I have a NEC NW4001 Twin Tub washing machine, that will drain out from the spinner bowls but will not spin? What could be the problem?
SOURCE: How to remove front panel of washing machine
there are two screws at bottom. unscrew. then lift up and out.
Posted on Nov 13, 2008
rickzilla
  • 706 Answers
SOURCE: Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Posted on Dec 06, 2008
JULIANFIX
  • 975 Answers
SOURCE: NEC NW452 4.5kg washing machine - spin cycle not working
theres 2 things to look for , 1 the LID SWITCH that tells the main module that is OK to SPIN, it could be loose or defective (need a multimeter to check the voltage on switch) 2 the DRAIN PUMP MOTOR , usually it gets stuck with lint and debris, need to open washer ,locate at the bottom on one side where the DRAIN hose is connected, is a small motor , take it out and check inside for clogged stuff , also check drain hose , hope this helps , AJ
Posted on May 16, 2009
dblred
  • 68 Answers
SOURCE: Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Posted on Sep 12, 2009
SOURCE: Washing machine will not drain.
I have the same problem. If I press on the lid by the switch it starts up and finishes the load. Hope this works for you!
Posted on Dec 11, 2009
How do I fix water not staying in the wash tub of Twin tub, LG WP 750R?
If your drain is not high enough the water will siphon out while filling. Check your owner's manual for correct height, usually about 39 inches from ground
Jun 20, 2014 | LG Washing Machines
Panda twin tub dryer not spinning any ideas as to fix?
Your drum belt is off track, worn, or broken
Apr 29, 2014 | Washing Machines
Twin tub washing machine
change the brushes on your motor
Jan 24, 2014 | Washing Machines
How can i remove the spinner drum from a defy twinmaid 920 (twin tub)? please help?
1)You have to tip the machine on it's back and remove all the screws from the bottom grey cover.
2)There are 4 screws securing the drain plug at the back. Remove these as well. Gently pry off the bottom of the machine.
3)The spin motor sits on four spring mounts. Undo the 4 screws from the top of the mounting plate.The motor shaft is not screwed to the drum. Slide the motor out of the drum shaft.
4) Once free, there are 2 X 10 mm bolts that lock in 2 grub screws on the shaft. Loosen these an remove the grub screws and remove this coupling off the drum shaft.
The drum is now free to come out the top of the machine.
Hope this helps
Jun 16, 2012 | Washing Machines
Spinner on twin tub washing machine not spinning
I have had a manatee twin tub washing machine with spinner for two years. When I went to spin dry the first load this evening, it would turn on, but not spin. I read the above entry about another twin tub. I did the following... I unplugged the machine for 1 minute. Plugged it back in, then slowly and carefully turned the spin tub clockwise for 1/4 turn, then counter-clockwise for 1/4 turn. I cannot explain why it worked, but it did. So, try this trick before taking it apart. Good luck!
Jan 15, 2012 | Washing Machines
Spin dryer on my twin tub washing machine does not drain properly. There is water at the bottom of the tub
I 've got twin tub w/machine service is not spinning and draining, can you pls tell me how to solve the problem?
Thanks
Oct 06, 2010 | Samsung Washing Machines
Sounds like change grinding in spin cycle
This machine is prone to getting stuff down into drain pump. Pull unit away from wall, disconnect plug, hoses etc... Pull back steel panel of of rear of machine, facing rear of machine, drain pump on lower left, rinse pump on lower right, take needle nose pliers or spring pliers and remove hose to tub and drain pipe hose, tilt machine forward, take 5/16 nut driver and remove three screws holding pump, drop pump down, replace pump. Install in reverse order. Then, remove center nut in center of tub, pull center spinner out, then lift top to machine, remove inner tub and clean out metal, money or other stuff from bottom of outer tub, reinstall in reverse order.Once money has gotten into pump it can damage it, so replace it even though it looks good.
Oct 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Need instructions for replacing spinner motor
figured it out by oursleves - part came of old motor by twisting opposite direction to spin and pulling.
Apr 12, 2009 | Washing Machines
Eco smart won't drain, smells hot
hi
you commented on hearing water in the machine after the wash , i know that f&p spin bowls have a liquid inside the actual spin bowl system i think it aids in the spin operation of the machine, but if you had something in the drain network then that will stop the machine from emptingout as it all works on a time basis check and see that you are not getting any leaks from the bottom of the machime as your new pump won't last long if it gets wet also if there is water leaking that can be the main seal on the motor shaft failing
cheers grant
Oct 19, 2008 | Fisher and Paykel GWL11 Top Load Washer
Hitachi twin tub spin dryer won't spin and pump out water if I have more than two light items in it. The washer is perfect and I love it. Does it have a belt for the spin that needs tightening or what...
you probably have a sock or some other item in the bottom of your spin tub that is blocking the flow of water out of your spin tub an that prevents the spinner from spinning properly you need a wire long enough to reach in there and remove whatever is blocking it
Aug 04, 2008 | Washing Machines
Washing Machines Logo
175 people viewed this question
Top Washing Machines Experts
