Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Sparks from wires ina 1995 g20 van - 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
    Scholar:
  • 117 Answers
Do the wires spark only when the engine is running? If so the problem could be from the ignition spark plug wires. If they spark with the engine off, then you have a wire loom problem with a wire shorting to ground where you see the spark Tape it up
Posted on Nov 02, 2013
Where is the turn relay on 95 chevy G20 van
On the left side of steering column under the cluster its a 3 wire square relay with DOT written on it
Jul 19, 2016 | 1995 Chevrolet G20
Sparks jumping from spark plug wires in 1995 chevy g20 van the wires are new and so are the plugs cap and rotor and coil
replace the leads with a heavier grade of lead insulation Use spacer bars to seperate the leads as the current will jump to the lead of lower resistance ( ie piston not in compression mode). Spark jumping will cause problems not the least being a blown motor through firing at the wrong time
Jan 06, 2013 | 1995 Chevrolet G20
I need a stereo wiring diagram for 1995 chevrolet g20 gulf stream van
Below is a wiring diagram. I do not have a picture of the connector but there are wire colors on the diagram which should help you figure it out. Also I believe if there was no cassette deck in the vehicle (factory), I don't believe there were any rear speakers. Hope this helps....
Mar 11, 2012 | 1995 Chevrolet G20
My 1995 Chevy G20 van won't start most of the time. The engine cranks and whines, but never starts.
I would be looking for fuel first a faulty fuel pump. second seeing if you have spark, bad wires or plugs or even distributor, timing could be out
Jan 29, 2012 | Cars & Trucks
How do I remove or replace the arm rest on my Captains chair? I have a 1995 Chevy G20 van.
how do i remove the broken piece of arm rest from my 1999 full size chevy van . front drivers seat
Jan 24, 2011 | 1995 Chevrolet G20
Chevy 95 g20 van 8 cylinder wiring order spark plugs
1-8-4-3-6-5-7-2 The #1 spark plug is the front spark plug on the drivers side and the cylinder location in order from front to back on the drivers side is 1-3-5-7 and on the passenger side it is 2-4-6-8. The ignition rotor rotation is clockwise.
If your Distributor cap is not numbered then replace the new wires, or transfer the old ones to the new distributor cap one wire at a time. Identify the #1 spark plug wire and start from there.
Apr 23, 2010 | 1995 Chevrolet G20
Where is the jack stored on our 1995 Chevy G20 van
It should be located on the right hand side fender wall on most Chevrolet / GMC Vans. Another location it may be under your hood on one of the fender walls (these is more common with Dodge)
Aug 23, 2009 | 1995 Chevrolet G20
1992 G20 Chevy van died going 80 mph acts like out of gas but pump is pumping could this be distributor rotary or what
I would go over your basics
check fuel pressure
check fuel filter
check for spark
Low fuel pressure can cause all types of power problems. If all of them check out fine, I would check your exhaust converters for blockage.
Jun 18, 2009 | 1995 Chevrolet G20
I hasve a 1995 chaevy g20 van.Took it to a shop
You really need more information (basis for any real diagnosis) but, If the weather was damp or rainy, you may want to consider checking the cap and rotor for cross firing caused by carbon tracks inside, or, ignition wires for arcing either to each other or to the nearest ground. This can show up as an intermittent mild miss or starting problem and evolve into your current condition.
Apr 28, 2009 | 1995 Chevrolet G20
Replacing Spark Plugs
Remove the engine cowling inside to access the ones in the rear. The front ones can be accessed from the front of the engine compartment. One or two of the middle row plugs can be accessed most easily by jacking up the vehicle and removing the front tires. Make sure you follow all safety procedures and use jack stands.
Mar 22, 2009 | 1995 Chevrolet G20
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
51 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
