Question about Troy Garden
Troybilt tb525cs trimmer want run unless choke is on
Want run unless choke is on. has new plug,cleaned muffler,replaced primer bubble.still no change
  • erick patterson Jan 08, 2013
    I REPLACED THE FUEL LINES YESTERDAY THAT MADE IT RUN LIKE NEW
hunter19_46m
  • 7482 Answers
SOURCE: have a troy built tb
Sounds like you will need to clean your carburetor. Sounds like you have gotten some trash in the cauburetor, check your fuel container to see if more trash is in it.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I have a Echo gt200r
Hi bdtyler72...
Sounds like you still have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor properly cleaned and rebuilt that should solve your starting problem.
This is a FREE answer,Please take time to rate me
Posted on Jul 28, 2011
evwood
  • 50 Answers
SOURCE: poulan 32 cc string trimmer mod.# ppb100
After you have done all the suggestions #1 gave you, make sure the tubings are good. They deteriorate over time. Also be sure to check the spark arrestor. This is part of the muffler. Good luck
Posted on Nov 16, 2008
#1 Taper
  • 1041 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
SOURCE: how to change trimmer ine in tb525cs
You need to unscrew the black bumper button. I believe it is counter-clockwise. Mine was very tight and took a pair of channel lock pliers to loosen.
Posted on Jul 19, 2010
I have a Troy-Bilt XP grass trimmer...only run on full choke, I replaced the fuel filter because there was plugged.Still no help. I ordered a new carb and replaced it and still had the same problem.
When you installed the new carb did you adjust it for your engine? Idle control, idle mixture, fast misture? Running only with choke indicates that engine is not getting enough gas routinely via the main jet.
Sep 22, 2017 | Troy-Bilt Garden
CRAFTSMAN 2-CYCLE TRIMMER MODEL NO. 316.711190 WILL START BUT WILL NOT RUN UNLESS CHOLE IS ON.
OK, lets slow down a bit. First look at the primer bulb of the carb. Depending on the type, there should be 2 or 4 screws right by the primer bubble. Carefully, remove the screws. The top section with the bubble and one fuel line will come off. In between them is a gasket and diaphragm. Look at the lower half and you will see a very small screen. Get some carb cleaner and spray by the screen but not too close. This is where most of the dirt collects. You might need to remove dirt by hand. Then close the carb. back up. Place gas in the tank, but leave the cap off, so you can look inside while you press the bubble slowly. You should be able to watch gas flowing back into the tank at a steady stream. Then place cap on and follow the start up instructions. Get back to me when you can.
Apr 01, 2014 | Craftsman 25cc Gas Line Trimmer
Stihl FS85 starts fine, But not take full throttle
Pumping the primer bubble while the engine is running should cause the engine to over fuel and stall (if the tuning is correct). Sounds like its not fueling enough, pumping the primer is forcing fuel through the carb causing the engine to pick up rev's, but this is soon exhausted which is why it wont rev on the throttle.
* Check that the fuel line is not damaged and drawing in air. (if this is intact try the next step)
* Strip and clean the carb. Replace any diaphrams if needed.
* Check gaskets seal between carb, air filter and cylinder.
Just out of curiosity what standard carb settings did you use.?
May 23, 2013 | Stihl FS 85 Weed Eater
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Primer bubble is cracked.minimal fuel is getting to carburator. when it starts it will run a few seconds then cut off.Won't run except in full choke. Please Help
The primer bulb needs to be replaced. It is introducing air to the system and not allow fuel to flow. Replace it and check the fuel lines while you are at it.
HTH
Good Day
Oct 29, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi 790r i have changed the gas line and the primer bulb . the primer will mash in 1 good time and then gets very hard to mash in . i fully choke it and it will crank but only for 3 seconds until it...
You cannot flood the engine by pushing the primer bulb too much, unless the hoses are hooked up backwards. The primer does not push gas to the carb, it sucks gas through the carb and returns it to the tank. Top barb on primer is the hose coming from the return side of the carb and the bottom fitting is the hose going to the return fitting on the tank. Look inside tank, it is the one without the filter on it, just a flange with a hole in the center.
If you can see gas and air bubbles moving through the primer and into the tank the hoses are on correctly. If you see bubbles going in the correct direction and then reversing when you remove your finger from the bulb, then the check valves in the primer may be bad. Replace primer.
When you say the primer "gets hard to mash", do you mean it is hard to push in or is it very slow to refill and return to the home position? If it is hard to push in and the bulb is full of gas and the hoses are on correctly then there must be a plug in the line going to the tank or the vent in the gas cap is not working. If it does not return, then it is most likely a plugged filter, plugged line from the tank to the carb, plugged screen inside the carb or a stuck needle valve. The primer is creating a slight vacuum to pull the gas through the carb, which is what the carb does when the engine is running. If there is a full or partial restiction on the supply circuit neither the primer nor the carb can pull enough gas for the engine to run. May need to disassemble carb and clean out any varnish, gunk or plugged ports/jets. Use spray carb cleaner. May want to think about a diaphagm and gasket kit if you do it yourself. If you do not feel confident in taking apart the carb, then take to a repair shop.
May 05, 2009 | Garden
Homelite zip start 2cycle trimmer.
I had this same problem, would run a couple of seconds, stop, and you couldn't start it again.
Had good gas/oil mix 50:1 and 25cc Homelite. Had replaced the fuel filter, gas, spark plug, and took carb apart and cleaned with carb cleaner and primer bulb worked fine. None of that fixed it. What did? Take the muffler off and see if it will start and run with the muffler off. If it does, chances are the muffler is clogged. Also check the exhaust ports and clean them out if plugged with black oil carbon residue.
My muffler was clogged up, took it off, cleaned out the exhaust ports, there was some oil that was in the muffler(oil that didn't burn during combustion). It now starts and runs like a champ on first or second pull.
Mar 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Poulan 32 cc string trimmer mod.# ppb100
Try checking the fuel filter, not sure of the exact location but should not be to hard to find. Try looking in the gas tank if it's not readily located. If small 2 cycle engines sit for any length of time ( 30 days or so) with fuel in them the filters can become clogged. If your not going to use it for extended periods or storing it for the winter make sure you drain the fuel tank and run the carburetor dry.
Nov 07, 2008 | Poulan 25cc 2-Cycle Gas Powered String...
Garden Logo
115 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
