me this happens in newer home, sometimes he tells me it happens in older homes. What can I do?
    Top Expert:
  • Bosch Master
  • 78,267 Answers
Buy a top loader.
Posted on Mar 02, 2017
  • 641 Answers
SOURCE: Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Posted on Jul 26, 2007
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
  • 1028 Answers
SOURCE: front load washer- spin cycle is like a hurricane
be sure all the shipping materials have been removed ..next adj all feet up as close to bottom of washer as possible ..try rocking machine ..if movement detected adj only foot necessry to firm up washer ..still have vibration suspect floor ..front washers need a good SOLID floor
Posted on Aug 17, 2008
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
I had same problem, the bowl is supported by (2) large springs from the top & two telescoping shock absorbers underneath.
I inverted the machine, found a large hollow retaining plastic bolt had falled out of the shock absorber,causing the bowl to be out of balance & the drive belt to be missaligned.
I reinstated the plastic retaining pin/bolt then tried the machine again.
Now the damn thing refuses to wash or spin.
I'm not happy.
Posted on Nov 06, 2008
  • 50 Answers
SOURCE: MAYTAG LAT8506AAE WASHER - TERRIBLE NOISE/VIBRATION ON SPIN
Try this for re-setting the balancing mechanism:
With the washer empty, tip tip it forward so that it is just sitting on the front feet. Hold it there for a few seconds, then gently lower the back down. (Often there is a mechanism in the back feet that automatically levels it for you--if this doesn't work, check that the back feet are not damaged.)
Posted on Mar 16, 2009
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Washer wont spin, wash or pump enough water in the machine
This is several issues rolled into one. The clank noise is concerning and the smell could be the heating element for high wash temps. The other thing is the control module could be causing a lot of this. The water valves could be causing the fill issue and the clank could be the pulley on the drum. The bad thing is there are not a lot of parts for that machine as it was 13 years old. The control board is almost 300 dollars. Taking the time to trouble shoot it requires tools and patience . The service manual link is attached. Bosch WFMC3200UC Training Manual
Dec 13, 2017 | Bosch WFMC 3200 Front Load Washer
The drum is loose when the washing machine is not in use. When it's in use it makes a loud whirring noise like a train going through my house. This happens on an empty load as well. The machine is a front...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Out of balance drum WM2277HW?
More than likely it did not get reinstalled right after the move. All four of the leveling legs must be firmly touching the floor. If one is even the thickness of a piece of paper off the floor it will start to rock during spin and the problem just amplifies itself. Make sure it's perfectly level and that all the feet are firmly on the floor.
Jul 28, 2008 | LG WM-2277HW Front Load Washer
Movement when spinning
Yes. Did you buy this new or used. ????? Please le me know. I have seen the gromot on these wear out quickly. You need to get it repai if under warrenty .
Feb 10, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washing Machines Logo
26 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
