Question about Pentair Pool Products Power Max Commercial Pool Heater 500K BTU LP Copper
Hi, the main water jet adjuster keeps shooting up into the air when i turn the pump on. I had accidently turned the pump on when the water level wasnt high enough but only for a few seconds . Could there be trapped air or something. STYLUS spa power 500. Thanks
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Hi you can Align the jet to a more straight pos.
Posted on Jan 24, 2013
My 2002 yzf r6 bogs down in mid range I have adjusted the carbs any advise on what to do
Hi, Roger and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichner valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper fuel level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue please visit the websites below. Good luck and have a nice day.
http://fullmanuals.com/search/?q=2002+yamaha+yzf+r6
Sep 07, 2015 | Motorcycles
Tip
How to adjust carb settings
Hi Charlie.<br />Operations to be performed depends on how much tuning is needed.<br />Carb setting regulates the ratio between air and fuel in the mixture aspired into the cylinders.Optimal air/fuel ratio is usually around 14(air) to 1(fuel). I illustrated the complete job with cleanup and jet replacement and adjustment. In some situation you do not need to perform complete tuning, which involves taking apart the carburetor. In that case perform basic regulation setup using the two adjustment screws at one side of the carb. Adjustment simple procedure starts from part 2/Adjustment. A good approach is first doing adjustment using idle and thickener screws. Then do the whole tune up if the simple adjustment does not work.<br />The complete tuning is based on carburettor cleanup, regulation of main jet and idle jet and needle setup.<br /><br />Part 1 : Complete tuning and cleanup:<br />1. Take apart the carburettor,<br />2. Undo the float chamber(6 in diag) held by screws (26 in diag).<br />3. Clean bowl with with carb cleaner (put a lot of it in the bow, wait a bit and dispose it-finish the job with a cloth if needed) . Clean floats (nr.4) and other parts using carb cleaner and cloth.<br />4. Use a flat screwdriver to remove the main jet screw (placed in the chamber, held by big golden screw, goes between the floats). Spray the main jet. You must be able to see through it.<br />5. Use the carb cleaner to clean the accelerating pump and all the other parts inside the part. Needle and small parts must be cleaned. Clean the idle jet, which is the smaller golden screws. If you have a compressor blow into the jets (you can blow them even without compressor, but follow H&S).<br />6. If possible replace main and idle jets. Sometimes you may like to replace the jet with a bigger one to get a richer mixture.<br />7. Adjust the needle if needed. A lower needle settings means a richer mixture.<br />8. Remove idle adjustment screw (7) and main adjustment screw(31), clean them screw them back in without tightening and perform part 2. Leave the screws about one and half turn from all way in.<br /><br />Part 2: Tuning and minor cleanup - Here you mainly operate on idle and air (thickener) adjustment screws (8 and 12 in diag)- Start from here, if this does not work, do part one:<br /><br />1) If the engine runs start from idle adjustment: screw or unscrew the idle regulator to adjust the idle speed, the screw is placed to one side of the carburetor and has a spring (part 12).<br />Keep idle least slightly higher than the minimum needed. Example, if the engine stays on slightly below 1000 rpm, set idle to a bit higher with engine revving above 1000 rpm.<br /><br />2) The thickener, placed near that of the minimum screw regulates the air flow. Tighten the screw and unscrew 2 turns from all the way in. Do regulation from this position. <br /><br />Here carburetor diagram and part list. The diagram is taken from service manual. The manual for Lifan 150 (does not include carb setting) has been uploaded here:<br /><br />http://www.mediafire.com/?o3r8x2ujrdbfb6o
on Oct 29, 2011 | 2008 Lifan Delta 250 V Twin
Bike ackes like its running outg of gas and runs on one cylender how do i fix it
Hi, Danny and the usual suspects are:
Apr 29, 2015 | GAS Motorcycles
Maax sa9592 06
Each bathtub has at least one air control on the tub that when opened lets air into the jets that produce the bubbles.
If you are experiencing too much pressure out of each jet, some of the jets if they are adjustable you can turn them down by rotating them left or right.
The other issue may be the water depth in the tub before you are turning it on. Make sure the water level is at least two inches or more above the highest jet.
Rod
US Parts Center
Feb 05, 2014 | Home
My 1994 Sportster is running rich, how do i make it run leaner??
Hi Ctabe8b, and the usual suspects are:
1. Excessive use of enrichner system.
2. Enrichner valve not seated or leaking
3. Dirty air cleaner element.
4. Restricted fuel tank vent system.
5. High speed riding style.
6. Idle speed improperly adjusted.
7. Loose jets.
8. Float level too high.
9. Plugged or restricted bowl vent.
10. Worn or damaged needle or needle jet.
11. Vacuum piston assembly malfunction.
12. Plugged air jets or passages.
13. Excessive accelerator pump output.
14. Main jet too large.
15. Imporoper tire pressure.
Good luck and have nice day.
May 31, 2011 | Harley Davidson FLSTNI Softail Deluxe...
I have a primary jet and secondary jet in the carburator of the 500 gl silverwing . and the jets I have is 75 and 125 which goes where . and what should be the setting on the air jet ?
The secondary main jet (125) goes into the jet needle holder in the center of the carb (needle). The primary main jet (75) is between the secondary main jet and the pilot screw (this one is slightly off center) . The start setting for your air screw should be 1 3/4 turns. Warm up your engine and drive for ten minutes. Adjust your idle speed to 1100 + or - 100 rpm. Now turn pilot screw in or out to get highest idle speed. Readjust idle to 1100 rpm. Now turn pilot screw in till idle speed drops 100 rpm. If pilot screw seats go to next step. Adjust the pilot screw out 1 full turn from 100 rpm drop point. Now reset Idle to 1100 rpm. That is how Honda says to set your air screw. Standard setting is probably sea level and going through the procedure will set you up for the altitude where you ride. Do the adjustment during good weather at the altitude you plan to do the most riding.
Aug 27, 2010 | Honda CX 500 B Motorcycles
Fill tub, press button, hear motor but no bubbles,etc coming from jets
Are the jets open? The center of the jets turn to adjust the pressure of the jets. If this is not the problem, there may be a problem with the impeller in the pump assembly. If you here the pump turning and not buzzing, it could be an air bubble in the suction tube. This tube is the one coming from the front of the pump, if the pump is higher than the tube coming from the tub, or if there is a high spot in the tube, an air bubble is a real possibility. If the tube is level with the pump, there should be no problem with air bubbles and the problem lies in the top part of this paragraph.
Mar 10, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Dies out after holing throttle open after a short while
All two stroke engines are sensitive to fuel. Now that many areas have mandated the use of added ethanol, the small engines are affected more than ever. Use fresh fuel, that is mixed and stored no longer than 6 weeks. The main reason for this is because ethanol will hold water whereas gasoline will not. Because ethanol will hold water, humidity and condensation are more critical to be careful about than ever. Mix your fuel in small batches and keep your can capped tightly and out of the sun. Now about the carb. Most two cycle engines have carb's that have two jets. The jet that is closest to the cylinder is the low speed or main jet. The other jet is the high speed jet. Start the engine and allow it to run for a minute to warm up. Adjust the low speed jet rich enough by turning it counter clock wise to allow for a good transition from idle to high speed without any bog. Next, adjust the high jet for maximum rpm plus 1/4 turn counter clock wise to keep enough fuel available for air temp and load changes. Adjust the high side with the cutting head in place. Clean out the air cleaner and the muffler screen every couple of months and you should not have any more problems.
Aug 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Our A O Smith pump/motor gets airbound everyday
Well somehow air is obviously getting into the pump line. Easiest fix is to move the pump below the water level of the tub and then gravity will keep water in there. If you do have the pump below the water level, then make sure you don't have jets shooting a bunch of air directly at the intake in the tub. If that's not the case and it is below water level, then make sure you don't have a leak in the line somewhere.
Jul 19, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Jacuzzi jet pump doesn't produce much bubbles
you need to turn the air on should be some sort of cap or screw in type thing to let the air in open it
Jan 17, 2009 | Pool & Spa
Pentair Pool Products Power Max Commercial Pool Heater 500K BTU LP Copper Logo
93 people viewed this question
Top Pentair Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pentair Pool Products Pool and Spa Expert? Answer questions, earn points and help others
