Question about Kenmore 24032\24036 Top Load Washer
Beeping dryer & broken hinge on the washer
As like many of you we have the kenmore oasis elite washer & dryer @ about 2 1/2 yrs old the dryer beeps some sequence during drying but does not show CF! the lights on the loud & soft sounds flash back & forth AND... on our washer there is a broken hinge!!! I am glad the ONE person had a good experince with Sears on repairs -- I got some lady with a heavy foreign accent that I could understand her saying it would $75 to get a tech out to look at it!!!!
  • 15,935 Answers
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis F2 (and beeping _
This code indicates a pump issue. First, remove and clean the filter. Then you need to check out the pump. Take a flashlight and look into the suction port on the pump. Check the impeller for broken or missing blades and make sure that the impeller moves freely. If any blades are broken or missing or if it won't move freely, the pump will have to be replaced. Hopefully, it is just clogged, but no matter how diligent we are, some items like coins, tacks, pens/pencils, or other hard items make it into the washer and some can end up at the pump and can damage the impeller or clog up the pump. Hope this helped and best wishes.
Sep 01, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis Washer 110.2709
Mar 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore, Elite Oasis washing machine, apprx. 2 yrs. old has display code F-50 with continuous beep. Technician unable to come out for 1 week. Any ideas?
problem with the RPS(rotory positon sensor)sensor.wait for the manufacturer for repair.make suer the washers not in use as it might lead to F51 error code.
Dec 09, 2008 | Kenmore 24032\24036 Top Load Washer
Drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis 110.6703 is BEEPING!!! ARGH!
repl./// user interface board stuck button common problem
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Cycle Signal Beeping
The user interface button panel has failed and will need to be replaced.
Apr 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 24032\24036 Top Load Washer Logo
159 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
