Question about Sony Playstation 3 (PS3) Console
System update 1.82
Every time this update downloads it says a connetion error has occured how do I fix this?
  • Anonymous Dec 27, 2007
    i started the system update and it says there is a connection error and everytime i turn it on it tries to update again but then it just says error right away. How do i fix this??
Just try uploading the firmware maybe a day or two later & it should work.
Posted on Jul 10, 2007
SOURCE:
How to fix windows update 80070216
Machine is infected with a rootkit or a virus.
Windows errors can occur for a number of reasons, including programs not installing or uninstalling properly, malware, system conflicts, Active X errors, and the most common, registry errors. PC registry errors occur over time due to the constant writing, editing and deleting of information from your computer's registry over time as programs are installed, modified and removed.
Many malware and spyware programs can also cause unwanted changes to your PC registry, which leads to the errors and reduced PC performance you are likely experiencing. In some cases, registry errors can be occurring without you noticing. They are still harmful and should be fixed regularly.
Download and run Kaspersky TDSSKiller, then download and run Combofix. These two tools will clean-up your machine. The links to download these applications are provided below.
Windows Update should work after that.
Combofix Download
Sep 09, 2014 | Microsoft Windows 7 Home Premium 64BIT...
How do I fix windows error update 8 to 8.1 0x80070003?
copied from windows website.
Windows Update error 0x80070003 Applies to Windows 8.1, Windows RT 8.1 If you receive Windows Update error 0x80070003 or 80070003 when you use Windows Update, try running the Windows Update Troubleshooter.
May 15, 2014 | Microsoft Windows 8 For Tablets
Runs slow should i download a upgrade
Follow these steps:
- Optimize Internet
- Update Browsers
- Update Flash player
- Clear Cookies
- Clear History
- Fix registry errors
If problem still occurs then use system utility tool Reginout.
Jan 16, 2013 | Dell Latitude D530 PC Notebook
Fix error 8024402c
Click Start, and in the Search box on the start menu, type CMD, then press Ctrl+Shift+Enter (this will get you an elevation prompt for an Administrator command prompt)At the command prompt, type net stop wuauserv, then press EnterType rmdir /s %windir%\softwaredistribution\wuredir, then press Enter. Type Y to acknowledge the command.Type net start wuauserv, press EnterUse the Windows Update Web site again to install updates.Hope updates are installed.. If problem still occurs then run a system utility tool like Reginout for an instant fix.
Apr 21, 2012 | Microsoft Windows Vista Ultimate Edition
Error code 0x00000002
STOP 0x2 DEVICE_QUEUE_NOT_BUSY error code has a value that is 0x00000002. This is a fatal error typically known as STOP message or Blue Screen of Death (BSOD).
This error generally occurs in Windows XP but may also occur in latest version of Windows such as Windows Vista or windows 7. The computer may stop responding without warning. Moreover, your computer may give error messages like STOP 0x00000002 error or related errors and if blue screen appeared then you may have to restart the system in the mean time of your work due to which unsaved work will be lost.
Cause of Error:
  • You may be using corrupted profile in your system which raised this problem
  • The device driver of your system is not updated
  • Malfunction of hardware usually is the cause of error such as STOP 0x2 DEVICE_QUEUE_NOT_BUSY or similar error
  • Registry database of your system may have corrupted or modified erroneously by invalid application
  • You have installed new hardware unsystematic or installed unknown application
  • Spyware has infected the PC
  • Antivirus software is not working
  • The operating system or application might have run out of usable memory.
This is one of the serious problem in computer if it is not resolved instantly then it might create some more unexpected error. STOP 0x00000002 error and its related error will disturb you all the time and you may have to bear loss of data. When blue screen of death appear on your monitor screen then you need to restart directly whether you have saved your work or not. Therefore, you are suggested to fix STOP 0x00000002 error as earliest possible.
How to Fix:
To fix STOP 0x00000002 error you need to follow the following methods.
  • If this error occurs in your pc then you will have to restart the PC and then press F8 key before appearing Windows. You will see a black screen with white text giving many options. Select the option "Last Known Good Configuration" and press Enter. If you have configured the computer improperly then it may fix the error.
  • If you have installed any hardware in your system then the chances is more that the device driver is not updated and thus errors of type STOP are given at the time of operation. You must download latest drivers.
  • If your system does not become stable then you need to try scanning of registry with this tool. Since, registry keeps all configurations of your system if it gets impaired then you must download registry repairing softwareand repair it .
Mostly, spyware has been the reason of various errors in computer system. Spyware damages files in the computer system and if once damaged then it is no longer used and it also corrupt registry database. The file which is infected by virus may be a program file, system file etc. If STOP 0x00000002 error occur in spite of antivirus then download anti spyware to scan your computer.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 28, 2011 | Microsoft Computers & Internet
The problem with sound (cod 10 error). compaq nx7010
A Code 10 error usually occurs due to:
  • Missing device driver
  • Malfunctioning device driver
  • Incomplete device driver files
If the device due to which the error has occurred contains the value FailReasonString in its hardware key, then this string is displayed as an error message. Otherwise, the device displays the following error message:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Most of the time, you can resolve this error by updating the device driver for the faulty device. To update the driver, select the System option from the Control Panel. In the System Properties dialog box, select the Hardware tab, and then select the Device Manager button. Scroll through the Device Manager window and identify the faulty hardware device. Right-click on this device and then select the Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
Causes of System Errors
System Errors Usually Occur due to:
  • Device driver conflicts
  • Corrupt or damaged software files
  • Malfunctioning hardware
  • Corrupt or damaged system registry
  • Virus or spyware infection
Steps to Prevent System Errors
With a little vigilance and extra precaution you can easily prevent most system errors. Some of the tasks that you can perform to prevent system errors are listed below:
  • Keep your operating system, device drivers, and software applications updated with the latest hot fixes, security releases, and updates.
  • Run regular antivirus and anti spyware scans to keep your PC free from harmful and disastrous malware. Always keep these software updated with the latest security releases so that your system is always protected against malware infections.
  • Avoid opening attachments of unsolicited emails and visiting dubious websites.
  • Do not download freeware and shareware from websites whose authenticity you aren't sure of.
  • Be very careful while downloading ActiveX controls from various websites. ActiveX controls provide their master with complete control over your system and therefore, a malicious ActiveX control can cause severe damage to your system and may also enable a hacker to steal your personal information.
  • Last but not least, perform regular registry maintenance to ensure that your registry is free from errors. 90% of all system errors are connected to the system registry in one way or another. You can easily perform registry maintenance with the help of a registry cleaner such as RegGenie. This software will provide you with a simple-to-use graphical interface and enable you to scan and clean registry errors in just a few mouse clicks.
System errors are common on Windows systems and can occur due to a number of reasons, including problems with device drivers, hardware, software applications, and the system registry. Code 10 is one such system error that occurs due to problems with a device driver. You can fix this error by updating the faulty device driver. Preventive maintenance with the help of antivirus software, registry cleaners, and a certain amount of vigilance while working on the Internet can help you keep your PC free from system errors.
Additional Recommendations...
Driver Update: Many errors are related to driver problems such as obsolete, outdated or incompatible drivers. A driver update tool is recommended to scan your system for corrupted and outdated drivers and to ensure that all your drivers stay up-to-date.
Jan 15, 2011 | HP Compaq JBL Pro (401508-001) Computer...
My Buffalo 1TB Ext.Hard drive is not showing on my list of drives on my computer. It shows (in the device manager) an error Code 10..What does this mean?What can I do to fix the problem? Thank you
Almost all Windows operating system users come across system errors at one time or another. A flickering or blank screen, frozen cursor, blue screen, or an unexpected system restart are all indications of a system error. Most of these errors display an error message that you can use to troubleshoot and fix the problem. In this article, we will learn about the code 10 error and then have a look at common causes of system errors and methods to prevent them.
How to Fix a Code 10 Error
Dec 17, 2010 | Buffalo Technology 1TB DriveStation...
My ps3 connetion test keeps on failing because of connection speed[download and upload]
This is a problem occurring in all the play station 3 consoles....... this is mainly because of some error in board .....as a result it leads to the damage of ur PS3 ....................try to update your system ..........
if its working good then better download this Repair Guide for further information .........
CLICK HERE to download
Dec 11, 2010 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
