Question about Philips 50PF9956 50 in. HD-Ready Plasma Television
No picture, just audio
I did see a video image. Could this be the inverter?
  • 362 Answers
Hi
I am happy to help, we need to check the backlight inverter.
  1. Turn tv on and get to a point that you have audio.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely at the screen for a very dark video image.
If you see an image you have a bad inverter, you should be able to replace it yourself. I can walk you through in chat. Let me know your findings. Lone99star
Posted on Jan 20, 2009
  • Jason Morris Jan 20, 2009
    Yes you have a bad inverter, I will check with parts vendors and get you a price on replacement board.
    Lone99star
Samsung tv un46eh5000fxzc has a very dark picture
Back light problem. Check and replace the damaged components at its back light inverter circuit board. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 25, 2017 | Samsung Televison & Video
Can a tv inverter board cause tv to not display
inverter board may be used to power backlight for the lcd display. If it is similar to laptop lcd displays in functionality .
http://www.ehow.com/how_7501465_check-tv-inverter-board.html
Apr 17, 2015 | Coby 40 TFTV4028 LCD TV
How to fix my screen?
check and make sure your video card is seated properly if it is my best guess without doing any testing is that your video graphic card is broken
Jan 08, 2015 | Samsung 700Z COREI7-2675 15.6 8GB 750GB...
No video,screen is dark,there is audio
Hi doubles,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 24, 2011 | LG 42PJ350 42 in. TV
The lcd inverter appears to be out no backlight can hear audio and see screen in light also the usb and the touchpad does not work
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 22, 2009 | Acer Aspire 5100 Notebook
Picture goes off within seconds once turned on
You will have to do some detective work here. If you are getting audio but no video then
the next time this happens take a strong flashlight and hold it against the LCD screen.
Look closely around the edge of the flashlight and see if you can see an image.
If you see an image then the problem will probably be in the inverter board or the power supply board to it.
Mar 06, 2009 | LG 42LG70 42 in. LCD HDTV
No Picture
Hi washingtonrm,
Jan 22, 2009 | iLO 2600 Television
My 26 inch insignia has sound but black picture
Hi freelingtrapt,
Jan 22, 2009 | Insignia LCDTV26 26 in. Television
Picture will not come on. only sound
Hi jsevcik897,
Jan 20, 2009 | Philips 50PF9956 50 in. HD-Ready Plasma...
Philips 50PF9956 50 in. HD-Ready Plasma Television Logo
170 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
