Question about EliteGroup ECS 760GX-M 1.1 SOCKET754 ATX HT 1600 2DDR400 AGP8X LAN SATA RAID ATX Motherboard
I do not remember reconnecting the front panel connector cables
I will apreciate your help
  • osmelendez
    osmelendez Jan 06, 2013
    Thank you very much, for your valuable assistance
  • EliteGroup Master
  • 3,606 Answers
Hello the manual and drivers can be downloaded here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=504
The file maybe has to be unziped.
Just click on the link for download and you need adobe reader to read the content.
Most front panel connections look like this:
I do not remember reconnecting the front panel con - 1_6_2013_8_57_35_pm.jpg
Or this:
But i always recommend to look in the manual.
Hope this help was good
Posted on Jan 06, 2013
  • osmelendez
    osmelendez Jan 09, 2013
    Thank you for your valuable assistense
Motherboard connections (to front panel)
remember the colored wire is +, the + and - should be printed very small on the board near the connectors as well as what they are example (HDLED is hard drive LED) or (PWRLED is power LED) or (PWRSW is power switch) these are examples yours may differ slightly
Jan 31, 2013 | Gateway (4000811) Motherboard
Not getting all the channels- only 2 - 13 and auto set isn't finding the others. Apreciate any help.
Look in the setup menu, set is now set to air or antenna which on cable will only allow channels 2-13------------if on cable or such switch the setting to catv/cable and not to air/antenna.
Dec 21, 2012 | Televison & Video
Dell dimension e510 flashing amber light USB front panel
If you are comfortable around computers, you could try the following to test the power supply. Unplug the cord from the power supply, hold the power button in for about 15/20 seconds, open the case, unplug the 24-pin power connector from the motherboard and jump the Green wire to one of the Black wires, reconnect the power cord and power the system on and if power supply fan and hard drive run, then the PSU should be good. Note: Do not remove any wires from the plug, use a small piece of wire or a paper clip as a jumper. Power supply checks out and the system still does not work, again remove the power cord, hold power button in for several seconds to discharge the residue power, reconnect the 24-pin connector to the motherboard. Remove all the PCI cards, the video card [if applicable], memory, all peripherals, disconnect the data and power cables to all the drives, check that the front panel cable is connected to motherboard, with nothing else connected to the system, reconnect the power cable and power the system on. If you do not get any beep codes or diagnostic lights on the front panel, then it would appear that motherboard has died.
Aug 07, 2012 | Computers & Internet
How to connect the front penal with motherboard
Hi.
To connect the front panel of your case with your motherboard, it is quite easy.
If you have the motherboard manual, I will help you on connecting the cables to the motherboard.
In summary, the pins or connectors for the front panel are on the same spot of the motherboard.
If you don't have the manual, check on the motherboard, THere are like 8 or 10 pairs of pins which are labeled.
The speaker cable is a 4 pin conector. See the speaker's pin on the motherboard.
The Power cable will fit into a 2 pin connector.
The HDD Cable as well
The reset. too..
The colored cable is always +, the black cable is always -
The + usually goes on the first pin of the assigned connector.
For example: motherboard connector is:
The cables goes on the Jumpers area.
You will see somthing like this:
Hope that helps
God Bless You!!
Remember to rate this solution!!
Feb 21, 2011 | Intel Motherboard
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
How to replace the blower motor in a dodge 2001 caravan
Removal & Installation
  1. Disconnect and isolate the negative battery cable.
  2. Remove the right quarter trim panel as follows:
    1. Remove first rear seat. Remove the second rear seat, if equipped.
    2. Remove the sliding door sill plate.
    3. Remove the quarter trim bolster.
    4. Remove the upper C-pillar trim and D-pillar trim panel.
    5. Remove the first and second rear seat belt anchors.
    6. Remove the screws securing the quarter trim to quarter panel from the bolster area.
    7. Remove the screws securing the rear edge of the quarter trim to the support bracket.
    8. Carefully disengage the hidden clips securing the front of the quarter trim to the quarter panel just rearward of the sliding door opening.
      Fig. Removing the trim panel to access the rear blower motor
    9. Disconnect the wiring harness connector from the accessory power outlet, if equipped.
    10. On long wheelbase wagons only, remove the quarter trim from the quarter panel and pull second rear seat belt through access hole.
    11. Pull first rear seat belt through the access hole.
    12. Remove the quarter trim panel from the vehicle.
  3. Remove the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
  4. Twist the blower motor out of scroll housing.
  5. Disconnect the blower motor wiring connector.
  6. Remove the blower motor from vehicle.
    Fig. The rear blower motor is held in place by four screws
To install:
  1. Install the blower motor unit into the vehicle.
  2. Reconnect the blower motor wiring connector.
  3. Secure the blower motor into scroll housing.
  4. Install and tighten the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
  5. Install the right quarter trim panel as follows:
    1. Install the quarter trim panel in position in the vehicle.
    2. Insert and pull the first rear seat belt through the access hole in quarter trim panel.
    3. On long wheelbase wagons only, insert and pull the second rear seat belt through access hole in quarter trim panel.
    4. Reconnect the wiring harness connector to the accessory power outlet, if equipped.
    5. Engage the hidden clips to secure the front of quarter trim to quarter panel rearward of sliding door opening.
    6. Install the retaining screws that secure the rear edge of quarter trim to support bracket.
    7. Install the retaining screws that secure the quarter trim to the quarter panel in bolster area.
    8. Install the second rear seat belt anchor (if equipped), and the first rear seat belt anchor.
    9. Install the D-pillar trim panel and upper C-pillar trim.
    10. Install the quarter trim bolster.
    11. Install the sliding door sill plate.
    12. Install the second rear seat, if equipped, and install the first rear seat.
  6. Reconnect the negative battery cable. Check blower motor operation.
Hope helps (remember to rate this).
Nov 01, 2010 | 2000 Dodge Caravan
Where is the blower motor resistor in a 2001 dodge caravan se. I do not see it behind the glove box. I do see soemthing similar under the hood on the passenger side aginst the firewall but it is not...
Caravan, Grand Voyager, Town and Country, Voyager, 2000-2004
Blower Motor - Removal & Installation
  1. Disconnect and isolate the negative battery cable, then wait 2 minutes before proceeding with the removal. This will effectively disable the air bag system preventing possible personal injury.
  2. Remove the glove box from the instrument panel.
    Fig. The blower motor is located behind the glovebox, behind the blower motor cover
  3. Remove the A/C-heater blower motor cover.
  4. Disconnect the blower motor wiring connector.
  5. Remove the blower motor wiring grommet and feed the wiring through the blower motor housing.
  6. Remove the blower motor mounting screws.
    Fig. Once the cover is removed, unplug the electrical connector and push it through the opening in the housing
    Fig. The blower motor is secured to the housing with three small screws
  7. Allow the blower motor assembly to drop downward to clear the instrument panel and remove from vehicle.
To install:
  1. Place the blower motor assembly into position on the A/C-heater unit and tighten the mounting screws.
  2. Route the blower motor wiring through the blower motor housing and seat the wiring grommet in the hole of the blower motor housing.
  3. Reconnect the blower motor electrical connector.
  4. Install the A/C-heater blower motor cover.
  5. Install the glove box into the instrument panel.
Auxiliary Heater and Air Conditioner
To install:
Hope helps (remember rated this).
Jul 11, 2010 | 2001 Dodge Grand Caravan
My antena wont go down ,and the motor wont go off , even when the car is shut off .
Unplug the harness to the ant.It will not go off,until you replace the whole ant.mass.The gear(plastic)are stripped out,and the motor can not sense that the any.is moving.
Jan 19, 2010 | 1991 Oldsmobile Eighty Eight
Toshiba screen removal
Remove the front speaker grill, remove the front access plate. Undo the front control panel wire harness via plug connector, undo convergence sensor wire harness via plug connector, remove screws holding bottom screen frame. Screen should come off with frame. Some models have retainer clips that hold frame to the front of the cabinet and you must pull the frame off these retainers but I do not think that is the case with this one.
Hope this helps,
Skyassoc
Jun 28, 2009 | Toshiba TP50H50 50" Rear Projection...
Reinstalling Power supply
The green wire with yellow stripe goes to ground anywhere on the chassis. And the black cable should be keyed so that you can only hook it up in one place.
Mar 23, 2008 | Fujitsu Plasmavision PDS-4229 42 in....
Computers & Internet Logo
289 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
