Question about Westinghouse Electric SK-26H730S 26 in. LCD TV
My Westinghouse TV is stuck in sleep mode - Westinghouse Electric SK-26H730S 26 in. LCD TV
How do you get a Westinghouse 50 inch TV out of sleep mode
Go to sleep timer in menu and hit button until it goes from max sleep (i.e. 90 minutes) down to 0 minutes or off.
Jul 07, 2016 | Westinghouse Televison & Video
Westinghouse auto scan
Obtaining and using a replacement remote might help.
Mar 03, 2014 | Westinghouse Televison & Video
I have a sony kv 25dxr tv it stuck on sleep mode how do i take it off the remote does work can I reset the tv and how
Unplug,replug the tv like an hour later.The tv should reset itself back to the factory setting.Just don't know,it will get rit of this sleep mode setting thought.U can try website like Remotes.com to buy an exact remote to the original.
Oct 21, 2010 | Sony Televison & Video
Westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
Feb 16, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
TX-47F430S seems to be the common problem of going back into standby. Powers up shows the logs and then goes back to low power. The light never goes blue. The fiber optical laser turns on and stays on but...
This is known as SLEEP MODE / STANDY MODE problem.
Simple solutions:
3.Then turn-on your TV using the remote control2_bing.gif. Just in case it won't go all the way to normal state.
6. These steps are done to over-ride the sleep mode.
Roan
Jan 29, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
TX-42F430S Lock up on power up
I have a similar problem with my TX-42F430S; Mine freezes when changing from Comp 1 to Comp 2. unpluging and waiting was the only fix. Just recently my TV just started turning off(after about 30min of watching) and the led will flash blue. I need to unplug for about 10min before it works again. Getting frustrated and I have contacted Westinghouse to send for repair. only had the TV for 3 months; connect to Roger Explorer HD box.
Nov 02, 2007 | Westinghouse TX-42F430S Television
Westinghouse Electric SK-26H730S 26 in. LCD TV Logo
155 people viewed this question
Top Westinghouse Electric Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
ray gallant
Are you a Westinghouse Electric Televison and Video Expert? Answer questions, earn points and help others
