I have an LG S24AHN. My a/c works but sometimes. It comes up with an error CH62 after running for about 15 mins. Have checked the fan and it is not stuck. Have replaced the Circuit Board and the same problems persists. Can anyone advise? Is it a problem with the Heat Sink?
4 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: my LG split system Model
It's communication error between indoor and out door. Make sure you have command from indoor by checking volts in out put of indoor or in put of out door. If not, Check your PCB and also loose connections.
Posted on Dec 19, 2010
SOURCE: Heat coils in central air
no heat coming from my central air unit when i cut the heat on. Just cool air. what should i do.
Posted on Feb 25, 2009
  • 19 Answers
SOURCE: not sure of settings
On the remote, press the mode button (might also be labelled master control) until a snow flake appears. Then set the temperature for 23 degrees. The speed of the fan can be changed by the fan button. All functions should cycle through so if you go too far, just keep pressing the button until you get back to the desired setting.
Posted on Jan 21, 2010
Diplomat Gas Oven cuts off after few mins
The oven is probably overheating and shutting itself off to prevent damage/fire. If the cooling fan isn't running. Check/replace the thermostat that switches the cooling fan on.
Aug 02, 2014 | Hotpoint Diplomat Oven Grill Selector...
50 inches LG PLASMA TV TURNS OFF AFTER 15 MIN.
A blown capacitor might not be the reason. After 15 to 20 minutes of work, the temperature inside the set do rises much, this kind of fault can occur. Check its cooling fans.
Jun 25, 2013 | LG 50PT350 50 in. Plasma TV
My LG REAR PROJECTION DLP keeps on shutting off i change the lamp a year ago and dont know what the problem is
Check the Lamp Fan, if it is defective set will work for a few mins then shut down.Watch the Fan if it starts to run ,then stops when set is trying to come on with lamp then you need to replace the Fan.
Jun 09, 2011 | LG RU-60SZ30 60" Rear Projection...
My LG split system Model S24AHN switches itself off after a minute or 2 and CH 5 flashes on the screen. What cause this and how can I fix it?
Dec 19, 2010 | LG Heating & Cooling
Not sure of settings
Jan 18, 2010 | LG Heating & Cooling
Cooling fans dont turn on
thats your main radiator fan, meaning if it don't come on then vehicle will get hot. check the fan for operation by letting the vehicle idle for a while, keep check the temp gauge and what for the fan to come on at the half way point.
Jul 30, 2009 | 1995 Acura Legend
The fan stops running
check whether the power saver mode is on. put it off. or some timer must be on. stop the times. it wll be rectified
Jul 27, 2009 | Heating & Cooling
Stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Jul 25, 2009 | Heating & Cooling
TOSHIBA SATELITE 215 NOTEBOOK HEATS UP.
One quick and easy fix you can do is to go get a can of compressed air and blow out the vents and fan area under the notebook. Sometime when there is a lot of dust in them they overheat pretty quickly and shut off. Just like you said happens.
May 21, 2009 | Toshiba Satellite A215-S7422 Notebook
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
