Question about Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt WTMC6500UC gas dryer lint sensor
Lint sensor keeps beeping
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
  • 7 Answers
SOURCE: Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Posted on Oct 25, 2008
  • 228 Answers
SOURCE: Bosch condensation dryer model WTL5400vc. lint filter alarm
there is a reservoir in the base of the dryer which holds some condensing water prior to the pump pumping it to the holding tank at the top this has a float swith to tell the pump to come on and drain water to top tank this is probably stuck in the on position so the machine thinks it is always full of water and its waiting for you to empty it,you need to remove side panel and remove flost switch to clean, remove condenser and put youre hand in back of unit if its still very wet in there thats the problem should be bone dry at end of cycle.
hope this helps
Posted on Jul 22, 2009
Ranglo
  • 1194 Answers
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 27, 2010
SOURCE: Bosch Nexxt 500 gas dryer takes a long time to dry
Did you ever figure this out? I have a new Bosch and can't get the clothes to dry.
Posted on Oct 07, 2010
My Bosch Nexxt 500 dryer keeps tripping the hi-limit cut out.
Try checking your exhaust vent pipe for excessive bends and kinks, make sure there is good strong airflow coming out the exhaust where it exits the building.
Dec 12, 2013 | Bosch Nexxt 500 Dryer
Bosch Gas Dryer NOT HEATING
Check ur venting inside and outside the machine. the lint basket? is the air blowing out the back without any restrictions? then check ur thermostats with a multi meter for continuity, may also want to check ur moister sensor, if its mis reading the dryness it will shut off heat early
Jul 09, 2012 | Bosch Nexxt WTMC 6500 Gas Dryer
Bosch Nexxt wtmc6500uc dryer. We receive an e01 error with every load and now cannot run the dryer at all. The vent is less than 5' with one bend, we clean the filter with every load, we've replaced the...
This was a previous post, but it may work for you.
A friend of ours has a bosch gas dryer and she had the same problem. She called the Bosch repairman and he sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try.
Feb 12, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Get E01 lint filter beeps every 2 mins
this code is an air flow restriction problem make sure that the dryer filter and duct work is clean and not obstructed.once every thin has been cleared this should solve your problem,good luck let me know how thing sworked for you
Jan 22, 2010 | Bosch Nexxt WTMC 6500 Gas Dryer
Bosch Nexxt Dryer gets warm but laundry doesn't get dry. Dryer stops after about 10 min of running and starts ''beeping''
this could be a faulty moisture sensor. try running the dryer in a timed dry mode and see what happens.also be sure to make sure all the duct work is free and clear and that the lint filter is clean
Jan 14, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer will not heat. lint filter is clean. dryer runs fine bosch dryer nexxt 500.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Nov 08, 2009 | Bosch Nexxt 500 Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
29 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
