System is not seaving date
It showing me "f1" and not saving my given bios setting
  • 2,878 Answers
Try entering BIOS and loading defaults (save and exit). This will clear all custom settings, so be sure you are comfortable doing so. Then save with new settings.
You may need a new CMOS battery if you you still can't save.
Posted on Jan 07, 2013
  • 59 Answers
SOURCE: Bios Can't Memorise Seting.
when you enter your bios and make changes you must save those changes before you exit normally this by pressing f10 wich will save the bios and then exit, and reboot the computer.......
i hope this is what your looking for.......if not please clarify the question for me.
Posted on Oct 11, 2008
mysleuth
  • 142 Answers
SOURCE: Microcode Patch Error,Where to download Bios Free
What model compaq?
Have you tried HP.com ? If OEM they will have the driver. If not I use driverguide.com for drivers I can't find. mysleuth
http://search.hp.com/query.html?lang=en&search=++&qt=Intel+Solano+i815&la=en&cc=us&charset=utf-8
Posted on Apr 28, 2009
samspelljr
  • 62 Answers
SOURCE: mercury motherboard pi945gcm cmos setting dose not
This sounds like your battery may be bad or not locked into place fully. Also on the mother board there is a cmos jumper that is used to clear your bios check to make sure the jumper is set correctly an also inspect the jumper to make sure it will make good contact to the jumper posts. Good luck I hope this helps. Also when you set the time in your bios make sure to exit with f 10 key or whatever the save and exit key is for you bios.
Posted on May 15, 2009
camhunksean
  • 70 Answers
SOURCE: unable to save date in m/b bios
make sure your using new cmos battery not yet been use and then set date in your bios and save it after finish.
still doesn't work?
try update your cmos that migth be the problem note! remember always take care of the risk on updating flashing cmos on power interuption never power off if still flashing. or if you update and flush it before it might be a bad flash of your cmos try bring it up to early state or restore your backup cmos firmware or download it to its main manufacture
Posted on Jul 01, 2009
  • 7 Answers
SOURCE: bios settings changed automatically
Have you tried to update the bios? One of the latest versions BIOS Update [DPP3510J.86A] 07/15/09. But verify to ensure that you download the correct bios for your board. There are a few options available. Also check the jumper pins for the bios on the motherboard normal or (default) setting is pins 1-2 jumped.
Posted on Nov 10, 2009
Dell poweredge 830 cd-rom unknown bios
Enter the set up (BIOS) menu by tapping the F2 key. Hold down the <Alt> key and depress the <E> then the <F> keys in succession. This will force the motherboard to load default settings and also force the motherboard to redetect all IDE devices. Note: The selection for the floppy drive will be set to ON. If you do not have one then you must disable floppy in set up (BIOS) menu.
Apr 13, 2012 | Dell PowerEdge 830 Server
I changed the battery on motherboard, it started and showed "checksum error press F1 to continue" pressed F1 everything ok, set up the time, date then restart the system, it is working but there...
You should press Delete to access the BIOS setting.
First you need to change the time setting.
Then you must change the Boot sequence from Removable Device to HDD where your first boot device will be your HDD which is where your Operating system is installed and the next thing your system will seek after the POST.
Hope this helps. Any vote is highly appreciated. Thanks =)
May 30, 2011 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Everytime we boot up our computer it says press f1 to do something and f2 to enter setup mode?
generally an indication that something is wrong in the system setup. Press F2 and enter setup, check the time and date settings and the system event log (If BIOS has one) for incorrect settings, also check and see if the BIOS shows a hard drive installed.
If time and are wrong, set them to correct and save settings. If system keeps losing time and date after power is removed, then the backup battery may need to be replaced.
If HDD is not detected, then reseat it. If still not detected replace it.
Dec 10, 2009 | Dell Inspiron 600m 1.6GHz Pentium M...
Cant get 4600i started. powers up but will not get past intro screen. screen shows F1 to continue and when i press F1 it tells me to press it again to retry reboot, F2 for setup options.
you need to go to cmos or bios setup, set all the date and time and proper boot setting there save and exit, it is a cmos or bios failure that causes these problems try replacing the cmos battery if the message still continues
Nov 22, 2009 | Dell Dimension 4600 PC Desktop
I INSTALLED A NEW CMOS BATTERY BUT STILL NO EFFECT AFTER THE SHUTDOWN WHEN I RESTART IT THERE IS AN ERROR ..LIKE THIS CMOS SETTINGS WRONG ...CMOS SYSTEM TIME/DATE NO T SET...PRESS F1 TO RUN SETUP...PRESS...
Just replacing the battery will not set anything. You have to do the setting of the values. If you can run setup by pressing F1, then do that and set all the settings and then save before exiting. Make sure you save the settings by choosing the correct exit and re-boot option.
If the settings cannot be set nor saved, then make sure the poser is off or pull the plug from the wall outlet, then short the bios with the jumper to short the bios. This will reset the bios to the default settings. Turn on the system and then go to the bios settings and set the settings. Then use the reboot option to save the settings.
Nov 06, 2009 | ASUS P5PE-VM Motherboard
Asus motherboard bios version1104
Whether it shows your cmos checksum error press F1 to continue or f2 to load default.? If this is the problem than kindly switch off the system check for the cmos battery and change the cmos battery and set the date and time properly in the bios and save it by pressing F10.This will resolve your problem.and if not than check the jumper setting on the motherboard is it set to clear cmos and if so kindly remove and set it properly to adjacent jumper ok. Have a nice time.
Dec 04, 2008 | Computers & Internet
When i start the computer it says "strike f1 to retry boot, f2 for setup utility" how do i fix this?
press F2 and enter BIOS menu - find Exit Menu and select
'Reset to defaults' -
Check the time and date setting in BIOS menu - correct it if wrong.
then Exit and Save.
If time/date was wrong - you may need to replace the internal button cell battery on the mainboard.
Aug 09, 2008 | Computers & Internet
Faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
David Payne
David Payne
