Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Projection oil spill on main circuit board
So the other day i tore my philips rear projection tv apart because the picture was terrible i noticed that the green and blue tubes were contaminated (the oil inside that is) so i pulled the lenses off all 3 tubes to get a close look and when i did the secondary cover for the fluid reservior on the blue tube popped off and a lot of coolant spilled out onto the main circuit board. the tv was off and unplugged and i tested the coolant for conductivity and it produced no conductivity but the tv no longer turns on. i havent touched anything other that the blue tube none of the wires or connections or any circuit boards...... am i screwed or can i just clean off the circuit board and turn it on or throw the thing away? ps: since the site wont let me choose my model the tv is a philips magnavox 7p4830 w101
  • Anonymous Feb 06, 2009
    i have to same exact problem
  • Anonymous Mar 09, 2009
    i did the same thing havent been brave enough to try turning it on yet.
  • 56 Answers
The coolant in the CRT's is made up of 70% ethylene glycol and 30% glycerin. The coolant is highly conductive and somewhat corrosive. Since you already tried to turn it on im not sure but hopefully you wiped it up first. Take some 100% denatured alcohol and use that to clean the spill you can just pour it on and wipe it off with the set unplugged of course. then let the remainder on the board evaporate (It evaporates very quickly when open) and repeat the process. if your lucky and it did short the first time you turned it on the fuse just blew.
Posted on Mar 11, 2009
A little oiled spilled on the motherboard while changing, is the fuse blown or the tv
go to the honey boo boo channel and your tv will be better. Or just get a new tv becuase you spilled oil on yours.
Sep 14, 2013 | Philips 51PW9363 51" Rear Projection...
I have a Philips projection TV model # 60PP920217F. The TV comes on but there is no picture. I recently changed the coolant in it and spilled a little on the circuit board. ( It was unplugged at the time.)...
The crt fluid needs to be repalced carefully and correctly...This is why we created step byt step instructions for our kits on our website www.TvRepairKits.com . In msot cases if you cleaned up the spill before powering up the tv would be fine....but its not always easy to get all the spill off the board.....look around and see if you find any burnt parts....if so post a photo here....
Feb 07, 2013 | Philips 60PP9202 60" Rear Projection...
Liquid coolant in big screen tv, what is it?
It is a very toxic material called Glycol==if touched it gets absorbed into your body by contact--there to keep the picture tubes cool.
Lens should never be taken apart---if it got on the circuit boards it will short things out and start dissolving leads and the actual board as well.
Jun 15, 2012 | Philips Magnavox 51MP392H Rear Projection...
I need the main board for an 03 60in phillips projection tv since i accidently spilled the coolant on it. since it was a huge pain to get into my room so i would like to fix it and keep it
The boards are the AC main filter (power Board) The LSB (large signal Board) and the SSB ( small signal board) Which board are you requireing? Let me know which one and I can assist you with locating the board you need.
Feb 24, 2011 | Philips Magnavox 9P6034C 60" Rear...
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
Philips TV model 60PP9202/17F veins circuit board destroyed
Email the team at www.TvRepairKits.com - they may have a photo or service manual for that model.
Jun 14, 2009 | Philips 55PP9401 55" Rear Projection...
NO PICTURE ON MY TV BUT I DO HAVE SOUND.
Check all your cables, make sure CRT boards are tight. Make sure you put the black ground wires back on the tubes. Also make sure that no fluid has spilled on the circuit boards.
Mar 27, 2009 | Philips Televison & Video
I have a 52" projection tv it is a phillips. one day i came home and i went to turn it on. now what do i do it wont turn on?
In the absence of any warnings of impending failure, the main power supply has probably failed.
This is likely to be a separate assembly (board) that you could replace on your own. If you remove the back lower panel, follow the AC cord to locate the supply, get the part number from the assembly (there may be two different numbers). The bare circuit board may have a number that was printed in the same manner as the component identifiers and then another number on a label which might contain a 'revision' number too. This board is probably not terribly tought to repair with the necessary instruments but you would be better off buying a new board and then looking for someone to repair the other since it will probably be needed when the replacement fails.
Feb 22, 2009 | Philips Magnavox 51MP392H Rear Projection...
Screen goes black
If you are willing, remove the speaker grill and the rectangular board behind that and look very, very carefully underneath each of the three picture tubes for evidence of coolant drops on the printed circuit boards. These sets have been known to spill a few drops of coolant onto the boards and this causes intermittent problems such as yours. This is my first direction in your case. Let me know.
Apr 16, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
418 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
