Question about Dell Vostro 230 PC Desktop
I have a dell vostro 230 slim and I can not get a picture from the on board video what can I do. And if I get a pci-e low profile video card will I half to change the bios for it to see it?
What are some options I have to fix this.
  • Dell Master
  • 7,627 Answers
If you are sure the graphics adapter is gone, you have check ALL cables, connections, try another monitor/ cable, drivers: http://www.dell.com/support/drivers/us/en/04/Product/vostro-230. A Graphics card is a option, make sure to look at the min. requirements for the graphic card, the power specs are important. I would not change the BIOS if Dell does not require it.
Posted on Jan 06, 2013
5 Suggested Answers
jose_v17
  • 229 Answers
SOURCE: Compatibility of PCI-EXpress card for Dell GX280 (Small Dextop)
So if this is a slimline pc you are kind of limited in upgrade options
space being the biggest , then being followed with cooling ability, the best advice I can give you if specs say 350 is needed i wouldn't chance having the card pull more of a load off of the PSU than what is rated for it. Hope this helps
Posted on Mar 24, 2009
  • 16 Answers
SOURCE: Dell Optiplex GX280 Video Card Install Problem
You hit that one right on the dot.  ATI website showed the specs for that graphics card you installed as needing a 300 Watt power supply.  Good news though... I researched newegg.com and I believe I found your 300W power supply.  There are 4 different Optiplex gx280 designs with 4 completely different power supplies.  Since you bought the low-profile video card, I believe you have the slim computer case and this power supply should work for you...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817374002
Good Luck
Posted on Jun 11, 2009
dante777
  • 623 Answers
SOURCE: Optiplex 520 pci video cards Dual monitors & Vista
There is a work-around for Vista. Look here.
A little bit down you can read:
"A user could force the installation of a XPDM driver for each of these devices, and therefore get heterogeneous multi-adapter multi-monitor to work as in Windows XP."
If you can go that way depends mainly on the manufacturer of the video card driver.
If you are going to sell all your nice 22" monitors - let me know...;-)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Jul 23, 2009
ahsan322
  • 38 Answers
SOURCE: dell dimension 2400 will not boot. Diag lights A & B amber.
first of all dnt take tention,
firstly remove ur all RAMs then reboot ur system. after that flash the motherboard cell.
after that reboot ur system, if yous system have same problem then plug out all hadware of ur system except VGA, RAM, Hard Drive,and key board. after this u may restart ur PC and then check it out.
hope so ur problem is solved
Posted on Aug 26, 2009
How to correct a bad setting in bios video card on vostro 230
Press F2 on boot up to enter the BIOS. More info can be found at Product Support Dell US Manual
All other info Product Support Dell US
May 19, 2014 | Dell Vostro 230 PC Desktop
I am getting an amber light on my Dell Vostro 230 desktop and it won't boot up
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Sep 17, 2013 | Dell Vostro 230 PC Desktop
HP slimline 7320 needs larger video card
I checked out the specs on your computer, and it does have a single upgrade slot, of the PCI variety. Don't confuse this with PCIE, which is totally different.
To make it fit in your PC, some video cards come "low profile ready", which means the circuit board is narrow enough, and they include a narrow bracket for mounting in the slim computers. They leave it to you to switch out the bracket, which is usually a couple of screws. Pretty easy to switch out.
There is two major drawback to this suggestion:
  1. PCI is not the preferred connection for graphics cards (it has a slower interface, and thus lacks pretty much all more powerful cards).
  2. You may have to remove an existing card (a modem, or network card, perhaps) to make it available.
If you are a gamer (you want to play 3D games on it), I would hold off and save your pennies for a more capable machine. This is not it.
Otherwise, there are several acceptable (not great, but OK) low profile cards out there. Look for low-profile and PCI in the description. I know newegg has a bunch of different models available in the $35-175 range. Just make sure whatever you get is low profile & PCI.
That should get you going. Let me know if you have other questions.
Dec 21, 2011 | Computers & Internet
Diablle Vostro 220 onboard video card
Installation of a PCI-Express 16 video card in the motherboard will automatically disable the on-board video.
I'll you should need to do is connect the video to the new card and load the drivers
Dec 05, 2009 | Computers & Internet
I recently bought an old dell optiplex sx 270. I
You are limited in the choices for video card The Optiplex GX270 only has a 160W power supply Not only that but because of the slim case, you're most likely limited to low profile video cards. That means the choices will be extremely limited & not very good. Even after the upgrade, you'll most likely have to stick with older games. follow this link to buy low profile video cards http://www.directron.com/lowprofile.html
Nov 28, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
How to intall pci card low profile
no there is a stand off board inside so that the video card or other pci cards will fit in sidewaz
Oct 10, 2009 | HP Compaq Business dc7600 PC Desktop
Good Luck
Jun 10, 2009 | Dell OptiPlex GX280 PC Desktop
9600gt video card into dell vostro 220s not working
THIS CARD MAY NOT BE COMPATIBLE TO THE MOTHERBOARD AND OR ANOTHER VENDER VIDEO CARD
Jan 23, 2009 | Nvidia GeForce 9600 GT,, PCI Express...
Help with finding a low profile video card
you will not find any good grpahics card on the pci platform anymore. the interface that you have seen is the pci-e interface which is the latest in use. better stick with the one u already have,
Dec 11, 2007 | Computers & Internet
Upgrading a dell gx260
when buying you need to ask for a low profile pci card for sound or video
What alot of manufacturers do is put in 2 plates which unscrews from the boards , which allows for either a regular tower installation or you use the short one for the desktops
here have a look at this site
http://www.google.com/products?hl=en&resnum=0&q=low+profile++pci+card+for+desktops&um=1&ie=UTF-8&checkout=1&sa=X&oi=product_result&resnum=1&ct=checkout-restrict
I hope that is helpful or a fix for your problem
Nov 24, 2007 | Dell OptiPlex GX260 PC Desktop
Dell Vostro 230 PC Desktop Logo
71 people viewed this question
Alun Cox
