Question about Siemens KA62DV50GB Side by Side Refrigerator
I have a problem with the ice maker on my Siemens KA60NA40 side by side fridge freezer. I went on holiday and did not isolate the ice maker. On my return I operated the unit and some ice was discharged but I found a small plastic cube with holes that are blanked off at the base. There is evidence of the part breaking/shearing off. It is about 12mm cubed with a taper on one edge. I then withdrew the ice box and found it frozen up with ice cubes and water. I cleaned the unit and defrosted the freezer. The ice tray operates on the test button and the ice cube conveyor operates correctly. Therefore the motors seem OK. The chilled water delivery is fine and the ice tray contains ice cubes but the unit will not operate automatically. If I activate the test button the tray turns as it should but the cubes do not drop into the ice box. Any advice will be welcome. square
3 Suggested Answers
Sebin
  • 712 Answers
SOURCE: its a side by side Siemens KA62DP90 GB
This may be due to any small leaks in the water supply line going to the ice maker. The leak caused water to flow outside and a part of it was frozen by the freezer. That is what happened. It is having only a simple repair to replace the pipe. But since this one is new, you may be well inside the warranty period. So don't take any risk. Just contact your dealer. Else it may spoil your warranty agreement.
Posted on Apr 22, 2010
SOURCE: siemens defrost controler
turn the defrost cycle switch till the compressor shuts off, if the defrost heater starts working you know it's the cycle switch. Sometimes the thermostat has to be showing a need for the heater to even come on. In
this case you might have to jump out the thermostat to make the
heater come on. If you thaw the back of the freezer and visually inspect the heating element it can sometimes have burnt ends that will tell you
it is bad. You could also use a voltmeter and track where the voltage stops. But make sure the Thermostat and defrost cycle switch will be
calling for heater to come on.
Posted on Aug 23, 2012
Hi I have a siemens fridge freezer and ice maker is leeking water and it come out of despencer serial number is ke07ze26690373 can you help
sounds to me that the water control valve is leaking on the back of refrigerator and causing water to overfill the ice maker. Need model number not the serial number should talk to someone about replacement parts
APPLIANCE 911
Jan 01, 2016 | Siemens Refrigerators
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Siemens Refrigerator model KA58NA70NE The ice maker section is not working. Please advice how to fix it.
I had the same problem and fixed it by changing freezer fan found underneath the freezer inside body, just behind the ice delivery/crusher motor. You need to open all the inside upper components like ice dispenser, ice maker, ice crusher motor, lamps assembly and finally the rear upper inside body cover. First, check whether or not the fan has strong air ventilation before trying to change the ice maker fan motor.
Feb 04, 2011 | Siemens KA62DV50GB Side by Side...
The freezer has been melting ice-cream
The first thing to do is, give it a FULL DEFROST, the old fashioned way. set it for defrost or unplug it and melt all of the ice out of the air tunnels below and behind the freezer. In the refrigerator section, you will find a hole that you can stick your finger into, normally in the wall next to the freezer. This has the defrost timer in it. Give it a full turn CLOCKWISE to make sure the contacts aren't stuck. When you are sure all the ice is melted and the water has been dried up, power it back up. It will run properly if nothing actually went bad. The next step, if it doesn't work right, is to replace the thermostat.
May 27, 2010 | Samsung RS2630SH Side by Side Refrigerator
Its a side by side Siemens KA62DP90 GB freezer/fridge.it is new, i just turned on the fridge yesterday and also the icemaker and found my whole freezer frozen the next morning with water seeping out.
Apr 22, 2010 | Siemens KI20R440 Refrigerator
American fridge freezer siemens KA58NA50GB. Freezer not freezing
If you are not capable to do that much better to call service Engineer to avoid big damage of your Freezer.
Apr 03, 2010 | Freezers
Whirlpool Freezer not freezing at all
The evaporator is located behind the back wall of the freezer.If the fridge part is ok,you may want to check the dial settings.If they are ok,then check the air flow into the freezer,you may have something blocking it.If that checks out ok,you may have a bad defrost timer.You can put it in defrost manually and see if this improves the freezer.
Dec 05, 2007 | Whirlpool GS6NBEXR Side by Side...
Siemens KA62DV50GB Side by Side Refrigerator Logo
190 people viewed this question
Top Siemens Refrigerators Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
John Tripp
John Tripp
 Mikey
Mikey
Are you a Siemens Refrigerator Expert? Answer questions, earn points and help others
