Question about Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television
Audio out of control
Audio is great and under control for the most part however in the past several weeks it will either go to Max volume & then shut offr or more
commonly the volume will fall rapidly to zero. We can bring it back by tinkering with the MENUE Audio controls but we are never sure what will correct the problem. Some times shutting off and then restarting will fix it. Any suggestions how to fix?
    Genius:
  • 1,199 Answers
This sounds like the volume control switch pod is going bad and will need replaced! You may try cleaning by blowing short bursts of air into and around button with some high pressureair in a can!
Posted on Jan 20, 2009
  • 744 Answers
Hi the reason for ur sudden rise in volume and fall is nothing but a minute fault in ur circuit board inside ur device. most probably with the help of soldering we can rectify it.
Have a Bose Soundock1 that is possessed.....volume cannot be controlled.............and goes to max volume whether use remote or plus-minus buttons on unit...where does the problem lie....since I have no...
I repair these fro a local store. The best best is to visit www.invebo.com and enter your dock serial number to access the diagnostic and check videos for your particular dock. The volume control problem can be due to several faults. The most likely is the docking board. Invebo sell kits on a buy and try basis. First have a look at the diagnostic videos. You may be able to get it going yourself.
Oct 24, 2011 | Bose SoundDock Digital Music System for...
I'm running windows xp/sp2 on Acer Aspire 3000 laptop. I've had sound working just fine ever since I got this machine, but just sometime in the past two weeks it has quit on me. When I open the volume...
first of all change the play back set from head phone in the audio tab and see if there is mute option on on the speakers symbol on the system tray bottom right hand on the system if yes uncheck the mute
Oct 26, 2010 | Acer Aspire 3000 Notebook
I have been using Plantronics 995 for several weeks. I quit working without any system cnanges. Have tried re-paring, and reset all audio settings to plantronics. Bought replacement unit ( plantronics...
this is a normal reaction ..specially on a wireless device ..the idea is to lower the volume into the computer ..(to max 80%)..and also get into the volume control by double clicking on the speaker icon in the task bar ..and in here look at the mic volume
if there isnt any volume section for the mic..than click options ..than properties..and from the list tick the case for mic in ..and will list the volume for mic..
if the advanced function is on ..check into the advanced under the microphone it is started the mic boost function ..if it is ..and you want to keep it for a better mic reception ..than you have to put the mic on mute to eliminate the static noise..
THis should not mute it for good..but you can make a trial to be sure..
If the advance boost function is on ..and the muting puts it out for good..the choice is to get rid of the boost but usually works if you mute it ..cause only mutes the noise ..
let me know if you didn't understood anything ..
Sep 03, 2010 | Plantronics Radio Communications
Volume at 100% and sound too low to watch dvd tried with several dvds and volume is too low
Just cross check the volume settings in volume controls. All the sliders should be at max level specially Volume Control and CD Player.
If it is fine then there is some thing wrong with the media you are trying to watch or can be problem with audio driver.
Jul 30, 2009 | HP G70-250us Notebook
Kenwood TS50 - Max volume gives very low audio while receiving
It sound like a bad reostat in the volume control. if its under warranty send unit back to kenwood and have them replace the volume control, and possible speaker involvement.
Jul 12, 2009 | Radio Communications
Volume is too low, even then it is turn up to the max.
Have you looked at the menu on your cable or satellite box to see if there is a seperate volume control for the box?
Usually it is found under
Settings>>Audio>>STB Volume
Apr 10, 2009 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Audio problems
Good Day, corilyn;
Several things that you may try:
1. Unplug TV and Cable/Sat box for 3-4 minutes, plug all back in, that's resetting the devices.
2. Some boxes have volume controls, make sure 'box' volume are turned to max.
3. Go into TV's customer menu, go to audio section, make sure speakers are turned on/ set to internal speakers.
Good Luck, Big Irish.
Jul 08, 2008 | Sony Televison & Video
Hitachi AX-M131U several weeks old, remote not controlling, on manual switch on the volume ramps to max, unable to reduce. Have tried reboot and holding on off button. Any advice???? Regards Geoff Law
This should still be under warranty. It sounds like the internal CPU is confused. This could be a simple power suplpy problem or something a bit more complex. Return it for warranty service.
Keep us posted.
Dan
Jun 10, 2008 | Audio Players & Recorders
Hitachi AX-M131U, several weeks old, remote stopped controlling, when switched on manually volume ramps to max. Have tried reboot and holding on off switch???? Any advise. Regards Geoff Law
Hi geoffflaw
try turning it off overnight and do a hard reset. Other than that, It is something you should refer back the the supplier and have the unit replaced.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
