Question about KitchenAid Kitchen Aid KSM150PSBK - Artisan Series 5-Quart Mixer, 10 Speed, Imper
How do I replace the governor on a kitchenaid mixer KSM150PSBK
    Novelist:
    Scholar:
  • KitchenAid Expert
  • 134 Answers
With two screwdrivers, you can carefully pry off the governor assembly. Be careful no to bend, remove the governor drive stud and lay it away so it will not be lost.
See page 6 of the service manual Fig. 22, and page 11 will show you how to reassemble the governor.
Service Manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Thank you,
Colleen
MendingShed.com
800-339-9297
Posted on Apr 23, 2013
2 Suggested Answers
  • 185 Answers
SOURCE: kitchenaid mixer makes a clattering sound at low speeds - seems to be coming from the governor or the control plate - any ideas, is this a common problem and how should I approach it?
Did it start clattering before or after it was re-greased? The K5ss by Hobart is an excellent mixer and there is no reason why it can't go on for a bunch more years. First you can get clattering if the brushes are less than 5/16th inch long, But that is not usual.
I would think that the rear bearing which is in the center at the rear may be more your problem, That bearing is behind the speed control switch and behind the governor (don't discount the governor being the problem) and is attached by two 3/8th nuts and slides onto the two guide slides that hold the motor parts in place. What i have found over the years is that 1.) the studs can bend (happens but not often) 2.) the bearing which is in the center of the big aluminum housing, (Called rear bearing assembly) moves over the years and causes humming and clattering.
So what to do about it? Loosen the two nuts a turn or two (do not remove) look at the top of the the bearing assembly and you will see a metal tab (used to attach the rear cover) (make sure the bowl and beaters are not attached to the machine) now plug it in and turn it to stir speed or number 2 position, put your finger on top of the tab and press down while the mixer is running, you should hear a change in pitch, and it should effect the clattering noise, (It will go up or down, or you may hear a new noise a light humming) (The humming is caused by the armature no longer in the center of the motor field and getting to close to the stator of the motor while it is operating, when it is out of center the developed magnetic field that causes the armature to turn gives off the humming noise because it is out of center or balance) if you notice that the clattering gets louder or softer by pushing down or pulling up you have to play with it to find the sweet spot, when you find it tighten the two nuts down just enough to hold it in place and no more. It takes a while and you wont hurt the machine but never go above speed two while doing this. If that fixes the problem you may have to do it more than once as the machine continues to age or if you move the machine around a lot. the real problem is the armature needs replacing (if this is the problem). Next you may have the machine timed wrong and that has to do with the speed control switch entirely, let us know what you find if these are not the problems we have a ways to go but they are the usual culprits with your symtom.
Posted on Mar 04, 2013
Why will my kitchenaid stand mixer only go fast?
You will need to look under the back cover and make sure that the lever is moving the speed control plate out and in at the bottom. Out = fast. If that is moving freely and there are no broken pieces inside that back cover (springs, brass governor bits) then replacing the small pcb at the top with the 4 wires coming out of it should solve the problem.
May 21, 2014 | KitchenAid Food Mixers
My governor assembly is broken and the speed controller does not work
You will need to buy a new governor from Kitchen Aid and possibly the speed control plate at the back. Often when the governor explodes it damages the contacts, they aren't expensive and it's easier than fluffing around trying to straighten it up.
Jan 02, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid stand mixer runs only on slow speed
The Kiichenaid mixer has a centrifugal speed governor. I suspect your is stuck. It will need to be disassembled, and inspected.
Jun 28, 2012 | KitchenAid Food Mixers
Top speeds don't work
Referring to the following parts description:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
The speed is controlled with a combination of the governor assembly #24 which mounts on the motor shaft, and the phase control board #27 which is mounted on the back of the mixer.
They operate in conjunction with item #25, the control plate assembly.
WARNING SHOCK HAZARD. FOLLOW THESE STEPS ONLY IF YOU ARE COMPETENT WORKING AROUND HOT ELECTRICAL COMPONENTS AND FOLLOW ALL SAFETY PRECAUTIONS!!!
Remove the rear cover screw #37 and the rear cover #36 and examine the governor when it is running. Also watch the speed control lever mechanism as you move it from off to the highest speed watching for binding etc.
If the governor appears to be opening and closing as the speed increases and the linkage is not binding then the problem is most likely the Phase Control Board, item #27.
Apr 18, 2010 | KitchenAid K45SS Classic Stand Mixer
Speed and not running correctly on a ksm150
Hi JIM, Happy New Year! From the symptoms you describe of your sister’s mixer it appears there are a couple of issues that need to be addressed. Issue #1, when your sister found the loose governor counterweights that should have been a clue that the governor needs to be replaced. The counterweights should not come off the governor. From your description that you “put everything back together, the actual mixer runs (but a little too fast on slow)” is an indicator that although everything went back together, the governor is still not functioning properly, so it still should be replaced.
Issue #2, which concerned you more, was “the arcing that is constant on the actual contact points that turn the motor on and off.” The contact points you refer to are the mixer’s electric motor brushes, and although arcing continuously occurs (that’s why the mixer head gets hot during heavy usage) under normal operation, it may be time to inspect and replace the mixer’s brushes; the more worn the brushes, the greater the arcing, which makes it more noticeable while more heat is produced.
Before going too much further, be sure to have your Parts List Manual on hand, too. If you don’t have the original you can easily download a PDF version from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, KSM150P and select the file: KSM150PSWH0.pdf (773.44 KB) listed for your model that appears under Parts List (61). Check to see that this matches your sister’s mixer model.
Turn to pages 8 & 9, titled “Motor And Control Parts” which provide an exploded view for the disassembly and reassembly of the mixer’s motor and electrical control components. Locate Illus. Nos. 29 and 19, Governor Assembly and Carbon Brush, respectively. These are the parts that I would replace – one governor and two carbon brushes.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! – hslincoln
Dec 28, 2009 | KitchenAid KSM150PS Artisan Series Stand...
K45SS cycles on low speed, then has only one higher speed
It sounds like you may have an issue with either the governor assembly and or the main control. If the speed you are getting is constantly going up an down in RPM then this could indicate that the governor has simply become worn and its resistance is gone. If however you get no speed at all and then all of a sudden you get a high speed then it will most likely be the main control. Part number for the governor assembly is 17830. Part number for the main control is 240904−2. Both are relatively simple and cheap to replace. Hope this helps
Thanks
Nov 18, 2009 | KitchenAid 32685 Mixer
Lymy kitchen aid mixer speed
It sounds like you may have a governor issue. which is located at the back of your unit. it controls the amount of current going to your motor by way of centripetal force. the part number for the governor assembly is 4159675. this can become weaker over time and will eventually cause it to sputter or speed up suddenly. hope this helps.
Thanks
Sep 30, 2009 | KitchenAid Food Mixers
Changed the governor...how do you set it for all speeds to work properly
Hi. Go to mendingshed.com. Look for the page titled Kitchenaid mixer parts. Near the top of the page, locate the FREE KA Service Manual. Download it. This valuable manual covers your K45SS mixer. In it you'll find what you need to adjust speeds and more.
If you haven't already, go to kitchenaid.com, select customer care and then select locate manuals, select it. Enter your model# in the search window in this manner, k45sswh. When you get to the manuals page scroll down and find the parts list for your mixer. It will come in handy if you ever need to order parts.
If this solution has assisted you, please rate it.
Good luck! ricardok45
Apr 28, 2009 | KitchenAid K45SS Classic Stand Mixer
Mixer speed settings
It could be the phase control, or it could be that the governor assembly or associated spring is missing or malfunctioning.
Mar 20, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K5SS mixer speeds up beyond set speed.
I have the same mixer and I believe your problem is the governor that is on the back of the motor. You can figure it out by downloading the repair manual here:http://store.mendingshed.com/kitaidparts.html The manual has all the info you need; including a troubleshooting section. The governor is availible from the the same site here:http://store.mendingshed.com/kagovernor.html What tipped me off on my K5SS was looking at the governor as it ran and I could see it moving back and forth; not steady like it should. Good luck!
May 14, 2007 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid Kitchen Aid KSM150PSBK - Artisan Series 5-Quart Mixer, 10 Speed, Imper Logo
424 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
