Question about Sharp Viewcam VL-Z7U Mini DV Digital Camcorder
Sharp VL-Z7U cassette door will not shut - with or without tape.
Charged battery and it still wont work, removed battery and it still wont work. Problem started out of the blue, all I can say is that there was an error in the tape, I removed the tape, fixed it, and reinserted it but from that moment forward the video camera refused to close. The camera is old but has been used very little over the course of the years. Practically new in use. How can I trouble shoot? I If it is broken, where/how can I get a new part? Also, I need to pass my videos to my computer, what do I need to buy to do this economically?? Please help!
  • Sharp Master
  • 1,680 Answers
Always use the camcorder with the battery and power button on.
Does the cassette compartment close without the tape ? If yes. then we have hope.
Now insert the tape and press to close the compartment as usual. Does it close or reject every time ?
If it rejects, then very slightly nudge the three tiny figures of the mechanism where the two wheels of the tape fit.
Now the tape will sit inside the compartment and lower itself.
If it still ejects, then very slightly press the base metal (where the tape rests once loaded but) without the tape. This is the largest metal piece visible closest to the hinge and door.
The tape will load properly now.
You could face error DEW or 007. Both are known errors.
DEW is really due to moisture in the air. Try on hot dry place.
for 007 error, you would need to carefully clear with one index figure the reading head. Remember all parts of the camcorder are delicate and need carefull handling.
Never use any tools, fluids, fabric or tissue.
Let me know if this solves.
I am looking for USB driver for Windows 7 and the method to extract from tape as I do not have Firewire (Ieee 1394) any more in my laptop and desktop.
Posted on Nov 10, 2013
otacon
  • 1944 Answers
SOURCE: Sharp video camera VL-AH50
Did you try cleaning the tape head?
Posted on Feb 22, 2008
SOURCE: SHARP Viewcam z vl-Z500H-S Camcorder
To transfer video you need to use firewire, not usb. If you use firewire to connect, set the camera to the 'play' icon and then open up a capture program (ie, movie maker) you should be able to just record/capture from there. Good luck!
Posted on Nov 19, 2008
SOURCE: Sharp Hi8 Video Camera VL H410
This camera needs to have the battery recharged in order to remove the tape.
Posted on Nov 20, 2008
satavlad
  • 405 Answers
SOURCE: Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Posted on Oct 26, 2009
SOURCE: Hello! I have a very old Sharp VL-H860 camcorder.
I also have one and it works great but I don't have the audio/video adapter on the side so I cant view my films on TV. I would be interested in your camcorder or maybe vise versa? Regards, Pete
Posted on Feb 07, 2010
I have a Sharp VL-E760 viewcam LCD that records on 8mm tape. The battery no longer charges and I have a tape inside that wont come ojt because it needs the battery. Is the problem the charger itself
The problem is most likely the battery itself when you have finished using your kit and wish to put it away never put it away with a half or fully charged battery as it will not last always run it down and never leave a tape in either.
John www.jvsvisual.com
Apr 18, 2013 | Sharp Video Cameras
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and...
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and I've also tried it with power supply connected?
Oct 04, 2011 | Sharp VL-Z5 Mini DV Digital Camcorder
Oct 18, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
I have a Sharp ViewcamZ VL-Z900. DEW error
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
Sep 18, 2009 | Cameras
Cancorder not wrking-e007 error message
moisture in the cassette holder. Take out the cassette, leave the holder door open for a couple of hours in a dry, warm location, and it should work again.
Sep 12, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
What doe DEW mean? The "DEW" sign keeps coming on and then shutting off..
DEW sign indicates high humidity level inside the camcorder. What you experiencing has nothing to do with humidity, It is a faulty connector on a junction board. Sharp has fix for it.
Jul 12, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
DEW message keeps coming up on camera
Good Luck,
Luwangula
May 22, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
"DEW"
Good Luck,
Luwangula
May 05, 2008 | E.Digital Sharp VL-Z7E Digital Viewcam...
My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Dec 20, 2007 | Sharp Viewcam VL-Z7U Mini DV Digital...
Sharp Viewcam VL-Z7U Mini DV Digital Camcorder Logo
108 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
