Question about Bose Wave Radio
CD player in Bose Wave will not shut off unless unplugged and there is no display
SOURCE: bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Posted on May 14, 2008
  • 20 Answers
SOURCE: Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Posted on Dec 31, 2008
BillB-SA
  • 2761 Answers
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Posted on May 19, 2009
BillB-SA
  • 2761 Answers
SOURCE: Bose wave radio won't turn on
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monpoly on repair of these units. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to provide a $200 allowance towards purchase of a new Wave. Before you spend the big bucks on theis trouble-prone product though, you might want to check out the new HD radios -- better sound and MUCH lower prices than Bose.
Posted on May 22, 2009
elix0411
  • 3530 Answers
SOURCE: CD stuck in Bose wave radio/CD player. When eject
It is jammed and there is no way to take the cd out but remove the cover and manually eject the cd out. It is possible that the motor got stuck.
Posted on Oct 20, 2010
My bose CD player is not working my cd are stuck I don,t why
Good luck this should do it.
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Feb 08, 2015 | Bose Wave Radio
A CD is stuck in my bose system How do I get it out?
From an other web site
PART I
PART II
Oct 09, 2014 | Bose & Wave& Music System
How can I manually remove a disc in the bose wave changer
This would be best left up to a repair shop, unless the fate of the Bose is not an issue. :D
Jul 27, 2014 | Bose Wave music system Multi-CD Changer...
I can't get a cd out of my Bose Wave System
I had the same problem. I unplugged the power cord for a few minutes and when I plugged it in again the CD could be ejected. Haven't had the problem since
Martin Hill.
Dec 16, 2012 | Bose & Wave& Music System
I have a Bose Wave radio AWRC-1g. The CD player
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
Mar 21, 2010 | Bose & Wave& Music System
CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Jun 28, 2009 | Bose Wave radio/CD remote control -...
I gave the Bose Wave Radio and 3-cd player to a friend for
Unplug and plug back in. It should go through a automatic process, ejecting any discs that are inside. If all you hear is a mechanical noise, try this again only with the disc trays facing the ceiling.
Dec 29, 2008 | Bose Wave Radio
No power
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monopoly on repairs. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to give owners of broken sets a $200 allowance towards the purchase of a new Wave. Before spending the big bucks though, you might want to check out the new HD radios. Better sound and a MUCH lower price.
Nov 11, 2008 | Bose & Wave& Music System
Bose wave does'nt display light ' can't see the time, Help
Hi
I read that if you hold down the Clock Set button and use the volume adjust you can change the display brightness.
Hope this helps with your rpoblem
Aug 09, 2008 | Bose Wave Radio
Bose Wave Radio Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
