Question about Reddy Heater-30-55,000 BTU Variable
55,000BTU R55c Multifuel auto start.
Blows raw fuel when trying to start. Take top cover off and it will start. Will run when putting top back on. Will not start again unless I take top cover off. Has two screw, I assume adjustments, on the end One is bigger than the other. How are they used for adjustment. I don't have a manual.
  • Anonymous Jan 20, 2009
    I have a reddy heater 55 55,000 btu it start up and runs for a few minutes 10 or 20 minutes then shuts off .? Their are two screws on back where the motor is are they adjusment scews if so what do they control?
  • Anonymous Jan 21, 2009
    junk it
Check this site out http://reddyparts.com/pressure.htm should help you out I think.
Wolf
Posted on Jan 21, 2009
Car blows raw fuel from tail pipe
If you can get the car to Orielly's or Autozone they will check the OBD1 system for free to help you fix the problem.
This sounds like the fuel is not burning in the combustion chamber due to a lack of spark, excess fuel and smoke. On vehicles with a coil pack for every cylinder you would replace the coil pack but on your vehicle you have two coil packs, one for each side. If a coil pack is bad this would cause your problem (left or right). The auto parts people should be able to help you further, but I think this is the problem. (I had a similar problem).
Good luck!!!
Nov 08, 2012 | 1994 Mercury Cougar
What is a multifuel stove?
Multifuel stoves can accommodate various fuels including white gas, unleaded auto gasoline, kerosene, jet fuel and diesel. They tend to cost more than any other camping stove.
Sep 10, 2012 | Coleman Camping, Backpacking & Hiking
Ignition fuse keeps blowing, sometimes I drive 130 miles till it blows n sometimes 1/4 mile and sometimes as soon az I replace it it blows orther times I put a new fuse in and the fuel pump runs and when I...
I'd replace the fuel gauge sensor as a first thought, however, before doing that, I'd meter the sensor the times that it blows immediately.
You may want to check and see if it blows at a specific fuel level.
Trace the wiring to the fuel guage itself and make sure the wire isn't intermittantly shorting somewhere like where it runs through the headlight (if it does) and where it goes into the fuel gauge (or low fuel light).
You seem to have tracked the problem to the root area and just need to isolate it to the specific area.
Jun 28, 2011 | Harley Davidson FLHRS - FLHRSI Road King...
When I turn the unit on, it blows raw gas out and only lights sometimes.
When mine did this it was contaminated fuel. What I am saying is that from storage these will build condensation (water) in the tank. So I emptied mine out in to a clean five gallon bucket and observe, Fuel floats on top of the water and you will see the water bubbles under the fuel. If this is the case you need to dry out the tank as best as you can and then put fuel back in it. Now you can carefully siphon off most of the fuel and reuse it just be careful not to **** up any of the water. If this is not the problem you need to go over the fuel delivery system and clean it out completely
Jan 07, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Loaned my heater to neighbor, he ran it out of fuel. put more fuel in and it started spitting raw fuel and firing intermittently. I cleaned igniter plug and blew out igniter hole and fan motor,generally...
Hi you will have to clean it all out till you get all the stuff ou tof it it has pulled all this through from being run dry , you not far off just more to do
Feb 04, 2010 | Heating & Cooling
1991 toyota 3L V6 Overfueling, raw fuel pouring out exhaust pipes
The valve cover gasket change is related only to the extent of needeing to remove something else . There is the fuel pressure regulator and the MAF SENSOR talks to the ECU telling the computer how much fuel is needed for proper mixture of thre air passing into the intake. It is the first sensor in the intake duct coming out of the sir filter. Make sure all the injectors are secure in wiring connection and look around for any other that had to be removed. All plugs mean it isn't just one injector. Unplug and replug the MAF. cHECK THE THROTTLE POSITIO SENSOT. iT RIGHT THERE where the fuel likage is attached.
Jun 02, 2009 | 1994 Toyota Pickup
check if your O2 sensor is working that is the thing telling computer how much fuel to put into motor it is on pipe close to motor your O2 sensor tests how much oxygen is pipe while running and tells to increase or lean back fuel
May 26, 2009 | 1994 Toyota Pickup
Runs rough raw gas come out tail pipe
It almost sounds like to much fuel pressure.Check fuel pressure it might need adjusted down to factory settings
Apr 09, 2009 | 1994 Chevrolet S-10 Blazer
THE HEATER STARTS THEB BLOWS ALOT OF SMOKE
There are any number possibilities for intermittent running.
1. Bad ground connection at the Ignition Device (transformer, spark box)
2. restricted fuel filter causing fuel starvation
3. crack in the plastic end cover
4. crack in the airline
5. crack in the fuel line
6. crack in the nozzle adapter
7. water in the fuel
8. Others I’m sure I left out
You must be the one to troubleshoot & find the cause.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heating & Cooling
Reddy Heater-30-55,000 BTU Variable Logo
410 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
