Question about Singer CE-100 Futura Computerized Sewing Machine
Machine cannot start due to abnormal conditions
Riccar 525 - makes a birring noise when I press foot pedal but the needle does not go up and down. I can turn dial at right hand side ok.
Sounds like the motor is trying to run but the other machine parts are not moving. If your machine is an older mechanical (not computerized), then it's very possible the machine has seized due to lack of regular cleaning and oiling. Avoid trying to run the machine in this condition as it can damage the motor.
Wheel on right side that controls the needle up and down is very tight...
May 22, 2018 | Riccar Sewing Machines
Haven’t used my machine in a few years ?? the bottom feet are not moving fabric???
Remove the plate & give the jaws a little drizzle amount of oil & let that seep in then gently hand crank the machine until the jaws start moving, using cotton buds to apply the oil is a better way of applying the oil, but don't over do the oil or the fabrics will be ruined upon using it again, wipe of the excess from the jaws & run scrap fabric through until no oil residue is visible at all... I hope this helps....
Feb 20, 2018 | Sewing Machines
My zig zag won't work on my older viking machine. How can it be fixed?
How long since your machine was thoroughly cleaned and oiled? Mechanical machines need periodic TLC to keep them in top operating condition. Could be the machine has seized due to dried-out old oil.
Feb 15, 2017 | Sewing Machines
I am sorry. The 60629850 Singer Sewing machine was told to me that it was born in 1884 not 1883! Please help me find a manuel for this machine in original condition!
In the 1900s there were no manuals as the seamstress would be taught how to use the machine the shop selling the product. A Singer sewing machines are all very similar and an older seamstress would be able to share information, I would have thought.
There may be someone here willing to help;
http://www.stickssn.org/site/media/Effective%20Collections/Master_Catalogue_Sewing_Machines.pdf
Jan 21, 2017 | Singer Sewing Machines
FEED DOG DOES NOT SEEM TO BE MOVING
you would have to check with a sewing machine shop in your area and see how much it would cost to service the machine and they can tell you if parts are still available
May 05, 2016 | Sewing Machines
My Kenmore sewing machine model 158.12271 is locked. When I loosen knob on right side of machine, as you would to wind bobbin, everything spins. When I tighten knob....nothing moves and motor is...
Your machine is an older mechanical. As such, they do need a periodic complete oil. Sounds like your machine has seized due to old oil that has dried. Avoid trying to run the machine in its current condition as it can damage the motor. Most sewing repair shops would be able to work on your machine.
Mar 03, 2018 | Kenmore Sewing Machines
I have an industrial singer model:cs-4002-6. HOW MUCH IS IT WORTH
Value depends greatly on location and condition. Shipping a machine used machine is usually not cost effective due to weight. I often see this type of machine in working condition with table and motor sell for under $200. Kind of tragic when you consider what it sold for originally. To determine demand in your area, look on Craig's list for industrial sewing machines and remember that older machines are less desirable than Juki, Consew or other modern copies due to parts availability.
May 16, 2011 | Singer Sewing Machines
Singer CE-100 Futura Computerized Sewing Machine Logo
50 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
