Question about Baby Gear
NEED TO CHANGE THE SEAT
SEAT COVERS HAVE FADED & WORN OUT.
    Sergeant:
  • 211 Answers
May I suggest that before you remove the cover take several closeup photos of the current cover connections, as some are very difficult to reattach.
Posted on Jan 06, 2013
Copies Still Faded After Changing Toner
can be the wiper blade, worn out drum, is there a black faint line down the side of the page as well?
May 30, 2012 | Ricoh Aficio Mp 4000...
My 1985 honda accord get flood it.. I look inside the carburetor when the car is off and it look like it keep driping gas, what could be the problem
It appears that the float needle and seat is not sealing properly due to the needle & seat being faulty or the float itself is sticking. Judging from the vehicle year the fault is most probably a badly worn and therefore leaking needle & seat. The problem may be caused by some dirt becoming lodged between the needle & seat, so it would be advisable to replace the fuel filter which is located on the inlet side of the fuel pump.
You may be able to purchase a needle & seat set separately but the best option would be to get a carburettor overhaul kit which includes all the gaskets, seals and N & S.
To replace just the N & S requires the removal of the top cover of the carburettor and can be a bit fiddly because of the little linkages between the cover and body of the carby. If you are unsure of how to tackle job it would be best to have a good mechanic effect the repair as he will be able to ensure all the adjustments and settings are done properly.
Dec 23, 2010 | 1985 Honda Accord
I have an automatic mechenical citizen watch day & date, model V2 of black colour the number inscrived on the back cover of the watch is B L 7200 and 11101446 67-0375 , now the problem persists...
Hi you need to send the watch to Citezen for a full check over and service.
the likely hood id that one of the gears is worn out missing a few teath so no longer catches to rotate the calender wheel.
Dec 30, 2017 | Citizen Watches
HP Z6100- Magenta ink density fade
there may be air bubble in ink tube assembly if u can do the priming then ok o/w call hp service provider to do this
Jul 28, 2010 | HP Designjet Z6100 InkJet Printer
2005 GMC Envoy XL, i just bought one, the radio knobs are worn down and faded looking. Is there a replacement kit for knobs/buttons without physically changing the entire radio? Also my rear cover im...
As for the knobs, if you can pull them right off the unit just go to a scrap yard and pull some off a lower mileage vehicle, doesnt need to be the same exact one alot of gms will share the same parts. or try a site like this https://www.autozone.com/collision-body-parts-and-hardware/radio-knob/gmc/yukon-xl-1500
Dec 21, 2017 | 2005 GMC Envoy Xl
Volume Sporatically Fades Out
Take it back and have him try it with you there so he can hear what you're hearing. He should cover his work unless its something that went wrong after the repair.
Jul 23, 2009 | Music
Right side of label faded or blank after replacing printhead
Things to check:
1. Move the pressure arm further towards the outside of the printhead. Adjust if needed using only the minimum pressure required in order to achieve uniform print quality.
2. Inspect the printhead to ensure it has properly engaged the alignment pins. I have had after-market printheads that did not line up correctly and required "surgery" to make them properly seat on the mounting pins.
3. Check for worn platen roller bearings. If they're are sufficiently worn, one side of the platen roller will be slightly lower than the other.
4. Consider replacing the platen roller. They do wear out and require replacement. Zebra part number 40038M IIRC.
5. Check the printhead parallelism adjustment. The procedure is in the maintenance manual.
Steve
Jul 15, 2008 | Zebra 105Se Thermal Printer
Fabric on hood and stroller seat faded from sun--new covers??
Are you sure you called Inglesina USA. They had sent me replacement parts, i.e. seat cover ripped by the airline company during our travel. The customer service is the best. The number is INGLESINA, USA INC.
363 route 46 West - Suite 260 - Fairfield, NJ 07004, USA
Toll free 888 542 1112
Email: inglesinausa@inglesina.com
Mar 05, 2008 | Inglesina Emma Carriage Stroller
How to change seat covers on a quinny buzz stroller
Try this link
http://www.quinny.com/media/producthandleidingen/Quinny/08.08%20win1299_Buzz4_UK.pdf
The instructions & diagram are in section 6.2 on page 5 of this 7 page pdf document.
Hope it helps!
Nov 26, 2007 | Baby Gear
Baby Gear Logo
20 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
