Question about Audiovox SIR-PNP3 SIRIUS Radio Receiver
I have audiovox Sirius radio from 2004 and still works fine. I am having a problem finding a frequency setting while driving from phila. Pa. To Newark de. Can you help me with a frequency setting that won't bleed through ?
    Problem Solver:
  • 10 Answers
I use a wired fm modulator that the fm antenna passes through. When the sirius radio is on it blocks the regular fm signal preventing local signals from interferring. Do a search for wired fm modulator and you should find one. Mine actually fit inside the dash on my pickup.
Posted on Dec 16, 2013
3 Suggested Answers
  • 11 Answers
SOURCE: I can't get my audiovox XCS9 XM Radio to work in my home
Check to see if youre cable is plugged into the line out jack. If that is not the problem you may have a defective cable or home adapter
Posted on May 28, 2009
SOURCE: screen dark
I have 2 of these I got at a yard sale and both had the dim screen
problem.I took 1 apart and everything looked fine.Put it back
together and put it back on the cradle and still did not work TILL I
squeezed down on the connection to the cradle and the radio.It lit up fine.Same with the other one.Its the bottom connection in the
radio that is worn from taking it in and out of the cradle all the time.
My XM radio had the same problem but it was the power cord that
wore out from taking the radio out every night and it powered up eratically like it was shorting out.Try squeezing it down on the
cradle and see what happens.
Posted on May 30, 2009
How does a audovox sirius pnp3 work, how to hook up in c ar
The cradle connects to the cigarette lighter connection for power. There is a connection for the Magnet mount antenna which sticks to the roof. The radio can output a radio frequency signal which you can tune your fm radio to receive. It has a number of frequencies to choose from so you can try to find one that is quiet and works best.
Mar 29, 2013 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
My radio is showing aquiring signal.how can i get it fixed
I heard these have a common problem with the antenna line breaking within the radio. I had it happen and replaced the radio. It's a shame since I'm sure I could have fixed it. I think it happens if the radio ends up hanging from the antenna lead. Any electronic tech or engineer should be able to check continuity from the antenna jack and find/fix it.
Jan 22, 2013 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
What fm station do i use in the car
You need to find a clear radio frequency in your area then in the SIRIUS sat radio you will find a FM transmitter frequency adjustment menu. set it to the same as your fm radio and your all set.
Feb 19, 2010 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
How do i unlock or modify audiovox sirpnp2
call up Sirius and see if they have any manuals for that model to see if they can unlock it for ya or just have Sirius erase the reciever and start fresh by them reseting Hope this helps
Cheers
Johnthetr870
May 15, 2009 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Screen dark
Mar 26, 2009 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Audiovox Xpress XM Radio Home Dock Problems
home dock does not allow the fm frequency generator. it only works in the car dock
Nov 18, 2008 | Audio Players & Recorders
Sirpnp2 reciever gets hot and loses signal.
I had the exact same problem with Sirius radios. I bought two Kenwood DTS-7000S receivers and both were sent back for warranty. Of the two, they only fixed one but by the time I figured out the other was bad, it was out of warranty. Kenwood, along with the repair community state they do fix such units, they toss them out. The thing that gets hot hot hot is the part that receives the Sirius antenna inside your unit. If you're like me and have nothing to lose then I recommend doing some cutting with a dremel and adding a small computer fan. It just takes a light breeze to keep that part cool enough (but it does take some sort of breeze, convection is out). For a home unit, find an old A/C power supply and match it to an old computer fan of equal or less voltage. For car, find a fan that uses 12 volts or less. It's an easy fix, really!
Nov 04, 2008 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Sirius S-50 Portable
Go to device settings - FM Frequencies - select the FM 1 or FM 2 or FM 3, turn the dial to move the FM frequency to that which you want. Press the Sirius Dog to enter this frequency. That's it.
Oct 20, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Aug 18, 2007 | JVC KT-SR1000 SIRIUS Radio Receiver
Audiovox SIR-PNP3 SIRIUS Radio Receiver Logo
103 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
