Question about Kenmore Washing Machines
Kenmore Heavy Duty Washing Machine model number 110 91250100 not starting
I have checked the circuit breaker. Looked at all wiring to make sure it is connected tightly with no breaks or corrosion on it. When trying to start, it wont start with the on/off switch in any position.
catriver
  • 878 Answers
SOURCE: Kenmore washing machine
Sounds to me like you have a worn drive block and possibly a bad spin tube. The drive block can be accessed by removing the agitator first. Next you will need to remove the spanner nut. Now you can remove the basket. Attached you will see the picture of the drive block, I hope if it downloads. The spin tube locks into this drive block with two tabs that fit in respective grooves in the block. If the tabs are worn off the spin tube, that will have to be replaced as well. Good luck,
Posted on May 21, 2006
AlmostBob
  • 550 Answers
SOURCE: kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Posted on May 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Posted on Feb 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Posted on Mar 13, 2009
  • 1937 Answers
SOURCE: Trying to remove spin basket (inner tub) from Washing Machine
See the Sears parts site for washer 82372110.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82372110
The following may also help.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=146
Posted on Jan 26, 2010
My North Star industrial pressure washer trips breaker when burner ignites
Is it all electric? If so, that is maximum load (pump, blower and ignition spark) . Is the breaker on the machine or in your house/building? If yu have a 20 amp machine plugged into a 15 amp circuit it might run cold but trip out when you add the spark and burner blower. Also check if there are other items using the same circuit. If your extension cord is long and light guage wire ( smaller wires have larger numbers, 10 guage wire is heavy duty and 16 guage extension cord is light duty) it could be the cause of the breaker tripping.
Jul 04, 2014 | Garden
I need wire diagram for jcaho 1015
Have never looked for a manual that wasn't on the net.
Jun 08, 2014 | Heavy Duty Associated Equipment 6002B...
Washing machine will not start the wash cycle after filling with water. I have tried normal, delicate, and heavy duty cycles.
Not sure what model you are referring to, but in general, it sounds like a problem with the timer switch or if it's all electronic, then it will be in the control board.
If I had the model number I could be of more assistance.
May 27, 2011 | Kenmore Washing Machines
I have a older model heavy duty kenmore washer after it filled up with water it just stopped on its own no nosy no smell I pulled on the nob to restart it but no luck I then unplugged the unit
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Without knowing the model number etc. I can only offer a couple of suggestions.
1. Try to set the knob to another position such as spin and re-start.
If it starts to spin and / or drain, the problem could be with the timer not advancing.
2. Is it possible that the washer isn't getting power? Check the house fuse box / circuit breaker to be sure, or plug a lamp into the outlet.
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngMost of the other Whirlpool / Kenmore troubleshooting answers for the motor not running point to the motor or its' connections itself.
Oct 13, 2009 | Kenmore Washing Machines
I replaced the coupler in my Kenmore washer Ultra Care I Heavy Duty Series 80 (MOdel # 110 92582220). Simple enough, remove front/side panel. Pull motor off (only 2 eletrical disconnects), replace,...
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Washing Machines Logo
181 people viewed this question
fordexpert
Mike Squire
Robert Rankin
